Old 12-19-2015, 06:49 PM   #1709
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Astroboy View Post
What clutch Are you guys running with this kit? I think I might have smoked my stock clutch
Sent from my LG-D850 using Tapatalk
Exedy stage 1. I like it, but the gear rattle is annoying as hell. I probably wouldn't use the flywheel if I had to go back and do it over
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Astroboy (12-19-2015)
Old 12-20-2015, 08:55 PM   #1710
Astroboy
Astroboy's Avatar
Drives: None
AVO Turbo Kit Owners Topic
Exedy stage 1 on your car? How much power are you making? Did because I think I remembered reading that the clutch is rated at 200tq
Astroboy is offline   Reply With Quote
Old 12-21-2015, 10:52 AM   #1711
protpibe
protpibe's Avatar
I think around 240wtq (310whp) when I dyno'd it last, but I've since increased the boost. No slips anywhere. The exedy stage 1 is rated to 200tq, but it will hold much more. I'm assuming it comes at the cost of excessively fast wear lol
From what I remember reading, the exedy Stage 2 will have nearly an identical pedal feel, but be rated to a higher torque number.
Astroboy (12-21-2015)
Old 12-21-2015, 10:27 PM   #1712
Astroboy
Astroboy's Avatar
Drives: None
Ok, it's official, I ordered my stage 2 then. Thanks. 2 more questions, would you recommend I swap my flywheel to since I burned my stock clutch, and how much stiffer is your exedy clutch compared to the oem one? I like the smooth pedal feel of my stock clutch
Old 12-22-2015, 02:07 AM   #1713
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
TRUTH!
But I guess we put up with it...because race car
Old 12-22-2015, 06:14 AM   #1714
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I have the exedy stage 2 (old revision) and there were some of us with problems like gear lockup and stuff; there is a thread about it. The new stage 2 revision I think it uses oem flywheel... I'm in the process of getting a new clutch soon and people recommended me ACT
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Astroboy (12-23-2015)
Old 12-23-2015, 06:15 PM   #1715
Astroboy
Astroboy's Avatar
Drives: None
Did you install the exedy yourself? Which ones the old version? I ordered mine from ft86speedfactory
Old 12-23-2015, 10:22 PM   #1716
Draco_PR23
Fiebru
Draco_PR23's Avatar
Yes with a friend who is a mechanic, I installed the clutch by Sept/2014.
Here is some pics of the old rev. Stage 2, in the last pic you can see the P/N: http://www.ft86club.com/forums/showp...0&postcount=11
This is the thread about the problems we had: http://www.ft86club.com/forums/showthread.php?t=75445
Current Cars:
Old 12-23-2015, 11:03 PM   #1717
Astroboy
Astroboy's Avatar
Drives: None
Does it come with instructions that show torque specs for clutch bolts? I'm going to install it with a friend to
Old 12-23-2015, 11:14 PM   #1718
Draco_PR23
Fiebru
Draco_PR23's Avatar
It does have some overall instructions; about the torque specs you could found them in the service manual I think which you can find it in the forum. Also there is a diy thread which helped me a lot
Current Cars:
The Following 2 Users Say Thank You to Draco_PR23 For This Useful Post:
Astroboy (12-23-2015), SkAsphalt (12-24-2015)
Old 12-24-2015, 12:04 PM   #1719
Astroboy
Astroboy's Avatar
Drives: None
@protpibe do you have any quarter mile times wile you were pushing 240whp? Dynojet correct
Old 12-25-2015, 08:08 PM   #1720
Astroboy
Astroboy's Avatar
Drives: None
I'm about to install mine tomorrow, I want to know what lubricant I'm supposed to use on the throwout bearing. I might need to go to o'reilys to get it, but don't know what it's called. Also, what lubricant must I use on the shifter when reinstalling
Old 01-01-2016, 01:53 PM   #1721
Astroboy
Astroboy's Avatar
Drives: None
I finally installed mine yesterday, and after 5 miles, it started making a weird grinding noise when decelerating. Do you know what it could be?
Old 01-01-2016, 04:17 PM   #1722
Astroboy
Astroboy's Avatar
Drives: None
I really need your help with an issue I'm having. You see, I recently installed my clutch by myself, and now, i hear a gear grinding noise Every time I decelerate is this normal?
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
