Old 12-29-2015, 08:59 AM   #1
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Are your windows hard to control
Seems there is an annoying sweet spot to roll the windows down part way. Almost like I have to hit that little bump to control this. As for control of passenger window from drivers side, I can only go all the way down. Drivers window I can hit that little spot and it works fine. Is this a defect or bad design? It's pretty annoying
RichardsFRS is offline   Reply With Quote
Old 12-29-2015, 09:01 AM   #2
Ashikabi
Ashikabi's Avatar
I have this problem too. Have to try several times to get it where I want it. Usually use the vents anyways to avoid wind noise
Old 12-29-2015, 09:13 AM   #3
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Took me a while to realize and get used to the two-step switch.
If you push or pull all the way down, it automatically opens or closes all the way.
But if you push/pull half way, you can hold it as long as you want until the window is where you want it, let go and its good. going halfway doesnt engage the automatic fully open/close feature.
The Following 8 Users Say Thank You to PandaSPUR For This Useful Post:
Eighty 6 (12-29-2015), humfrz (12-29-2015), Packofcrows (12-29-2015), soulreapersteve (12-29-2015), stevesnj (12-29-2015), Tcoat (12-29-2015), Teseo (12-29-2015), TRD-X (12-29-2015)
Old 12-29-2015, 09:17 AM   #4
RichardsFRS
Panda thanx cus I haven't tried it that way. Will try that at lunch. So annoying
Old 12-29-2015, 09:27 AM   #5
Teseo
Drives: frs
This bring the question:
"Automatic vs Manual"
The Following 7 Users Say Thank You to Teseo For This Useful Post:
FRSBRZGT86FAN (12-30-2015), go_a_way1 (12-29-2015), new2subaru (12-29-2015), PandaSPUR (12-29-2015), soulreapersteve (12-29-2015), Tcoat (12-29-2015), YamahaR86 (12-29-2015)
Old 12-29-2015, 09:54 AM   #6
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Bingo PandaSPUR is 100% correct.
Anyone that's owned Toyotas over the years knows the "two-step switch" feature as it's been used on the driver's door only for years now.
Toyota finally listen to their owners and have been installing this feature on both front door windows on newer model Toyotas.
The Following User Says Thank You to TRD-X For This Useful Post:
Tcoat (12-29-2015)
Old 12-29-2015, 11:05 AM   #7
LOL. You want me to send you the owners manual again?
PandaSPUR (12-29-2015), soulreapersteve (12-29-2015), YamahaR86 (12-29-2015)
Old 12-29-2015, 11:22 AM   #8
I thought the owners manual was on-line ..... at www.ft86club/forums ......
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Old 12-29-2015, 11:23 AM   #9
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
My windows were somewhat hard to control as I was originally very lenient with them. I have since given them a stern talking to and now they are much more controlled.
2 step feature tho
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following 3 Users Say Thank You to Tectoniic For This Useful Post:
FatFree (12-29-2015), Tcoat (12-29-2015), YamahaR86 (12-29-2015)
Old 12-29-2015, 11:42 AM   #10
RichardsFRS
Yea panda that worked! Thanks
Old 12-29-2015, 11:50 AM   #11
RichardsFRS
Flux capasitor over both
Old 12-29-2015, 11:53 AM   #12
PandaSPUR
PandaSPUR's Avatar
np
I actually read the manual before I got the car (while anxiously waiting for paperwork), but still managed to miss the part about the window. Who would've known a window switch could be so complicated >_> Figured it out myself eventually.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Tcoat (12-29-2015)
Old 12-29-2015, 12:06 PM   #13
RichardsFRS
I had a scion before this and I don't recall being that big of a pita. Otherwise Id never heard the end of it from the wife. I didn't get a manual on my used FRS but I got the PDF, just haven't printed it
The Following User Says Thank You to RichardsFRS For This Useful Post:
Tcoat (12-29-2015)
Old 12-29-2015, 12:13 PM   #14
That's the ticket. There is a wealth of wonders to be found in there.
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 01:04 PM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 04:08 PM
Hard to See at Night with Tinted Windows? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 26 01-05-2013 10:50 PM
How hard can it be to tint the windows on the GT86 Killerbee Scion FR-S / Toyota 86 GT86 General Forum 19 12-28-2012 11:13 AM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-21-2012 11:39 PM
