Drives: frs
Something cool about SPC control arms
I am getting ready to change out all of my car's remaining rubber bushings to polyurethane. I also have the whiteline roll center correction kit and front caster correction to go on as well as SPC rear lower camber adjustable control arms. I was looking at the new control arms to see if I could change the already installed bushings to polyurethane. They look different than regular bushings, so I called SPC directly and talked to one of their tech guys about the bushings. It turns out that they install x-axis bushings in these inexpensive control arms. That is their name for cross axis bushings. These are like a heim joint that is sealed and packed with grease for longevity. So full articulation with much less flex than rubber or polyurethane. Wow! That is some nice technology for the reasonable price of these control arms. Just thought I would share that as I found it very enlightening!
#2 |
Drives: 2005 Toyota Camry
Also not legal for SCCA STX in case you are into those things.
#3 |
Drives: frs
Really? They appear stock in every way, but the cam bolt camber adjustment is not stock. Obviously the bushing isn't, but it doesn't look very different from rubber. That is unfortunate that they wouldn't pass muster for stx
#4 | |
-alex |
#5 |
^^ Doesn't matter how similar it looks, it matters what performance advantage it provides.
#6 |
Drives: frs
I'm heavily modded, wouldn't be stx anyway. Oh well. We do have a local autocross though, I need to go investigate. You guys that do it make it sound fun. Tell me the entry fee is worth it though for such short runs. How many runs do you get at an event usually?
#7 | |
Drives: '13 FRS - STX
Seat time depends on the group, I've paid $50 for a day and gotten anywhere from 3x-10x runs usually coming in with <400 seconds of seat time. IMO if you come in with the mindset of 'I want maximum sliding and hooning and going fast' it's a losing proposition. For me it's the challenge of your skills, how quick can you adapt and maximize what's available to you? Having targets, seeing where you stack up and trying to find that extra tenth of a second is the satisfaction for me. Can you beat your buddy? Bring a friend along and both drive your car, learn and teach each other? Or get downright nasty trying to prove you're faster. It's all about mindset imo. ![]() And depending on where you're at as a driver, if you feel comfortable handing the keys over to a local hotshot it can be eye opening how much time you're leaving on the table that they can unlock sitting in your car for the very first time. |
#8 | |
For the entry fee, practice events are much more fun. Championship events usually have less seat time (especially if they are behind on schedule). I do enjoy the seat time, however I prefer road race/track events. -alex |
#9 | |
Drives: frs
#10 | |
Not a troll
Maybe I'll have to take some time off of work to get a solid weekend of HPDE in... |
#11 | |
Do it! There's the SPDA autox school in April (sign up EARLY, it always sells out in like 15 minutes), and also the OTA Time Attack school (single day this coming year) in early May.
#12 | |
Not a troll
#13 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
AutoX is also pretty reasonably priced at around $40, and if you're lucky and early enough, you can sign up for the Scion Racing Contingency like Jamie and I.... The only knock to the local AutoX here is that the time idling and waiting for your next run is longer than an HDPE track day. But also is much more affordable and inherently safer.. However, while idling and marshalling the course, you get the learn a lot from VERY fast guys, and get to talk with guys who have fun driving cars rather than hard parking (which is rare in my area) |
#14 | |
Not a troll
I look forward to spinning out and making the guys running the event fix pylons after every run I make |
| Megan racing rear lower control arms , toe arms, rear traction arm | fcdrifter20 | Brakes, Suspension, Chassis | 11 | 01-03-2016 08:11 PM |
| Adjustable control arms and Toe arms | zumin | Brakes, Suspension, Chassis | 12 | 07-08-2015 06:54 AM |
| DME Lower Control Arms and DME Toe Arms - Review | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 02-24-2015 11:53 AM |
| GTSPEC rear control arms & toe arms review | Jesse | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-23-2013 03:20 PM |
