#57 |
Drives: 2013 Asphalt FRS
Well I would hope the MAF reading would not change do to you plumb nitrous in after it.....
Please tell me you have someone else working on your car.......SMH
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-14-2015 at 04:30 PM. |
#58 |
Drives: 370z
I don't think most people consider nitrous as naturally aspirated as the whole point is to bring more than atmospheric oxygen into the cylinder?
Just to do the math, to get 300hp out of a 2l engine... assuming you are an amazingly awesome (f1 grade) engineer and can get 210 PSI of BMEP out of the engine (haha), that would equate to a tq of 169 ft. lbs, so to get 300 brake hp you would need... 9300 rpm... hahaha... To get 300whp, with a loss of ~15% you would need... 10,700 rpm... hahaha... since peak hp is usually 15% less of peak tq you would realistically need to rev to 12,300 rpm... Okay, so not possible on gasoline, so how about e85? I can't find any realistic numbers for e85... some paper claimed they got to 19 bar (275psi) of BMEP, but that's supercharged... In any event, to get down to a realistic level of ~9000 rpm, you would need a BMEP of 287 PSI or 19.8 bar (230 ft.lb of torque!!!)... don't think that's realistic... Edit: In any event, it's kind of a moot point, the rods bear force, not power. So really, the limit isn't hp, the real limit IS the BMEP. So the reason NA hp doesn't always equate in terms of failures to FI HP is that FI boost TQ (BMEP) WAAAYYY higher than NA, and usually can't rev as high. So if the rods fail at 300 whp FI, you would need to see what their max tq is at, then that is the max tq you can hit on NA, which likely you'll never hit because it's na. In this respect nitrous can be seen more like FI, as it boosts your BMEP to rediculous levels. Last edited by totopo; 12-14-2015 at 04:16 PM. |
| The Following 3 Users Say Thank You to totopo For This Useful Post: |
#59 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Lets just plumb pure O2 into an engine and see what happens hahaha!
| The Following User Says Thank You to go_a_way1 For This Useful Post: | FRS Justin (12-14-2015) |
#60 |
Drives: Sterling BRZ Ltd
Lots of reasons not to do that haha
#61 |
Not Bаnned Anymore
LMAO but that would make like 5x the HP!! my 200HP NA FRS would be 1000HP NA FRS for about 23 seconds
#62 | |
Drives: '13 FRS - STX
#63 | |
| The Following User Says Thank You to mrk1 For This Useful Post: | Sportsguy83 (12-15-2015) |
#64 |
| The Following 2 Users Say Thank You to raven1231 For This Useful Post: | FRS Justin (12-14-2015), mrk1 (12-14-2015) |
#65 |
Drives: toyota mr2/ Toyota GT86
Nitrous is chemical supercharging - uses a chemical reaction to generate the extra air inside the cylinder
the end result is the same - more cylinder pressure just like you had fitted a blower... so no nitrous is not an NA mod |
| The Following 2 Users Say Thank You to 350matt For This Useful Post: | ajc209 (12-15-2015), FRS Justin (12-14-2015) |
#66 |
Drives: GT86 Cosworth
What people are not getting is that engines have tolerances and the level set at 250whp is to guarantee within reasonable doubt a reliable car. Sure a certain percentage of cars might take 350whp for 50k and multiple trackdays but its not going to help the likes of Cosworth when those customers come back with broken engines....
Sent from my GT-I9300 using Tapatalk |
| The Following User Says Thank You to ajc209 For This Useful Post: | FRS Justin (12-14-2015) |
#67 | |
I think its obvious who knows what. on this forum 300hp n/a man. Do the research and you will see what I have built and what I have done. I m sure you do ok doing what you do but your definitely no front runner.
Facebook FT86PROJECT9S 710whp |
#68 | |
#69 | ||
![]() As to the rest of the thread.
#70 |
Drives: Crystal Black BRZ(Sophia)
I read this thread when there were no replies and I thought good please let it die. Now four pages later I find people being trolled. Let it die the information he is proving is not accurate and we all know this.
| The Following User Says Thank You to Yoda For This Useful Post: | 86 South Africa (12-15-2015) |
| Tags |
| kill brain cells, not facts |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 74 | 05-07-2025 04:28 AM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
| Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
