Old 12-13-2015, 03:02 AM   #6735
White Momba
Drives: 2015 Sprintex FR-S
Quick question guys, I'm needing to install an intercooler on my 210, I cheaped out and got a stage 1. Now my IAT's are too high.
I've read stories that the bolts break when trying to separate the supercharger, any truth to that? Am I gonna run into any trouble?
White Momba is offline   Reply With Quote
Old 12-13-2015, 09:30 AM   #6736
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
That was an issue with the early ones. If yours is newer, you should be ok. Even if you have an early blower, just be careful and you should be fine. I have one of the first batch and I was able to install the intercooler without breaking any bolts.
Old 12-15-2015, 02:31 PM   #6737
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Like @Draco-REX said, if it is an early one then you might have an issue. I have an early one and I think one or two of mine broke but I replaced all of mine with new stainless steel bolts before I installed it anyways. They aren't that pricey so if you wanted to pick some up for peace of mind it wouldn't put you out too much.
Dustin is offline   Reply With Quote
Old 12-16-2015, 02:07 AM   #6738
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Dumb question inc: Is it just me or has anyone else wondered or knows the answer as to why the sprintex innovate supercharger kit has a much smaller intercooler and intercooler piping than any other supercharger and turbos?
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 12-16-2015, 02:46 AM   #6739
sw20kosh
Drives: 2013 Black FR-S
Water. Those r hoses.
Old 12-18-2015, 11:57 PM   #6740
dave-
Drives: 86 GT
SPS 210 kit with 69mm pulley and intercooler.
Will this configuration support straight E85 on stock injectors and pump?
If not, what is required? (Injector/pump size that is)
dave- is offline   Reply With Quote
Old 12-20-2015, 09:37 AM   #6741
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
You may want to consider injectors at that point. See if @moto-mike has any insight.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following User Says Thank You to Rifle For This Useful Post:
Xero-Limit (12-21-2015)
Old 12-20-2015, 02:36 PM   #6742
stockysnail
Just the tip
stockysnail's Avatar
Moto-east recommended to me larger injectors and fuel pump if going flex fuel. I'm guessing it's possible without, but may not getting the full potential as not enough fuel to reach the limit.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
dave- (12-21-2015), Xero-Limit (12-21-2015)
Old 12-21-2015, 11:01 AM   #6743
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
It is about where you want the fuel to hit. You can hit the target AF ratios with stock injectors close to 280 whp, but you'll be shooting that fuel in less than ideal places of the compression stroke. Using larger port injectors allows for keeping an optimal DI mixture/DI timings, less oil dilution, and more consistent power.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
86 South Africa (10-27-2017), dave- (12-21-2015)
Old 12-21-2015, 03:28 PM   #6744
dave-
Drives: 86 GT
Good info @moto-mike, exactly what I was after. Making the power is one thing but having to work around limitations isn't worth it. I'll stick to pump (98 RON here, 93 in the US?) for now.
Assuming there was no further hardware progression, what size injectors and pump would you recommend to support optimum tuning on the SPS/69mm pulley kit?
Old 12-21-2015, 07:20 PM   #6745
stockysnail
Just the tip
If e85 is in the picture, Moto Mike recommended the following to me:
-DeatschWerks DW65c 9-651-1010 Fuel Pump kit
-DeatschWerks 700cc Fuel Injectors
as seen on his site: http://www.moto-east.com/store/ft86/ft86-fuel.html
otherwise if only using pump gas, stick with stock injectors and fuel pump.
The Following User Says Thank You to stockysnail For This Useful Post:
dave- (12-22-2015)
Old 12-22-2015, 11:23 AM   #6746
jwvand02
Drives: 2013 SWP BRZ Limited
It's definitely possible without. If I'm not mistaken, both Delicious and Moto-East have gotten cars over 300whp with stock fueling.
That's not to say it's not a good idea, but I haven't seen much evidence that it's a requirement.
edit - just re-read this and realized it was mentioning the SPS blower. Yeah, probably need fuel for that
jwvand02 is offline   Reply With Quote
Old 12-24-2015, 02:23 PM   #6747
White Momba
Just wanted to follow up guys, the install went without a hiccup. No issues with bolts breaking. Only downside i found was the entire intake manifold needed to come out to properly reach the rear upside down bolts.
Here's a video of my blower after about 10k. Very happy.
and here are a few pics.
https://drive.google.com/file/d/0B3Q...p=docslist_api
hope that worked ^
The Following User Says Thank You to White Momba For This Useful Post:
stockysnail (12-24-2015)
Old 12-24-2015, 08:05 PM   #6748
jwvand02
hope that worked ^
you can get to the bolts in the rear with some really creative tool usage. I ended up using an allen screwdriver bit and a 1/4" ratcheting box wrench to get to those.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
