Old 12-29-2015, 12:34 PM   #1891
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
You can add a 2 point, but you cannot change the stock bars, they decided those aren't strut bars and cannot be changed.
There was a bulletin a couple of years ago.
Sent from my DROID RAZR HD using Tapatalk
14stu is offline   Reply With Quote
Old 12-29-2015, 04:26 PM   #1892
xwd
Originally Posted by Shneegle View Post
We can use a triangulated in place of the stock 2 point, you just have to use the factory location to install it. GTSpec is one of the 3pts that would work based on my understanding of the rule.
It's not legal apart from the fact you can't modify/change the stock bars as noted by 14stu. You can change one that is an existing three point bar, but you can't tie together two 2-point bars like we have into a three point one.
Old 12-29-2015, 08:35 PM   #1893
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Thats funny. So we add a 2 point and basically have a 3 point. We just cant modify the existing stock bars. What a great rule!
Shneegle is offline   Reply With Quote
Old 12-29-2015, 11:11 PM   #1894
renfield90
The Stig's German cousin
What are people doing for rev limit? I know there's not much power to be made but bumping from 7500 to 7600 gets me from 59 to 61 in second. Would be really nice to hit 63 or even 65 but I don't want to run into valve float.
I've searched ft86club up and down and haven't seen a hard number anywhere.
Old 12-30-2015, 12:53 AM   #1895
CraftyObeseCrunchyKitty
Drives: Blue ZC6
What month and year?
CraftyObeseCrunchyKitty is offline   Reply With Quote
Old 12-30-2015, 08:49 AM   #1896
48Spoons
Drives: Ultramarine FR-S
Ran into this same quandary mid year when i was getting a tune. Ended up going with 7600, though hit around 64-65. I'm also on 255s which i think are a little taller. Went from hitting rev limit 4-5 times a course to maybe once which was really nice.
48Spoons is offline   Reply With Quote
Old 12-30-2015, 11:58 AM   #1897
14stu
14stu's Avatar
Appendix F - Clarifications (of the official SCCA Solo Rule Book)
Scion FR-S and Subaru BRZ
The pair of OE strut tower-to-firewall/bulkhead braces are not considered to be a strut bar per Section 12.18 and are not allowed to be removed, modified, or substituted per section 14.2.G.
This clarification was added in 2013 during the first year the twins' competed in SCCA events.
The Following User Says Thank You to 14stu For This Useful Post:
whataboutbob (12-30-2015)
Old 12-30-2015, 02:23 PM   #1898
renfield90
64-65 indicated or calculated? I know the 255s will help but IMO it's only a small help. With respect to width, someone stacked them up against 245s and they're basically the same. :/
7800 would be enough to probably never shift except on insane courses, but I've seen suggestions that valve float starts that early. Again though, most of what I read is more speculation than hard evidence or number crunching.
Old 12-30-2015, 03:48 PM   #1899
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
I have 255/40 rivals and my radar detector measures speed through GPS and its always right with my speedometer.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 12-30-2015, 08:02 PM   #1900
48Spoons
I think it was 64 indicated and 65 calculated. Was oringally going to go higher but yeah, the valve float rumors scared me off it. While its probably fine, I'd rather not be the guinea pig.
Old 01-02-2016, 02:08 PM   #1901
RedBRZ80
Drives: 2013 Red BRZ
I don't think I've seen a top national prep car ever having changed or messed with them. Just don't think it adds much to the deal.
RedBRZ80 is offline   Reply With Quote
The Following 2 Users Say Thank You to RedBRZ80 For This Useful Post:
BlaineWasHere (01-02-2016), tigermack (01-02-2016)
Old 01-03-2016, 03:20 PM   #1902
bslate3
Drives: 2015 CWP BRZ
Looking forward to joining the STX crew with Sam 14stu.
What ride hight is everyone running. We are running the Ohlins with the older stiffer spring rates. Also is anyone running a slight forward rake?? Or is neutral better?
bslate3 is offline   Reply With Quote
Old 01-04-2016, 09:59 AM   #1903
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Looks like my stock brake pads are just about due to replacement. What pads are you guys using for STX? I'm looking for something better than stock, but won't squeal like crazy on the street. I don't mind some dusting as long as it washes off fairly easily and isn't corrosive.
smg1138 is offline   Reply With Quote
Old 01-04-2016, 10:12 AM   #1904
FastWhite
Drives: Subaru BRZ Limited M/T
Winmax W3. I followed the bed in procedure and I do get any squeal. At all. I do get dust, but it washes off just fine. I have gunmetal Mach V wheels.
FastWhite is offline   Reply With Quote
The Following 2 Users Say Thank You to FastWhite For This Useful Post:
smg1138 (01-04-2016), whataboutbob (01-04-2016)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
