Old 12-21-2015, 06:18 PM   #547
Kodename47
Kodename47's Avatar
Drives: UK GT86
What I've found that works perfectly with ECUtek is:
Flash, it asks to turn ignition off and on to reset the ECU and then it asks you to clear DTCs, which you do.
While still in that state, press the pedal 5 or so times (I do 10).
Either start the car and leave to idle for ~1 minute or lturn the car off and idle the car the next time you start up.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-22-2015, 07:08 PM   #548
djdnz
1337
Drives: 2013 BRZ WRB S/C
On my second tank of gas after installing the e-force s/c, I didn't count the first tank because I was enjoying the car a bit too much to be a fair comparison.
Pre-s/c, last fill up:
25.10mpg
Post s/c, second fill up:
19.56mpg
djdnz is offline   Reply With Quote
Old 12-22-2015, 07:19 PM   #549
toast
Drives: 14 BSP Edelbrock BRZ
I got better mileage with my STI...
You guys must wind the snot out of your cars at every opportunity, I routinely see 29-30 mpg for a tank.
toast is offline   Reply With Quote
Old 12-22-2015, 07:23 PM   #550
djdnz
1337
Bay area traffic city driving only... When I lived in the country I used to get ~29mpg. But yes, I like the gas pedal.
Old 12-22-2015, 09:28 PM   #551
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
or...drive in stop-and-go traffic that seldom goes over 40 mph.
shiumai is offline   Reply With Quote
Old 12-23-2015, 11:22 AM   #552
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Yeah, I have a stock BRZ motor still (really considering this SC is why I'm here), and I get about 21 mpg unless I take a trip on the highway during a tank. Traffic sucks. Used to get around 30 when I had a low-traffic, highway only commute.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 12-23-2015, 02:41 PM   #553
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Basically the same observations. City mpgs took a good 2-3 mpg hit while freeway driving was relatively the same. I think it has something to do with the internal bypass valve. It probably stays mostly open when cruising but gets closed (therefore loading the sc) when constantly doing pulls like in stop and go traffic.
Old 12-23-2015, 02:43 PM   #554
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
What year STI? I had a 14 that was lucky to see 21mpg average. After e85, it dropped to 14mpg
NotSoJDM is offline   Reply With Quote
Old 12-23-2015, 02:50 PM   #555
toast
2008, stage 2 protune. I would routinely see 22 mpg/tank, better if I wasn't beating on it.
Sent from my Nexus 6 using Tapatalk
Old 12-24-2015, 01:18 PM   #556
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
It's a fairly big drop in mpg... Anyone know what this kit + e85/Flexfuel would do?
This is around a 20-30% decrease. I can only imagine it'll be more.
Of course the drop in fuel is at least compensated for by the massive grin factor :-)
I like driving!
86 South Africa is offline   Reply With Quote
Old 01-15-2016, 02:07 PM   #557
getbent
Drives: 2013 FR-S Blue MT
What is everyone using as an oil cooler solution with the Edelbrock supercharger?
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 01-15-2016, 02:09 PM   #558
NotSoJDM
NotSoJDM's Avatar
I fabbed up a system using a Mocal Tstat plate and Setrab 6 Series Cooler with -10AN lines.
Old 01-15-2016, 02:38 PM   #559
BigFatFlip
BigFatFlip's Avatar
So far most have been custom due to the location of the intercooler. Mine is very similar to @NotSoJDM except with crappy hardware store brackets. I have a setrab 619 and racerx sandwhich plate.
If you want one that works with the kit, you're going to have to hound Edelbrock for a Russell kit. They have the ability and resources, just need interest from customers to justify production.
Old 01-15-2016, 02:40 PM   #560
shiumai
shiumai's Avatar
I haven't added one. If i need one, i'll look into it.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
