Old 12-28-2015, 11:29 AM   #799
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Originally Posted by shiumai View Post
100% sure it's not unless you think that the installation of a supercharger results in an exhaust shield suddenly loosening on the same day. it doesn't sound like metal clanging. it's more of a plastic rasp than a metal one.
Pulley vibration ?
Paulo86 is offline   Reply With Quote
Old 12-28-2015, 11:32 AM   #800
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I mean the audio is crap, but that sounds metallic to me. Also, if you haven't checked it out.... you can't rule it out. That noise could have always existed and you just now noticed it since you changed something.
You did change the way air moves through your motor as well, so...yes you could have easily changed the exhaust noises.
The Following User Says Thank You to Summerwolf For This Useful Post:
shiumai (12-28-2015)
Old 12-28-2015, 11:41 AM   #801
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
the noise didn't exist before. i've had the car 3 years and am pretty in tune to all the little noises i hear on a daily basis.
shiumai is offline   Reply With Quote
Old 12-28-2015, 11:45 AM   #802
Summerwolf
Panda Trueno
Summerwolf's Avatar
3 years, 7,000 miles you said earlier correct?
Old 12-28-2015, 11:45 AM   #803
-Phil
Drives: Rb25 neo brz
Try using some Chassis mics placed around and keep moving them until you find exactly where the noise is, Sounds bothersome but if you're anything like me its worth your time.
-Phil is offline   Reply With Quote
The Following User Says Thank You to -Phil For This Useful Post:
Old 12-28-2015, 12:05 PM   #804
shiumai
shiumai's Avatar
yes. by the way, i'm not discounting anything you've suggested - i'm just starting out with the most obvious thing that was changed right before the noise started and going from there.
Old 12-28-2015, 12:12 PM   #805
shiumai
shiumai's Avatar
sitting in the cabin, it sounds like it's coming from the engine compartment, but i do realize that it's sometimes difficult to determine exactly where it's coming from. i considered a few things - intake noise, exhaust noise, belt slipping (squeak?), transmission noise due to more torque, ACVS mentioned here: http://www.ft86club.com/forums/showthread.php?t=95280
etc.
if i found out anything new or edelbrock responds to my PM, i'll let you guys know.
The Following User Says Thank You to shiumai For This Useful Post:
-Phil (12-28-2015)
Old 12-28-2015, 12:58 PM   #806
shiumai
shiumai's Avatar
Originally Posted by Paulo86 View Post
Pulley vibration ?
I thought of that as well, so it's definitely on a list of possible sources.
Old 12-28-2015, 03:34 PM   #807
CSG Mike
CSG Mike's Avatar
from what i heard in the video, the rasp i'm hearing does sound like that. i did mention it to @CSG Mike right after noticing it, and he mentioned that it could be intake/exhaust noise. since i never heard it before (stock exhaust except for nameless axleback) i chalked it up to maybe intake noise. but usually that's more of a whoosh or hiss (that i'm used to). i also thought it could have been vibration of the plastic intake at some kind of resonant frequency or something like that.
as i mentioned above, it's only at WOT near redline, right when the gears change. it's more of a 'mechanical' noise, and is very brief.
paging @itsibarra @Edelbrock LLC
i'd like to take it by edelbrock and give mike ibarra a quick drive around the block to hear it so we can diagnose what it is. if it's normal and doesn't cause harm, no worries, but i'd like to find out for sure.
If that's the noise you're hearing, it's completely normal. You should hear it on the CSG car; its way, way more audible
It's essentially valvetrain noise that you didn't hear before, but is not detrimental to your car at all. It helps the engine breath better at low RPM for more output.
CxG (01-21-2016)
Old 12-28-2015, 03:52 PM   #808
shiumai
shiumai's Avatar
Thanks for chiming in, Mike. So what made the difference between being able to hear it now vs. before? Also, since I hear it only around 6500 rpm to redline, I wouldn't exactly call that low rpm.
Old 12-28-2015, 04:31 PM   #809
CSG Mike
CSG Mike's Avatar
The amount of cam advance there is, in relation to the ignition phase, which allows the noise to be audible over normal engine operation.
Old 12-28-2015, 04:43 PM   #810
tracerit
Drives: '13 SSM BRZ Limited 6MT
Originally Posted by FuzzyFunk View Post
This is from Edelbrock just to clear things up as I was also a little confused:
Once you hit 36k, the limited powertrain warranty will be up, however the supercharger itself has a 3 year warranty which covers any part within the system itself.
I'm at 30k miles now. I was under the impression that if I installed it myself, there would be NO warranty on anything. So I was figuring having a shop install it, but if I do that then I'll pay the quoted $800 install fee for only 6k miles left of warranty on the limited power train, and have a 3 year warranty on the superhcarger itself. Doesn't seem worthwhile to pay a shop to do it then.
But if I install it myself, will I still have the 3 year warranty on the supercharger? I can roll the dice and waive the 6,000 remaining miles of the limited power train warranty to save $800 and installing it myself.
tracerit is offline   Reply With Quote
Old 12-28-2015, 05:33 PM   #811
Paulo86
Paulo86's Avatar
So i was right but no one listen to me :'(
Old 12-28-2015, 06:07 PM   #812
shiumai
shiumai's Avatar
I was listening - i'd like edelbrock to hear it too, just so they can identify it as such and determine its a normal with the addition of the SC.
CSG Mike (12-28-2015)
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
