Drives: SWP BRZ Limited Manual. 2014
Slow leak on tires under warranty
Should I bring it in to a dealership to get it checked out? Or to an authorized Michelin seller like sears?
I have 2-3 months left in my warranty. It's mostly when it gets cold, and it compress, and triggers a low air pressure. Takes 2-3 weeks and it starts triggering. Thanks!
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
#2 | |
When it's cold fill it to 40 psi, and watch the pressure throughout the week, the TPMS light comes on when one of the tires is out of range of the others by 5 psi or if they are past the 40 psi mark I believe. I suggest you get the tires checked for leaks first.
#3 |
Search the michelin website for details on the warranty. And then go to the dealer. Car warranty and tire warranty are separate as the tire is considered a wear item. If all four tires do it, I would say it is the gauge you are using. Gas station air gauges are always off a couple psi.
| The Following User Says Thank You to swarb For This Useful Post: | humfrz (12-28-2015) |
#4 | ||
Nah, just 1, and 19k with a slow leak is just weird. I remember tires were case by case basis from but it's been too long.
#5 | |
So, the first thing I would check is the valve ...... remove the cap and smear some spit over the top of the stem to see if it bubbles out. Most likely your tire has picked up a sharp thing that is slowly letting the air out or a leak around the bead. If so, remove the wheel and tire and submerge it it a kids swimming pool to locate the leak. Then plug it with a kit. Oh hell, that's way too much work ...... just take it back to the dealer or a tire store and let them fix it ...... ![]() humfrz PS - even NEW tires can pick up stuff ....
#6 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
First, go to dealer. Let them take measurements and drive it for like 10min. Then, have them test the psi. If no change then tell them you'll drive it around to run errands and bring it back later in the day. Do that and have them test psi again. If nothing happens, take wheel off, inflate it like 3 extra psi than what tire says, dump it with rim into tub full of water and try to see if any bubbles appear. If none, then it might be cold weather? Mine are off 2-3 lately. 29 both left tires and front right is 33, back right 32. edit: I just remembered I swapped my tires around a few days ago!
#7 |
Not much to say other than, the tire has a puncture or it is the valve stem. Warranty does not cover road damage and it is unlikely a warranty claim.
#8 | |
Drives: BRZ DGM Limited
If it is just one tire losing air that quickly my advice is not to waste your time going to the dealer. Take it to a good tire shop and have them check it out. Did you hit any pot holes before this started happening? Hopefully its just the tire and not a bent rim. |
#9 |
The Fail Boat
Drives: CWP S.B.
Tire isn't a warranty item. O.O
Michelin has their warranty but most place not gonna help you go through the the trouble to cover it unless you brought the tire from them. (Or unless you know someone that works @ tire shop) Sent from my iPhone using Tapatalk |
#10 |
Drives: 2019 BMW ///M4
Take it to America's tire or something. They'll just fill it to near max PSI and dunk it in water. If you see bubbles then you have a leak. It's not under the 36k/3 year warranty because it's wear and tear. If it's a leak in the tread it's patchable. If it's on the shoulder it's not. If it's leaking from the stem (highly doubt it) then there's rubber seals inside to be replaced.
It shouldn't cost more than 10 dollars. America's tire/Discount tire patches tires for free even if you didn't buy it from them.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#11 |
Maybe the shelf elf is slowly letting the air out ...... because you've been naughty .....
![]() humfrz |
| How to warranty your stock tires and save money on Pilot Super Sports | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 81 | 03-31-2016 09:48 PM |
| Twins are slow? Not as slow as these cars! | babydriver | Scion FR-S / Toyota 86 GT86 General Forum | 66 | 12-12-2014 12:09 AM |
| Help! - slow leak from oil drain plug | amram | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 05-28-2014 02:42 PM |
| Slow Leak, wha do you guys think could be the cause? | peenut1086 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 12-25-2012 10:47 PM |
