Old 05-25-2015, 02:51 PM   #1
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Issues with Diode Dynamics brake as turn signal + reverse light module
Hey, is anyone else having issues with their Diode Dynamics brake light as turn signal module? Since installing mine this spring my LED lights have been acting weird, specifically the front and back turn signals.
For example, both of my front switch-back turn signals will blink on and off constantly while driving (when set to their DRL mode, light stalk one or more clicks), but when I activate the turn signal, they work properly (blink amber.) They will just flick on an off, quite dangerous...so don't even run my car with them on right now right now.
I also was informed by people in my building that my rear turn lights (which are currently the brake lights with the module installed) will just flash on and stay on..only one at a time. No key in the ignition, nothing flipped on.
I am uninstalling my module after work today and pulling out the extra harness that taps into the reverse lights...hoping for the best here.
super late update Removing it solved the problem. Faulty part.
Old 12-09-2015, 02:27 PM   #2
S84kam
S84kam's Avatar
Drives: FBRZS
I had a friend who had this exact same problem. First. We got a professional to do a continuity test on the harness. After we installed it we had the same problem. So we contacted diode dynamics. They sent us another one with a relay. So far so good!
S84kam is offline   Reply With Quote
Old 12-09-2015, 08:38 PM   #3
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
wut. i have the same problem. i thought maybe my switchbacks(also from DD) were maybe bad... guess i'll be reaching out. glad i saw this thread.
phanguy is offline   Reply With Quote
Old 12-10-2015, 04:49 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Glad I was not the only one!
Old 12-10-2015, 05:31 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by swarb View Post
Can I ask if you sent it in for replacement warranty or not? And how long was the warranty? I like their products, but I've seen too many failures to have complete confidence. Part of me thinks they sell low quality products with a warranty to justify the higher price. Would you buy again?
You have to realize you only see failures on a forum where this stuff is normally posted, they warranty everything for 3 years.....
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
SkAsphalt (12-11-2015)
Old 12-10-2015, 07:01 PM   #6
FRSBRZGT86FAN
So did you send it in for warranty and would you buy/use it again?
I don't have the tail as turn module specifically, but I have alot of other stuff and it's 100% worth there customer service and time, instead of asking other people what to do ask @Diode Dynamics themselves:
http://www.diodedynamics.com/store/a...ct-us.htmlwhen
If you login on there site too there's an option in the My Account section to RMA or warranty and order, I've only done it once for a headlight bulb and someone named Nick was totally understanding an sent a replacement in less than 3-4 days...
Old 12-11-2015, 09:18 AM   #7
Diode Dynamics
Diode Dynamics's Avatar
If you are experiencing any issues whatsoever, I encourage you to give our customer service team a call: (314) 205-3033 or send us an email: contact@diodedynamics.com
They are covered by our 3-year limited warranty, and we will help you troubleshoot.
Make sure they are still securely inserted into the factory connectors and that the wiring is intact
Thanks!
Nick C.
John C.
Diode Dynamics
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
FRSBRZGT86FAN (12-11-2015), SkAsphalt (12-11-2015)
Old 12-18-2015, 10:43 AM   #8
phanguy
phanguy's Avatar
Thanks!
Nick C.
I contacted support and after pulling out the Tap as Turn module I confirmed that my switchbacks were the problem.
"Then it sounds like you need to replace those switchbacks unfortunately. "
That's all that was said. No mention of getting a new one sent from you guys or anything like that. Kind of disappointing.
Old 12-18-2015, 12:59 PM   #9
Diode Dynamics
I apologize for the confusion, but they may have been under the impression the switchbacks were purchased from another vendor.
If you purchased them from us, than we will send you warranty replacements
Please give us a call: (314) 205-3033
Thank you,
Nick C.
John C.
Diode Dynamics
Old 12-21-2015, 10:52 AM   #10
phanguy
phanguy's Avatar
Thank you,
Nick C.
"Any purchase made before May of 2014 carried a 1 year warranty. So that does mean this order is unfortunately not covered at this point."
and in a previous e-mail someone told me that the ones I ordered had a known problem. There goes $68. I think I'll try cheap Chinese ones next time.
Old 12-21-2015, 12:29 PM   #11
Diode Dynamics
Please give us a call and allow us to look up your order so we can take care of you: (314) 205-3033
If you are still in the warranty period, we will make sure you receive a warranty replacement set.
I was unclear whether you had purchased from us or another vendor
Thank you,
Nick C.
John C.
Diode Dynamics
Old 12-21-2015, 12:34 PM   #12
phanguy
phanguy's Avatar
Thank you,
Nick C.
Sorry yeah it was purchased from you guys in 2013. I'll be calling shortly. Thanks.
Old 12-21-2015, 12:41 PM   #13
phanguy
phanguy's Avatar
Thank you,
Nick C.
Yep. Still told me that it's out of warranty. Not worth buying another set from a company that tells me in e-mail that they have sold a set with known issues, but want me to buy a new set. Thanks anyway.
Always-On™ Module for Subaru BRZ by Diode Dynamics JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 246 03-31-2025 12:02 AM
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly zeal86 Exterior Parts (Aero, Lighting, Etc.) 15 05-29-2016 10:01 PM
(((SOLD))) FS: Diode Dynamics - Tail as Turn with Backup Module wrb Exterior Parts (Aero, Lighting, Etc.) 0 05-04-2015 06:13 PM
Diode dynamics turn signal bezel blackfireball5 Forced Induction 5 04-13-2014 03:33 AM
