Old 12-27-2015, 01:50 AM   #225
ajc209
Drives: GT86 Cosworth
Originally Posted by DocWalt View Post
FWIW I didn't use any threadlock on mine. I put the fronts on today, set at Ohlins' factory height and they dropped a LOT lower than I expected, a bit over an inch lower. I'm waiting for the Eibach springs to install the rears (and I blew a few hours messing with one of the factory end links, destroying it in the process) but they should be here tomorrow.
First impressions just from installing the fronts and with no front sway bar... Very OEM like ride quality. They do make a "woosh" noise over bigger bumps (like speed bumps) which was unexpected. Nothing bad to report, super easy install too.
edit: Linking to the post I made about today... Factory end links are horrible, for the record. http://www.ft86club.com/forums/showp...ostcount=13327
im going to see how far I get with stock end links. If they they are stuck ill get some whiteline ones.
400lb rear springs
im going to see how far I get with stock end links. If they they are shocking ill gry some white line.
Sent from my GT-I9300 using Tapatalk
ajc209 is offline   Reply With Quote
Old 12-27-2015, 01:52 AM   #226
ajc209
whoa double post
Old 12-27-2015, 08:32 PM   #227
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I finished installing my Ohlins today and aligned the car. -2.5 camber up front and -2.0 in the rear. About 1/32" toe in front and rear. Set the dampers to 15 clicks front and rear and took it for a few short drives. For being so much stiffer springs than stock (I'm using 60N/mm front and 70N/mm rear, same as ajc209) the ride is sublime. WAY better than the KWs on my GTI. I'm excited to get some miles on them now
BTW I'm going to use OEM links for now. Might change to Whiteline end links if I change the anti-roll bars. I'll have a replacement for the one I destroyed sometime this week.
Old 12-30-2015, 03:15 PM   #228
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Under hard cornering, the OEM front endlinks will bind and you will have steering lock.
I found out the hard way, when my front steering locked going into Turn 9 (Rainy Curve) at Laguna Seca. Almost lost the car on a flat, off-camber turn.
-alex
Old 12-30-2015, 03:34 PM   #229
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
-alex
Lovely, thank you for the warning. What links did you change to?
Old 12-30-2015, 03:40 PM   #230
Tor
Tor's Avatar
Drives: Toyota GT86
Can you expand? You mean with any lowered car? Or under what circumstances?
Tor is offline   Reply With Quote
Old 12-30-2015, 03:40 PM   #231
mav1178
mav1178's Avatar
Whiteline.
Now I'm on the adjustable endlinks that were supplied by Blitz w/ their coilovers.
-alex
Old 12-30-2015, 03:41 PM   #232
mav1178
mav1178's Avatar
Meaning that the front sway bar endlinks need to be shortened when you lower the car, otherwise it may bind when you are turning and hit the strut.
This varies depending on your suspension stiffness, traction, and sway bar stiffness.
-alex
Old 12-30-2015, 03:44 PM   #233
Tor
Tor's Avatar
Drives: Toyota GT86
Isn't it possible to rotate the swaybars in their mounts to facilitate the stock end links?
If the end link is longer that the space available, did you mount the swaybars preloaded??
Old 12-30-2015, 03:50 PM   #234
ajc209
Mav im lowered by the Ohlins specified amount ~20mm front and the roll bar is in the same position as stock so adjustable links not needed. You must be low to get it to bind?
Old 12-30-2015, 03:52 PM   #235
mav1178
mav1178's Avatar
I only was able to get it to bind at the track. Never had issues with it on the street.
I should add that I was also running additional caster in addition to camber.
-alex
Old 12-30-2015, 03:52 PM   #236
ajc209
and how low?
Old 12-30-2015, 04:04 PM   #237
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Did you use the Ohlins spacers with the Whiteline end links?
Again, thanks for the warning. I don't really want to experience that anywhere, especially on a track.
Old 12-30-2015, 04:27 PM   #238
mav1178
mav1178's Avatar
Originally Posted by ajc209 View Post
and how low?
Around 25mm front and 20mm rear. It's not much more than what the Ohlins recommended setting was, but no issues until I went to the track, and only on certain corners that had excessive G-forces.
-alex
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
