Old 12-17-2015, 09:57 PM   #1
skinnybehr
Drives: 13brz wrb
P0137 help please
Hello. I am getting a p0137 low voltage. I am currently on a catless exhaust and header setup( jdl uel, mxp exhaust) ecutek tuned at drift office. I didn't get this code until 3-4 months after tune. I'm sure it's not the tune. The cel will come on for 30 mins to a couple hours and switch off for a day or two. I made sure the connectors were fitted in the right spots and o2 seems to be in place. If it was a faulty o2 I feel like the cel wouldn't disappear on its own. Any ideas would be greatly appreciated. Could the o2 be bad after first 18k miles?
skinnybehr is offline   Reply With Quote
Old 12-17-2015, 10:04 PM   #2
skinnybehr
Drives: 13brz wrb
I live in wa also where it's wet and 36-60 degrees daily
Old 12-17-2015, 10:39 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
P0137 comes on and usually regards something to do with the O2 sensor bung, it's harmless and you can just disable it in romraider. If you have an O2 spacer you can get rid of it, and just disable t on romraider
Old 11-27-2016, 01:38 AM   #4
Spechtre
Spechtre's Avatar
Drives: 2014 ZN6
Did you get a solution to this? I am having the same problem under similar circumstances.
Spechtre is offline   Reply With Quote
Old 11-27-2016, 03:36 PM   #5
It's the PNW ...... most likely mold, mildew and moss growing inside the ECU.
jcw99 (11-27-2016)
Old 11-28-2016, 11:29 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
how are your fuel trims and measured AFR? If they are out of whack by quite a bit you may have a leak in the exhaust
guybo is offline   Reply With Quote
OpenFlash OTS - CEL P0137 ssyed Software Tuning 9 03-27-2015 11:32 AM
