Old 12-09-2015, 07:36 PM   #3081
CSG Mike
CSG Mike's Avatar
Originally Posted by Binary_fission View Post
Anyone with MT could take some pictures of their vacuum lines/tubes and how they are routed. I've installed the kit and everything is intact but car dies when started was told it's most likely vacuum leak/problem. Thanks in advance
Sent from my SM-N910T using Tapatalk
I think you'd be better off posting pictures and see if we see anything unusual
Binary_fission (12-09-2015)
Old 12-09-2015, 07:54 PM   #3082
Binary_fission
Binary_fission's Avatar
Drives: FRS
Car at the friends house, ill post it up tomorow thanks Mike for fast reply
Binary_fission is offline   Reply With Quote
Old 12-09-2015, 08:01 PM   #3083
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Check your MAF sensor orientation.
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 12-09-2015, 08:15 PM   #3084
Binary_fission
Drives: FRS
What do you mean? I thought there's only one way maf sensor will go in......Oh shit now that you mentioned I might have installed tube other way around on which maf sensor gets on. Thanks for advice will check that as well.
But if I did that wouldn't ecu trow a code ?
Old 12-09-2015, 08:17 PM   #3085
ScionOfHorus
Nope. Didn't throw a code for me when I had it the wrong way.
The plug should be pointing towards the front bumper.
The Following 2 Users Say Thank You to ScionOfHorus For This Useful Post:
Binary_fission (12-09-2015), Lonewolf (12-14-2015)
Old 12-09-2015, 08:20 PM   #3086
Binary_fission
Drives: FRS
Man I think that's where I messed up. Thanks man really appreciate it.
The Following 3 Users Say Thank You to Binary_fission For This Useful Post:
Alltezza (12-09-2015), CSG Mike (12-09-2015), ScionOfHorus (12-09-2015)
Old 12-09-2015, 08:27 PM   #3087
ScionOfHorus
I did the same thing :p
Binary_fission (12-09-2015), CSG Mike (12-09-2015)
Old 12-10-2015, 05:16 AM   #3088
Binary_fission
Drives: FRS
Fixed the issue, you were correct maf sensor was placed wrong way.
Thanks everyone for tips and support.
Here's first start
Bramick (12-10-2015), Lonewolf (12-14-2015), ScionOfHorus (12-10-2015)
Old 12-13-2015, 12:55 AM   #3089
Bykov
Drives: 2014 Monogram FR-S Whiteout
If there is anything that this adventure has taught me is that life is short. More on that later though. I have decided that when I get home I will be ordering this kit with the CARB tune. Being compulsive as I am I will order a few extra items with it to have in the garage including extra traction fluid, extra filter, and an extra belt to keep in the trunk. I will go for the JROC as well. I am wondering if the decision was made to clamp the hoses under the intake or if those are still left untouched.
I am also wondering, those that have installed the kit already, how much would an extremely detailed install video help? There's almost no content on this kit out there so I wonder if it's worth making said video(s) for those that are thinking of purchasing the kit with all the lessons learned on this thread incorporated (such as installing the MAF housing backwards) for those unwilling to read every single page as I have. If there is enough interest I may do it at a major inconvenience to me because I am not a you-tuber and this would likely prolong my install from one to three days not to mention all the editing and voice over time. Also the wife will not enjoy keeping her Subaru outside for three days while I fool about HA! I do understand the instructions are some of the best of any FI kit so I am already leaning against it.
Future plans include a full 2.5 inch exhaust with a single high flow cat and the Delicious BTFF kit but that's when I move to Oregon and don't have to deal with those pesky smog laws. The rest of my build isn't relevant here except one question I have; how will the CARB tune take a light weight flywheel? I am looking at the ACT setup CSG is very fond of (HDSS). I know with the right tune drivability is not effected but I may want it while I am still in Utah and on the CARB tune. I will be going with the slightly heavier option which I believe is 11.8 lb. If it just isn't practical on the CARB tune then is there even any drawback of the 10.5 lb FW vs. the 11.8 lb with accompanying tune?
Thank you in advance for everything on this thread already as I have read every single page and there are many of you that have made this a quality thread to read packed full of answers to questions I had not even thought of. This is my first post and I seriously hope the clutch question has not been asked yet though I am sure it hasn't.
Bykov is offline   Reply With Quote
The Following User Says Thank You to Bykov For This Useful Post:
CSG Mike (12-14-2015)
Old 12-13-2015, 01:37 PM   #3090
CSG David
CSG David's Avatar
Instructions are easy to follow.
Clutch/flywheel has no issues on a CARB setup. It can take the power no problem. HDSS is fine. We use XTSS and the 10.5lb flywheel with absolutely no driveability issues. We also spend hours in traffic every day so I don't think it's an issue.
Old 12-13-2015, 04:58 PM   #3091
Bykov
Right, that makes sense with the amount of power you are putting down. The reason I ask is because I know with the delicious tune there are issues with the light weight flywheel, or so the site leads me to believe with that being stated in the tune's description, but I also understand the tunes are very different. It's good to know I can make the upgrade with the CARB tune and not worry about suffering from poor drivability. Thank you for your quick response.
Old 12-13-2015, 06:38 PM   #3092
byun
byun's Avatar
Drives: 2015 BRZ CWP
Just ordered a kit last Thursday, can't wait to join the club!
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
Binary_fission (12-13-2015)
Old 12-14-2015, 02:41 AM   #3093
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Checked the contents of my package. Bought the kit from ft86speedfactory. Found this...
So I opened it and...
Looks like the rotrex traction oil leaked during transit. The install supposedly would need the contents of a full bottle. Thoughts? I already contacted Jackson Racing about this....I have an appointment for the install on Saturday 12/19/15.
SHWNBRZ is offline   Reply With Quote
The Following User Says Thank You to SHWNBRZ For This Useful Post:
Binary_fission (12-14-2015)
Old 12-14-2015, 10:56 AM   #3094
ScionOfHorus
eh, it doesn't quite take the full bottle. You should be fine. Just order another bottle off of amazon to keep it topped up.
The Following User Says Thank You to ScionOfHorus For This Useful Post:
SHWNBRZ (12-14-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
