Old 12-10-2015, 02:00 PM   #1
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
Fog light Help!
Whats up guys, recently got a set of the winjet fog lights and need some help or advice regarding the wiring. I'm pretty sure getting the bezels and the fog light housing installed wont be too much of a problem, but the wiring on the other hand will pose an issue for me. I have no prior experience wiring, and any help I can get would be greatly appreciated.
- Justin
EDIT: Also forgot to include that I plan on using the ignition wire to power the foglights
TheGuyWithTheFireStorm is offline   Reply With Quote
Old 12-10-2015, 02:49 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
It's pretty straight forward. Positive and a negative.
Hard part is figuring out HOW you want to wire it up. Do you want it on when headlights are on? On it's separate switch?
If you want an OEM look check out this DIY here using the BRZ's headlight stock.
Plenty of threads if you search around to get you an idea.
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
TheGuyWithTheFireStorm (12-10-2015)
Old 12-10-2015, 09:44 PM   #3
Thank you sir! So i checked out the wiring guide in the link you provided, and am a bit confused about which ignition wire i should be using. Would you be able to help me out a bit on that?
Old 12-10-2015, 11:38 PM   #4
86Stella
Drives: 2016 Oceanic Blue
Keep us updated because Im on the same route as you!
86Stella is offline   Reply With Quote
Old 12-11-2015, 11:06 AM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Gist of any wiring application is this.
Fog lights <------- Switch <---Fuse <----- Power Source.
You can wire the power source to anything that provides enough power. Such as another light source, 12v outlets or in this case, hes using the battery.
The fuse is an insurance so it doesn't fry your stuff if things go wrong, the fuse will be the first to pop and when it does the contacts won't connect so the electricity won't "complete" or go through.
The switch is a switch. The off position cuts off the flow of electricity and the on position completes it so the power can flow.
So essentially what he's doing is drawing the power from the battery. As for the ground, he connected it to the existing connector in the ignition. This is so he has the indicator light up on his dash board. If you want to go around that you can connect it to any ground or negative wire/bare steel you want.
TheGuyWithTheFireStorm (12-11-2015)
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly zeal86 Exterior Parts (Aero, Lighting, Etc.) 15 05-29-2016 10:01 PM
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 10:25 AM
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
