Old 12-23-2015, 07:56 AM   #1
rns294
Drives: 13 BRZ
Question First upgrades to the transmission
I just picked up a used 13 BRZ a little over a week ago and wanted to start making some upgrades to the trans to make it a little smoother.
I was thinking
  • Perrin Rear Shift Bushing
  • MTEC Shift Springs
  • TRD Quick Shifter
  • Kartboy Transmission Mount
  • Perrin Transmission Support
  • Motul 300 fluid replacement
Not buying all of this right away but these are all fairly cheap mods that I have read about and people seem to get a good quick result. I wanted to make sure all of this would fit together especially with the short shifter. I was thinking about adding the whiteline positive shift kit, but someone told me it won't go with a short shifter. So I wanted to check with more informed/knowledgeable drivers to see if all of this would fit together. Thoughts?
Also is there anything else that could generally help the feel of shifting for a fairly low cost?
Thanks for any help/feedback!
rns294 is offline   Reply With Quote
Old 12-23-2015, 11:34 AM   #2
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I use the Whiteline Positive Shift Kit with the TRD Quickshifter and MTEC springs without any problems.
menikmati is offline   Reply With Quote
Old 12-23-2015, 01:09 PM   #3
Xuningshen
Drives: Subaru BRZ
I would just do one thing at a time so you can actually feel the difference each makes. I had the same plan as you. but first I did the motul gear oil, and then I did the perrin rear shifter bushing. And thats where I stopped because I am happy with how it shifts with just those two.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 12-23-2015, 03:25 PM   #4
Vladimir Tutin
Vladimir Tutin's Avatar
Drives: '13 Hot-Lava FR-S
Only have done the Motul 300 myself. Planning on doing short throw and bushing pretty soon.
If you plan on doing both transmission and differential oil at the same time, I recommend doing the differential first if aren't going to use a fluid transfer pump. I did the transmission first and getting the last half of the bottles into the diff was a major PIA.
Vladimir Tutin is offline   Reply With Quote
Old 12-23-2015, 03:37 PM   #5
LenA
Drives: 2015 Silver BRZ
Does rear shift bushing help with everyday type shifting, or only during harder driving. I've done clutch pedal adjustment and Motul. Debating on positive shift kit and rear bushing
Thanks
Len
LenA is offline   Reply With Quote
Old 12-23-2015, 03:45 PM   #6
Xuningshen
Drives: Subaru BRZ
Thanks
Len
yup, it reduces slop by a good amount when shifting between gears. fast or slow shifting so i definitely recommend that.
side note... and i might get crap for this because I might be the only one who doesn't really like the MTEC shift springs. It basically puts it into gear for you(it basically snaps it into gear, and out of gear), to me that reduces shifting/syncro feel.
2014 WRB BRZ
The Following User Says Thank You to Xuningshen For This Useful Post:
LenA (12-23-2015)
SSP A960E Transmission Upgrades sspkris Engine, Exhaust, Transmission 123 06-10-2022 11:40 AM
"Flappy Paddle" Treatment From SSP // Automatic Transmission Upgrades@DSG Performance Jason@DSG Transmission and Driveline 201 06-09-2016 06:31 PM
10% Off All SSP Automatic Transmission Upgrades! // DSG Performance Jason@DSG Transmission and Driveline 13 07-29-2014 01:19 PM
Need Transmission Upgrades for Turbo? Admired Forced Induction 26 11-10-2013 02:48 PM
Transmission moving after upgrades? Sniper2606 Engine, Exhaust, Transmission 2 07-10-2013 01:54 AM
