Old 12-12-2015, 11:12 AM   #449
stevesnj
stevesnj's Avatar
Remember when you put 16's on and same height tire the gear ratio will go to true 4.11 and with stock 17's it comes out to 4.03 I believe. So be prepared for a slight increase in RPM and decrease in MPG. But with 16's you get a nicer pull off the line and through 4th gear. That's the main reason I'm going 16's. Some put on 18's and wonder why their cars are slower...lol
My 2016 Build thread
Old 12-12-2015, 11:35 AM   #450
Cole
Not a troll
Cole's Avatar
How do you figure that? If overall diameter is the same, wouldn't it keep the same revolutions per minute or second or whatever it's measured by for the wheel?
Cole is offline   Reply With Quote
Old 12-12-2015, 11:39 AM   #451
churchx
churchx's Avatar
Drives: 2014 GT86
"same height tire" means that overall diameter is not kept same.
Old 12-12-2015, 11:45 AM   #452
stevesnj
stevesnj's Avatar
It's less rotational mass. I've tried a few calculators and the results are the same. This is also a trick back in the day to keep the effective gearing true. Though the difference is negligible about 2% effective gear ratio. Looking back it's a change from 4.05 to 4.10 so not much. But possibly a placebo effect calculates also. In the end getting a lighter smaller diameter wheel and slightly less diameter tire does do something to the effective gear ratio.
Here's a calculator
https://tiresize.com/gear-ratio-calculator/
Old 12-12-2015, 08:31 PM   #453
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Getting a smaller wheel does nothing to the gear ratio. Getting a smaller diameter tire will lower the overall final drive. But none of this has to do with rotational mass; it's pure gearing. Lowering rotational mass will improve performance as if you had geared more aggressively, but it will do nothing to your rpms at given speed, and if anything, your mileage will improve a negligible amount.
The Following User Says Thank You to venturaII For This Useful Post:
stevesnj (12-13-2015)
Old 12-13-2015, 08:45 PM   #454
stevesnj
stevesnj's Avatar
Yep, tru, I stand corrected
Old 12-13-2015, 08:55 PM   #455
venturaII
venturaII's Avatar
Yeah, they're forged, reasonably priced, and have a load rating close to OEM. It's stamped right on the side, so I'll post it up when I head out to my car...
EDIT: Well, I thought it was stamped on the outside part of the wheel, but it's not. I remember seeing it somewhere though...I'm swapping out for my winter setup this weekend, so I'll take a closer look.
Finally got the wheels swapped this afternoon...load rating is stamped on the inside of the rim...1100lbs. A bit less than I recall..
Old 12-13-2015, 09:14 PM   #456
D_Thissen
D_Thissen's Avatar
I'd love a set of Toyota 86 16's
The Following 4 Users Say Thank You to D_Thissen For This Useful Post:
chaoskaze (12-13-2015), drewbot (12-24-2015), funwheeldrive (12-20-2015), Mr.Impreza (12-19-2015)
Old 12-18-2015, 02:40 AM   #457
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Juvenile View Post
Unsure of specs on these for now
Attachment 81381
Attachment 81382
Sorry Guys, I have been checking various threads including this one and still can't work out size and make of rims on the car above...what are they?
Old 12-18-2015, 04:13 AM   #458
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Genuine Watanabe wheels and are 16x8.5 +35 , plus spacers
The Following 2 Users Say Thank You to Juvenile For This Useful Post:
JD001 (12-18-2015), stevesnj (12-18-2015)
Old 12-23-2015, 07:58 PM   #459
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
The Wants for 16" wheel gets stronger per day >___>
We need a 16 inch wheel buy & sell thread....
Old 12-24-2015, 11:17 AM   #460
venturaII
venturaII's Avatar
Unfortunately, the list of high performance 16" tires (excluding DOT race tires with treadwear ratings under 100) in a width suitable for an 8.5" rim is almost nonexistent...
strat61caster (02-25-2016)
Old 01-14-2016, 09:09 PM   #461
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I'm kinda over my high-profile 205s on 7-inch wheels. The sidewall tends to roll over and play dead. I need either 195/55R16, or some 16x7.5s.
Man, no one makes decent 16 x 7.5 in 5x100 with +40ish offset.
Except! Volk CE28 Racing Scholarship model comes in fitments offered by no other Volk Racing wheel, at like 80% the price. Convert to USD (The yen is super weak right now) and add some shipping, and you get rare JDM Volks for $1500.
Limited production, unfortunately. Either way: Everyone buy these immediately.
(other finalists include RPF1s, Gazoo Enkei RS05s, or, strictly for comedy, Sparco Assetto Gara in fuchsia.)
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 01-14-2016, 10:03 PM   #462
MrDinkleman
Drives: 2016 Oceanic, "base" model
See my list in post #437 plus the additional input from a few members after it. it sucks that manufacturers are going away from 16" wheels. A lot of them will have a full range of diameters from 14" to 20+" but they skip 16" for some reason...
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
NissanGuy (01-14-2016)
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
