Old 12-20-2015, 11:09 PM   #1
Wyattkb
Drives: 2014 Whiteout FRS
Oil Galley Plug Adapter
I just wanted to verify that these are the correct parts for our vehicle to install into the oil galley port on the top of the motor for an oil pressure gauge.
Also is the gasket needed?
Plug Adapter
Gasket
Many thanks
Wyattkb is offline   Reply With Quote
Old 12-20-2015, 11:54 PM   #2
Trust86
Drives: 2016 Halo FRS
Correct
Better be a Defi gauge your putting in...
Trust86 is offline   Reply With Quote
Old 12-21-2015, 12:19 AM   #3
Wyattkb
Originally Posted by Trust86 View Post
Correct
Awesome!
It is a Defi Racer series 52mm. You need precision instruments to monitor vital things like oil pressure.
Thank you
Old 12-21-2015, 01:10 AM   #4
Trust86
Dope
I have the Defi BF series
Oil temp oil pressure and water temp
Post up pics after install
Oil galley temp reading low Tomita San Engine, Exhaust, Transmission 19 03-14-2017 05:22 PM
eTrailer Curt Plug and Play Trailer Adapter Eric1855 Miscellaneous 0 04-20-2014 09:40 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
Adapter help lookchris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-09-2013 10:39 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 09:38 PM
