Old 06-08-2012, 01:06 PM   #1
Liquidsnake
Drives: "I drives like a Porsche"
K&N drop in air filters..............will you?
I see they are available on their site. $43.00 Will you?
Thoughts?
Liquidsnake is offline   Reply With Quote
Old 06-08-2012, 01:17 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I was about to when I figured out which one fit (33-2252 btw). But thinking about it, the MAF is so close to the filter media that I worried about oil getting on it.
The Following User Says Thank You to Draco-REX For This Useful Post:
Username (09-05-2012)
Old 06-08-2012, 01:36 PM   #3
Liquidsnake
Didn't even think about that. Will you think about High-Flow Air Filter?
Old 06-08-2012, 01:55 PM   #4
vividracing
vividracing's Avatar
If you properly clean and oil the filter, you'll never have that issue. I've used oiled and oil-less filters on everything from vintage motorcycles to brand new cars and never had any issue. Also, K&N is very adamant that their products don't cause issues. Check the links for more info! K&N is my 1st choice in air filters on my personal cars and motorcycles.
http://www.knfilters.com/warranty.htm
http://www.knfilters.com/check_engine_light.htm
http://www.knfilters.com/common_misdiagnosis.htm
http://www.ftc.gov/bcp/edu/pubs/cons...ts/alt192.shtm
http://www.knfilters.com/air_filter_testing.htm
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
sosick (05-21-2015)
Old 06-08-2012, 01:56 PM   #5
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I was thinking about it, funny how Amazon says 33-2252 will not fit when you put in the 2013 Scion FR-S (just outdated page I'm sure).
[ame="http://www.amazon.com/33-2252-High-Performance-Replacement-Filter/dp/B000AP57OO/ref=au_pf_pfg_s?ie=UTF8&Make=Scion%7C91&Model=FR-S%7C21599&Year=2013%7C2013&carId=002&n=15684181&ne wCar=1&s=automotive&vehicleType=automotive"]Amazon has it for $36.33[/ame]
eriktherod is offline   Reply With Quote
Old 06-08-2012, 02:47 PM   #6
Liquidsnake
So should I buy the K&N drop ins or are they a waste of $$$
Old 06-08-2012, 03:08 PM   #7
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Thats the question... Not sure if anyone knows yet.
Typically, drop in filters make power, but on cars like this- its often 5HP or less...
Right now the only dyno figures I have seen are on prototype replacement intake 'systems'
Esoteric is offline   Reply With Quote
Old 06-08-2012, 04:53 PM   #8
Gardus@Supersprint
Drives: Clio TCE
I like ITG filters. The 3 layers foam has good filtering capacity (still inferior to the stock paper filters) and it doesn't need oil.
On 200-300 hp cars a panel filter can be good for up to 3-4 hp...I'm talking about max power.
I change it only because I save up on the servicing.
Gardus@Supersprint is offline   Reply With Quote
Old 06-08-2012, 05:38 PM   #9
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
You can also use a TRD PTR43-00085 the FR-S uses the same 17801-0D020
filter as an 03-08 corolla and a 1st gen TC
Touge Monster is offline   Reply With Quote
Old 06-08-2012, 06:44 PM   #10
RWD-boxer
RWD-boxer's Avatar
Drives: Black
I just got the 33-2252 k&n. And it sounds different .... I like
RWD-boxer is offline   Reply With Quote
The Following User Says Thank You to RWD-boxer For This Useful Post:
Subaruwrxfan (06-11-2012)
Old 06-08-2012, 06:46 PM   #11
Liquidsnake
Where did you buy it from? Online? Or local?
Old 06-08-2012, 06:48 PM   #12
RWD-boxer
RWD-boxer's Avatar
Drives: Black
It's the same as the scion tc 1gen
Got it at autozone. 51$
Old 06-08-2012, 10:24 PM   #13
TPO
TPO's Avatar
Drives: Scion fr-s,Lexus is250,4-runner
I have the TRD filter in my fr-s. worth the $49 I spent.
TPO is offline   Reply With Quote
Old 06-08-2012, 11:55 PM   #14
Lytheum
Drives: 2013 BRZ Premium 6MT
didnt someone remove the air filter and say the car made no extra power? if thats the case i doubt any filter will make a difference. the only benefit of a k&n is never having to replace it.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Wheel Directory: Advan RG-D 18x8.0 +45 wtf.bbq Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 09-11-2013 05:36 AM
K&N Drop In Filters! Available at Vivid Racing!! vividracing Engine, Exhaust, Bolt-Ons 6 06-29-2012 05:53 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
TRD Drop in AF feldy Engine, Exhaust, Transmission 2 06-05-2012 08:40 PM
