Old 12-14-2015, 01:05 PM   #1877
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
New goodies Name:  ImageUploadedByTapatalk1450116329.319979.jpg
Size:  302.7 KBName:  ImageUploadedByTapatalk1450116342.359325.jpg
Size:  257.6 KBName:  ImageUploadedByTapatalk1450116355.548804.jpg
Size:  195.8 KBName:  ImageUploadedByTapatalk1450116367.438449.jpg
Trap63 is offline   Reply With Quote
The Following User Says Thank You to Trap63 For This Useful Post:
Guillaume (12-15-2015)
Old 12-14-2015, 01:38 PM   #1878
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Trap63 View Post
They fit even with or without fog lamp, see pictures above.....
I thought he made that, as in its not the actual Subaru piece? Maybe I'm reading and looking at the pictures wrong.
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 12-15-2015, 03:30 PM   #1879
DSOmegaX
DSOmegaX's Avatar
He made them but they're based on the templates provided from the actual part, which shows it works with or without the fog covers. The lines of both covers are the same
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
SPCorBUST (12-16-2015)
Old 12-16-2015, 10:48 AM   #1880
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
They will fit but something about the alignment with the fog covers?
krayzie is offline   Reply With Quote
Old 12-16-2015, 05:06 PM   #1881
DSOmegaX
DSOmegaX's Avatar
Don't really have a plan if the number keeps increasing though...
@dsomegax.cars
The Following 4 Users Say Thank You to DSOmegaX For This Useful Post:
chanomatik (03-12-2016), chaoskaze (12-16-2015), krayzie (12-16-2015), Trap63 (12-16-2015)
Old 12-16-2015, 06:58 PM   #1882
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
That's what I was saying.
Those teeth on fog cover is a bit different between fog delete & fogged. But you can err heat it up & bend it to make it fit or file some of the extra edges out to make it fit.
PS: It will fit even if you don't do anything, but it wont align like the instruction. Not like you can tell unless you are looking right @ it up close.
The Following User Says Thank You to chaoskaze For This Useful Post:
Old 12-16-2015, 10:08 PM   #1883
krayzie
Drive From Home
krayzie's Avatar
You can at least fit 3 more on that wing.
Old 01-12-2016, 08:58 PM   #1884
DSOmegaX
DSOmegaX's Avatar
Originally Posted by chaoskaze View Post
Just so you guys know the DRL extension doesn't really run together with limited fog light bezel.
It can fit but it wont align up properly like the foglight delete bezel. Ofcourse you can hear it up @ bend them a bit and stuff.
Originally Posted by mister.bond View Post
i dont understand what is the difference in fitting ???
if i have Only DRL Lights like the Ts has.....
.....or DRL Lights with Foglights included !!??
i think it will fit both !!?? or am i wrong ?
Every BRZ has the DRL's. If I read it correctly, the dayliner extension doesn't fit if you have fog lights. Even simpler:
Have fog lights? Dayliner won't fit.
No fog lights? Dayliner will fit.
Although, I think @DSOmegaX is going to be testing that theory whenever his set comes in. (I believe I read somewhere that he ordered a set)
It should fit. I just ordered mine (I delayed the order earlier since I was the middle of buying a car haha). I am confident there is no issues. This is because:
1) the description of the item: "It has to use with LED DAY LINER (#484-005-002) as stock fog covers won't fit onto this extension." Remember that in Japan, the LED lights we have as DRL are an option; therefore, what its referring to as "stock" are the fog light covers only (without the LED lights). The question of it fitting is not whether it has fog lights or not, but whether it has the LED lights or not. That component is available to all USDM spec BRZs.
2) if you look closely at the covers for Premium (non-fog) and Limited (fog) for USDM cars, there really is no difference in the shape between the two.
@dsomegax.cars
The Following 2 Users Say Thank You to DSOmegaX For This Useful Post:
Ethereal05 (01-14-2016), SPCorBUST (01-12-2016)
Old 01-14-2016, 04:40 PM   #1885
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
You'll have to let us know how they fit went they arrive. I am interested in picking these up at some point.
Ethereal05 is offline   Reply With Quote
Old 01-14-2016, 06:12 PM   #1886
Trap63
Trap63's Avatar
Yes, they do!
"2) if you look closely at the covers for Premium (non-fog) and Limited (fog) for USDM cars, there really is no difference in the shape between the two."
YOU NEED , AS GRADE, DAYLINER MANDATORY (OR DRL IN EUROPE), no matter about fog or not.
Old 01-17-2016, 01:37 AM   #1887
DSOmegaX
DSOmegaX's Avatar
This is what the "stock fog covers" that japanparts is referring to
The covers are in line with the bumper. In comparison to cars like in US, which have the "find" that stick out
@dsomegax.cars
SPCorBUST (01-17-2016)
Old 01-17-2016, 05:21 PM   #1888
muckypuppy
Drives: MY13 SWP BRZ Cosworth 2.3
No issues with the covers on my AUDM model with DRL's and fogs. They are listed as 'dayliner extensions', so if you have DRLs the piece will fit. As DSOmegaX correctly points out, the 'stock' covers on JDM models do not have DRL's and protruding fins.
muckypuppy is offline   Reply With Quote
The Following User Says Thank You to muckypuppy For This Useful Post:
Trap63 (01-18-2016)
Old 01-18-2016, 03:28 PM   #1889
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Here are mine. I don't have fogs but I kinda feel they are still a little off (sits higher). I don't know if it's bc of the bottom reflections. Either way I'm happy with them.
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
The Following 6 Users Say Thank You to chermo12 For This Useful Post:
brandonblt2 (05-06-2016), Ethereal05 (01-18-2016), Myv (01-18-2016), pfaffendorn (03-06-2016), tracerit (01-31-2016), Trap63 (01-18-2016)
Old 01-18-2016, 07:51 PM   #1890
Ethereal05
Ethereal05's Avatar
Man those look great...Why must they cost so much? Haha. Looks like these might be included in my next order.
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
