Old 12-03-2015, 10:55 AM   #15
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Jayvelliott View Post
Moto,
I'm unsure if you have any knowledge or experiences with the two but how do you think this Kit compares to the JDL and FBM kit?
Pro's/Con's so far about this kit? Did you have to modify the crash beam for this install?
Side note: I do like how the IC pipe is positioned over the cool side of the turbo..looks very nice.
This is a hard question to answer but I think for most folks you need to look at what you get with the kit vs the price you pay, and people's general experience with it. Find out from people who have the kit.
Originally Posted by xsnapshot View Post
Do you think the bent rods here are a result of so much low end torque from the 335 blower?
I know you only had 276whp up top, but my guess is you were pushing at least that much in torque fairly low in the rev range as well.
Additionally, would you venture to say that a centrifugal setup that makes that same hp up top would be safer for the engine, as lower RPM torque is less?
We've made some mention about what our thoughts are here in other threads, but generally we don't recommend running for a prolonged period of time on pump gas at high loads and boost > 14 psi. That goes for any setup.
Inlet temps of 160 F are not that unusual on a high boost SC setup. When you do that for a prolonged period of time then the chance of knock goes up substantially, and there's nothing you can really do from a tuning standpoint to fix that. Just lower compression and better cooling or e85. At less than 12 psi it is not a big deal, but with the 19 psi the 335 was doing, that was a lot to ask from the stock motor and pump gas.
Xero-Limit is offline
Old 12-06-2015, 04:24 PM   #16
-Phil
Drives: Rb25 neo brz
Updated pictures apologies to those who didn't like seeing it on the dyno without anything on it heh
-Phil is offline
Old 12-07-2015, 02:09 AM   #17
BobbyBlue86
BobbyBlue86's Avatar
Drives: Subaru BRZ
Is it the crank case breathers that are making that high pitched sound?
BobbyBlue86 is offline
Old 12-07-2015, 07:00 AM   #18
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Is that 3" or 4" piping for the air filter? I'm curious because my GTX3076R has a 4" filter and I would like to relocate it for some colder air.
crazyfrenchbiker is offline
Old 12-07-2015, 09:11 AM   #19
-Phil
The piping is 3". the location of the filter there is fairly ideal.
-Phil is offline
Old 12-07-2015, 09:12 AM   #20
-Phil
Mike thinks its the breathers, I think It's the turbo so we'll say its a combination of both. the catch cans seem to act like resonators.
-Phil is offline
Old 12-07-2015, 09:36 AM   #21
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
You can clearly see steam or oil vapor or something coming from the breathers on top of the catch cans.
Is it normal to get that much pressure coming out of the crankcase to make the catch can breathers sing like that under boost? Makes me wonder if there is significant blowby in the cylinders allowing the crankcase to pressurize.
ATL BRZ is offline
Old 12-07-2015, 03:41 PM   #22
Xero-Limit
Xero-Limit's Avatar
The motor was freshly built and not quite broken in, but with an open PCV system such as this you'll always get some blow-by coming out of the filters since it isn't recirculated. With built motors that are designed for race use you need to leave the ring gaps a bit wider than factory, so expect to see a bit of vapor when using open cans.
Old 12-09-2015, 05:02 AM   #23
crazyfrenchbiker
Hot Lava 6MT
So you're running a reducer on the turbo? What's a bigger benefit, smaller piping with colder air, or larger piping with warmer air?
Old 12-09-2015, 09:13 AM   #24
mrk1
Drives: Sterling BRZ Ltd
Your turbo may have a 4" cover on it but not all 4" are actual intake. Look inside the center circle is probably something like 2.75" the surrounding area is anti-surge ports. So reducing down to a 3" pipe really is no harm, unless we are talking real big HP.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline
Old 12-09-2015, 09:37 AM   #25
-Phil
Mrk1 is correct the piping being 3 Inch wont hurt anything, so having the pipe routing to a colder area while keeping the 3 inch diameter works the best for our purposes if need be we have the room to change the pipe and make it into a 4" though.
-Phil is offline
Old 02-10-2016, 04:36 PM   #26
-Phil
Big Update here thanks to @RCEengineering @mapPerformance @moto-east and @streetfaction
Streetfaction Chassis mount
RCE tarmac 2's 11k rear 10k front
Racseng front Camber plates
We will be planning to Track the car as frequently as possible this upcoming season, One of the biggest modifications we are doing that is not seen here is a PAR gearset and our front aero setup
Please excuse the cleanliness of the vehicle hah
-Phil is offline
Old 02-19-2016, 12:28 PM   #27
-Phil
Today we added a set of Velox LCA's aswell as a set of Velox Toe Control arms and to finish it off a whiteline 18mm rear sway bar with links and braces
-Phil is offline
Old 02-19-2016, 12:56 PM   #28
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
The first rocket bunny car I have seen that actually has a shot at being tracked, lol.
Been a fan of the motor and suspension plans since the beginning.
Summerwolf is offline
Moto-East tuning post_break User/Vendor/Sponsor Reviews, Feedback, Comments 10 10-25-2016 03:57 PM
Caravan to Moto-East from NYC LI Liquid6 NY / NJ / CT / PA 10 05-04-2015 08:38 PM
Moto East Bluetail User/Vendor/Sponsor Reviews, Feedback, Comments 1 01-25-2015 08:12 PM
Moto-East (Moto Mike) Review Thread ecko04 User/Vendor/Sponsor Reviews, Feedback, Comments 4 05-22-2014 06:57 PM
GReddy Turbo Kit Now Available at Moto-East! Xero-Limit Forced Induction 1 12-27-2013 01:20 PM
