#827 | |
Drives: Toyota 86
Interesting point is, if I advance one cell by 0.350 at 2800RPM certain point IAM drops to 0.88. ![]() Fortunately over 6800RPM, I can advance one or two clicks from above logged data so more flattened power output at those high area. Edit: After adding some ign advance to the high RPM and got FLKC -0.65 from 7343RPM just before retarding by the ign map. http://datazap.me/u/makinenkr/201512...7-112&mark=107 For the Virtual Dyno graphs, smoothing works great! In my cases, smoothing 3 is more realistic I think. Last edited by makinen; 12-27-2015 at 08:56 AM. |
#828 |
Drives: FR-S Whiteout
This pull is not a good candidate for conversion either. Do you have bouncy suspension or this is a rough road?
http://datazap.me/u/makinenkr/201512...84-81-79-80-78 @makinen This is a 3rd gear pull I did at a slight downhill grade. http://datazap.me/u/solidone/cw1z2-1...5012&mark=4887 Notice there are no dips or spikes in the RPM. good candidate for conversion if I had done it on a level surface. 1smoothing coverted from this log ![]() 2 smoothing with same log: ![]() While the curvature of the line reflects the actual output the line is shifted up by about 20~25 WHP at the peak from what I'd get on a level surface.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 12-27-2015 at 09:16 PM. |
#829 | |
Drives: Toyota 86
I've increased smoothing factor to 5 and the result resembles actual Dynojet numbers. |
#830 |
Drives: 2016 Oceanic FR-S
Maybe someone can help me here. For some reason OF Manager freezes every time I try to export my log. I am using windows 10, and I am not sure if it is an OFT issue or if it's an OS issue. When I click download all it will bring up the log file. Then when I click the log file it will go through a process and after that OFM is frozen. Not sure if it's actually downloading it or not, but I have been unsuccessful trying to find it. Thanks in advance for any help.
#831 |
Drives: '22 BRZ
Make sure your OFM is up to date and make sure the OFT is up to date. Older OFT software would let you create logs that were too big (more than about 20 minutes) and would lock up the OFM. You might have to quickly click the delete button to get rid of the corrupted log file and make a new one after updating everything.
| The Following User Says Thank You to DocWalt For This Useful Post: | Akya2120 (12-28-2015) |
#832 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
Had some troubles in the last two weeks with my Twin Screw. Turns out my pre-o2 sensor exhaust leak (against block), was causing the sensor to read lean and dump gas into the block. Developed a bad knock. Pulled the oil, smelled like gas. Changed oil, stripped the car to stock, ran it for a week, no issues. Tuner sent me a new tune with less timing, ran that for a week with no issues. I flashed the final tune (original one) back on it, and have been running it for 24 hours now. I've also sent him these logs and am awaiting confirmation that I'm good to go. If anyone can take a look and tell me how these look, that'd be awesome.
There's a bunch of 2nd/3rd gear pulls, and one decent 4th pull. Wasn't on the highway, so I did what I could. http://datazap.me/u/rifle/final?log=0&data=6
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#833 | |
Drives: '22 BRZ
#834 |
It felt a bit weird, to tell you the truth. Just want to make sure I'm not starving the motor or anything. I'll see what he has to say. Thanks!
295WHP/220TQ |
#835 | |
Virtual dyno can be very consistent and accurate if you do it correctly.
Intent > Content
cowardice is the mother of cruelty. |
#836 | |
#837 | |
Drives: FT86
#838 |
No clue. I'll ask!
295WHP/220TQ |
#839 |
Drives: '22 BRZ
True, but considering it was pretty lean at WOT (leaner than I am NA anyway) well before it got to 11.8...
#840 |
Drives: UK GT86
That's if you trust the sensor output as the genuine AFR....
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | DocWalt (12-29-2015) |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
