Old 12-06-2015, 09:49 AM   #1
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
car cover recommendation?
anyone here keep their BRZ/FRS outside during the snowy winter? i have always kept mine in a garage, and driven a winter beater. that however means scraping off ice every morning and starting the engine 10 mins early to warm up. not really a problem, but if there's a good car cover you guys can recommend, i give the garage spot to the winter beater and keep the BRZ outside.
any input, good or bad, on car covers tried would be appreciated.
lionbacker54 is offline   Reply With Quote
Old 12-06-2015, 09:50 AM   #2
lionbacker54
The Following User Says Thank You to lionbacker54 For This Useful Post:
Dreyup (12-09-2015)
Old 12-06-2015, 10:48 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
In before you search hahaha!! Also no need to make 2 threads in 2 sections
Okay I do not recommend a cover unless you don't mind damaging your paint. A car cover should really only be used if the car is going to be stored in garage for more than 6 months and the cover will not be coming off once in that time.Your car will be dirty and taking off and putting on the cover will rub the dirt into the paint and ruin it. You should just leave your car on the street uncovered.
Old 12-06-2015, 10:51 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
No need to double post, I responded on your other post.
Old 12-06-2015, 10:59 AM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
I agree, as I have used a variety of covers for external use with mixed results. Good during the summer months if you keep the paint work spotless however winter months a pain in the neck. Condensation and the wind play havoc leading to all sorts of damage to the paint.
Old 12-06-2015, 11:01 AM   #6
stevesnj
stevesnj's Avatar
Why not just wash your car before putting the cover on?
My 2016 Build thread
Old 12-06-2015, 11:03 AM   #7
Cole
Not a troll
Cole's Avatar
Have you ever driven a car in the winter time? Especially a winter in Western Canada? There's so much shit on the road in the winter months, it's near impossible to keep your car clean for 30 seconds after you come out of a touchless wash.
Cole is offline   Reply With Quote
Old 12-06-2015, 11:03 AM   #8
stevesnj
stevesnj's Avatar
Just got this cover from Coverking Based on research and user input of this specific cover. I feel confident it will work as intended
http://www.ft86club.com/forums/showp...&postcount=188
Old 12-06-2015, 11:07 AM   #9
stevesnj
stevesnj's Avatar
I'm from NJ I know salt and it's effect. I find a way to keep my vehicles clean during the winter. It's a pain but i'd rather take the chance of a few scratches that can be polished out than salt and dirt sitting on the paint and under the chassis. I take it to a DIY car wash close by. Any stuff I get on the car on the way home is easily cleaned off before I would put a cover on. It's not that difficult.
Old 12-06-2015, 11:09 AM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Ita still gona get dirty if its outside. Op will also need to remove cover to start car once a month in winter then reinstall it
Old 12-06-2015, 11:09 AM   #11
Cole
Not a troll
Cole's Avatar
lol k. What is salt going to do to a zinc plated and painted metal structure? Not much.
The amount of effort that people go through to maintain their economy cars is hilarious.
Old 12-06-2015, 11:19 AM   #12
stevesnj
stevesnj's Avatar
Rust
Old 12-06-2015, 11:21 AM   #13
stevesnj
stevesnj's Avatar
True, but it would be significantly less than if left uncovered I would think.
Old 12-06-2015, 11:21 AM   #14
Cole
Not a troll
Cole's Avatar
Rust
Uhm, nope. Zinc plating and paint significantly reduce the possibility of corrosion.
Source: I'm a corrosion technician, and work on structures far more likely to corrode than a car. One of the best methods for stopping corrosion? Putting a coating on a structure.
High quality outdoor car cover recommendation? qqzj Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 03-29-2016 09:27 PM
WTB: Trunk carpet, cover, spare tire, tools, foams, latch trim/cover Izzy Want-To-Buy Requests 7 06-27-2015 06:38 PM
1of86 limited cover. Indoor cover mint condition SpecPer Cleaning and Detailing 0 06-06-2015 08:17 PM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
The cover store car cover for sale. FRSfan111 Northwest 2 06-21-2013 04:49 PM
