Old 10-03-2015, 03:09 PM   #99
dp1
driving smoother faster
Drives: Sold
This works great for my light HF jack with 4" base:
http://www.ebay.com/itm/1-ea-Univers...-/231461452946
Tried hockey puck first but it didn't last long. I track and ax so use jack often enough. The ebay piece is easy to put onto the pinch weld by hand then jack can be aligned underneath. Great support, very happy with it
dp1 is offline   Reply With Quote
The Following 3 Users Say Thank You to dp1 For This Useful Post:
DarkSunrise (10-03-2015), zc06_kisstherain (10-05-2015), ZionsWrath (05-22-2016)
Old 10-05-2015, 08:29 PM   #100
tracerit
Drives: '13 SSM BRZ Limited 6MT
How does it fit? The depth of the cut didn't measure up (not deep enough) when I measured against the pinch weld. But maybe it'll conform to it since it's a PU material.
tracerit is offline   Reply With Quote
Old 10-06-2015, 09:52 AM   #101
dp1
Drives: Sold
Fits very well. The thin bottom of that cutout provides all the support. All I wanted to avoid was metal on metal. Key advantage - easy to first put on by hand (stays on when you let go), align jack underneath, pump.
The Following User Says Thank You to dp1 For This Useful Post:
tracerit (10-06-2015)
Old 12-24-2015, 03:02 PM   #102
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This article saved me installing my berk axleback, knowing the rear diff is the jack point for the rear was really useful I hope this is in the DIY guide
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Astroboy (12-25-2015)
Old 12-24-2015, 09:25 PM   #103
Astroboy
Astroboy's Avatar
Drives: None
That's how most cars are. I feel like a dumb ass for bending my front left jack point a little. So Its always good to research before doing anything on these cars, because these cars are extremely sensitive
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 12-25-2015, 03:05 PM   #104
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
why is this not stickied?
Old 12-25-2015, 03:39 PM   #105
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by new2subaru View Post
*Giggles*
Seriously. Have you ever worked on it? Even the body panels bent easily. You literally can't lean 0n the car when working on it or it might bend. Even the threads for the wheels on the hubs tear easily. I love these cars but Damn
The Following User Says Thank You to Astroboy For This Useful Post:
Packofcrows (12-26-2015)
Old 12-26-2015, 07:10 PM   #106
Astroboy
Astroboy's Avatar
Drives: None
I understand what you mean but I don't see them as flimsy.
Not flimsy, you just have to double check it's directly on point or they might bend.
I bent it back not to long ago with vice grips, and today, I had the jack points on the lift while I was disarming for a clutch swap
Old 09-30-2016, 09:04 PM   #107
SteelWheels
Drives: BMW125i
Smile Thanks...
First planned project came to a holt when I looked under the car for an obvious jack point. Solved 5 mins later thanks to you.
SteelWheels is offline   Reply With Quote
Old 02-19-2017, 07:58 AM   #108
jdalny
Question: is it possible to get the car up on jack stands without a floor jack (just using the scissor jack that comes with the car)?
I'm guessing not because the floor jack needs to go in the pinch weld space, but if one is using that space for the scissor jack, it's occupied and the jack stand can't be placed there?
jdalny is offline   Reply With Quote
Old 02-19-2017, 02:16 PM   #109
cjny
Drives: 2016 BRZ
If you want a budget-friendly way to get your car on jack stands you can use an inexpensive scissors jack. Not as quick or as stable as a regular floor jack but it works.
cjny is offline   Reply With Quote
Old 02-20-2017, 01:35 AM   #110
FirstWinter
Drives: Car
If you're being that cheap you might as well use the one provided with your car in the trunk.
FirstWinter is offline   Reply With Quote
Old 02-20-2017, 09:35 AM   #111
jdalny
not sure
Well, you sort of misunderstood my question, or perhaps I didn't ask it successfully. But I've come up with a solution. Thanks for the assistance.
Old 02-20-2017, 03:03 PM   #112
cjny
Drives: 2016 BRZ
The one I mentioned can be used to lift the car at the differential or front-center jacking points, allowing the jack stands to be placed at the pinch welds.
Jacking up car - using garage jack NYNOMAD BRZ First-Gen (2012+) — General Topics 2 06-27-2012 08:36 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
