Drives: Ultramarine FRS mt
FRS aftermarket head unit installation - wiring
I apologize in advance if already talked about, but I r search not grood.
Imo bespoke is overpriced and going aftermarket, already have a couple in mind, but open to some suggestions as long as it doesnt thread jack. What I really want to know is the about wiring up an aftermarket head unit. I maybe jumping the gun, but any plug up harnesses work or maybe a universal type? I really want to avoid any hard wiring/cutting this early. |
#2 | |
Drives: 2013 BRZ Limited DGM MT
My Car Journal Thread: The GreyRZ Build
#3 |
Drives: Gray
I'm planning to install a new headunit in the next couple of days. I pulled out the factory headunit. It looks like the harness is a regular toyota one on the left. All the way to the right looks like the antenna plug. Is this a subaru antenna?
![]() Heres a pic of the antenna male plug. There's 2 identical plug. On the left was plugged into the head unit and both ones I'm holding was not used by the factory headunit.
| The Following 4 Users Say Thank You to keithbribac For This Useful Post: |
#4 |
Drives: 2013 Firestorm Scion FR-S
I installed a new head unit already. I used the regular toyota harness and it worked just fine. Be sure to hook up the remote/power antenna wire because it turns on the amplifier in the trunk that runs the door speakers. I forgot to hook this wire up and the stereo sounded horrible.
The antenna adaptor is for 02+ Lexus. The exact model I used was Scosche LSAAB. The dash kit is a different story. I used the Metra dash kit for a Scion TC, but I had to modify it quite a bit. I just used a dremel tool to trim the kit until it fit on the FR-S bracket. It works quite well now. |
| The Following 4 Users Say Thank You to Nitro For This Useful Post: |
#5 |
Drives: Gray
where do u hook up the remote/power wire? to the toyota harness, lexus harness, or to the cars wiring? and why does the lexus harness have two plugs?
#6 | |
I don't know why the lexus harness had 2 plugs, but I only used 1. |
#7 | |
That Guy
Drives: 2013 asphalt FRS MT
#8 |
Drives: Gray
here's mine
![]() and another one
| The Following 2 Users Say Thank You to keithbribac For This Useful Post: | Liquidsnake (06-21-2012), normancw (06-07-2012) |
#9 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
8400? Looks great. This is the deck I'm going with if/when I decide to replace the stock deck in the BRZ.
#10 |
Drives: Firestorm FRS
RCAs? Interesting.
#11 |
FRS Rear Mount Turbo
Drives: 2013 FR-S Raven, Rear Turbo
Hi, I would like to pull my radio out of my FRS and was wondering if I may ask for the correct way to do it as not to destroy anything? Do I need any special tools? Thanks in advance.
#12 |
Drives: 2013 FR-S, 6MT, Ultramarine
#13 |
To remove your headunit, try this:
Using a pry tool (I like plastic ones), pull the bottom slightly out Now, the hard part is carefully wiggling the panel straight out from the radio. There are 4 clips: 2 on top, 2 on bottom. It's hard to get pry tools in the top, so be patient. Try and pull out, but firmly. DO NOT pull on an angle!! Once the panel is removed, you'll see this: You should know what to do from this point on. Last edited by Lil Abner; 06-17-2012 at 07:44 AM. Reason: Spelling |
| The Following 13 Users Say Thank You to Lil Abner For This Useful Post: | 4Running Daily (06-06-2013), Bonburner (01-11-2013), buzznasa (06-29-2013), calis5nest (01-29-2014), dsgerbc (06-09-2012), encity5 (06-10-2012), Fly Guy (06-09-2012), Kamakanani0 (10-03-2012), Liquidsnake (06-21-2012), lordtakuban (07-18-2012), Roadstercycle (06-17-2012), SubaruOnlineParts.com (08-02-2012), SVXdc (07-02-2012) |
#14 |
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
EDIT: sorry should have said does the stock voice command run through the head unit or will you have to use a separate mic for that?
| BRZ NAV unit play DVDs when in park? | Mango22 | Electronics | Audio | NAV | Infotainment | 15 | 09-06-2013 02:28 PM |
| TRD parts installation manual | Nardi330 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 05-21-2012 03:19 AM |
| chrome fender trim installation | taosracer | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-15-2012 03:13 PM |
| BRZ Nav Unit owner's manuals | eikond | Electronics | Audio | NAV | Infotainment | 0 | 04-11-2012 04:07 PM |
| Removal of Radio/Infotainment Unit | Captain Snooze | Electronics | Audio | NAV | Infotainment | 6 | 03-20-2012 07:46 AM |
