Old 12-19-2015, 09:16 PM   #1
Texas2016Frs
Bottled FRS
Drives: 2016 manual frs
Oft and Vsc sport?
Hey guys I was wondering what exactly Vsc sport does on an oft tuned car
Texas2016Frs is offline   Reply With Quote
Old 12-19-2015, 09:20 PM   #2
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
It should do the same as in a stock car. The OFT does not alter the traction or stability controls in the car. Even the launch control feature in the oft shouldn't alter the VSC settings, because the launch control is really just a rpm limiter setting based on car speed.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 12-19-2015, 09:25 PM   #3
Texas2016Frs
Bottled FRS
So if I'm running oft and push vsc I still get the benefits of the tune and the vsc sport also or does it overwrite some aspects of the tune?
Old 12-19-2015, 09:33 PM   #4
yelsew
Little Member
yelsew's Avatar
Yes, The tune will still give you the engine stuff and the vsc will still give you the slidey body stuff. The two won't affect each other.
<--- My Journal
The Following User Says Thank You to yelsew For This Useful Post:
Texas2016Frs (12-19-2015)
Old 12-20-2015, 09:04 AM   #5
steve99
Drives: FT86
The oft itself has the "pedal dance" function which if you select it will turn off more of the traction stability functions than pushing the vcs sport button, it send commands to the vsc computer via the obd port
As above this is completly separate to tune
Vsc sport and Sport mode at the same time? Markk Scion FR-S / Toyota 86 GT86 General Forum 22 09-28-2015 03:07 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 07:50 PM
H & R Sport Springs (not Super Sport) dewitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-28-2013 10:01 PM
H&R Sport & Super Sport Springs for FR-S / BRZ @ Guerilla Racing GuerillaRacing Brakes, Suspension, Chassis 5 01-11-2013 06:20 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 02:43 PM
