Old 08-02-2013, 04:50 PM   #57
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by l0aded View Post
Which pin do you go into though? The one in the AV Hidden Menu guide won't work for Zypr.
No I mean literally use the front port or tap into it from right behind
lbroskee is offline   Reply With Quote
Old 08-03-2013, 02:35 AM   #58
lbroskee
lbroskee's Avatar
Originally Posted by post_break View Post
For BeSpoke owners that have Zypher or whatever the hell it's called... just put in a switch and use the backup camera input for Aux.
It won't be super simple but the idea would be to have a switch with some relays. A switch could be mounted for the driver to flip and that would send 12v to the trigger wire on the head unit, it would also swap the RCA input from the backup camera to an RCA cable of your choosing.
Again this isn't rocket science. RCA input sucks and the resolution on the head unit is crap but this would be your only option.
any idea how to hook up the relay and switch? i don't fully understand them
Old 12-14-2015, 12:14 AM   #59
BoneE
Drives: 2013 Whiteout
Will this work on a 2014 FRS. non bespoke. It is a Display radio. I have the AUX. Will that switch to A/V
BoneE is offline   Reply With Quote
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 02:14 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 11:11 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 10:44 PM
FS: Pioneer Premium Upgraded Head Unit (Not-Bespoke, Canadian option) pheoxs Audio/Visual, Electronics, Infotainment, NAV 1 03-22-2013 06:47 AM
I suppose this is an option....for someone. Pscylo Cosmetic Modification (Interior/Exterior/Lighting) 11 06-22-2012 12:34 AM
