Old 12-06-2015, 11:41 PM   #85
churchx
churchx's Avatar
Drives: 2014 GT86
Cybmx: sprint has different sized pads (for example - much thicker). As sprint front BBK is braking bias-matched to stock rears, imho better to install same compound pads on all corners, - stock sized in rear, - this kit sized in front. You may use different compound pads in rear, but it will certainly change brake bias, so imho better not. As it's mostly front that does most of braking, rear pads need to be exchanged way less often. For fronts you'll really enjoy cheaper pad prices and thickness of chosen pad sizing that will let pads last longer.
Old 12-07-2015, 10:44 AM   #86
Cybmx
Drives: 2016 Hyperblue Brz
You should be using the same pad compound front and rear. We have plenty of options
Thanks guys. I have the sprint kit with a few set of AP c300 pads, where should I go to purchase the matching pads for the rears?
Cybmx is offline   Reply With Quote
Old 12-07-2015, 12:12 PM   #87
CSG Mike
CSG Mike's Avatar
Unfortunately that compound is not available in a FRS/BRZ oem rear...
Old 12-07-2015, 01:49 PM   #88
Cybmx
Would you be able to recommend me an alternative? Thanks a whole bunch.
Old 12-07-2015, 06:14 PM   #89
CSG Mike
CSG Mike's Avatar
Unfortunately I'm not aware of any compounds that are directly comparable to the C300 that could be used as an alternative in the rear.
The Carbotech RP2 is somewhat similar, but has a bit more bite.
Old 06-18-2016, 04:42 PM   #90
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@CSG Mike @JRitt do you guys find that the caliper grabs the rotors pretty hard on fresh pads? I've done one track day on a new set of ds1.11 and my alignment guy (who races) made a comment that my fronts might need a rebuild given how tight they were grabbing and that the piston seals might be cooked. I'm skeptical since I've only really done perhaps 6 track days on the brakes... Although they were tough to push in when swapping the new pads in
Sent from my SM-N920W8 using Tapatalk
1Cor10:23 is offline   Reply With Quote
Old 06-18-2016, 10:58 PM   #91
CSG Mike
CSG Mike's Avatar
It's unlikely but possible, depending on your operating conditions.
For the guys that drive the car year round and weekend warrior the car, I usually recommend servicing the calipers once a year.
This is how much we like our AP Racing/Essex "Sprint" BBK... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-06-2013 11:30 AM
Question about Long-Term "Garaging" arleewa BRZ First-Gen (2012+) — General Topics 25 01-12-2013 09:13 PM
Some FR-S "news" (pricing update) Sport-Tech CANADA 19 03-24-2012 10:31 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
