Old 11-04-2015, 03:25 PM   #2479
yo.dur
Drives: 2013 Scion FRS
Yeah i figured as much. I was doubting that placement of using the brake booster line under the manifold, but ill use it for now. Will look into those options. Thanks for the input!
yo.dur is offline   Reply With Quote
Old 11-09-2015, 06:06 PM   #2480
yo.dur
Anyone know why these CEL codes are thrown?
P2122 Throttle / Pedal Position Sensor / Switch "D" Circuit Low Input
P2127 Throttle / Pedal Position Sensor / Switch "E" Circuit Low Input
Car holds consistent boost and runs absolutely fine, but i have to clear these codes every time I start the car because it starts in limp mode. Once those DTCs are cleared everything is fine. Map sensor is scaled properly.
Old 11-10-2015, 10:17 AM   #2481
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Pedal position shouldn't have anything to do with the MAP sensor. Are you sure that your connector on the throttle body is properly connected and none of those wires are damaged?
Old 11-10-2015, 04:46 PM   #2482
yo.dur
Throttle body connector is firmly clipped in and none of the wires are damaged leading upto the connector.
Old 11-12-2015, 11:51 AM   #2483
mike the snake
It's been a while because I sold my car a while back. Mainly because I spent 18K on mods and labor, shooting for 350hp, and went with a shop that had not tuned any 86's before.
I ordered the GTX2867r Premium kit, titanium exhaust, big clutch, Element Tuning Hydra Standalone ECU, meth injection, bigger injectors, bigger radiator (moved forward for extra clearance), the works, it took 4.5 months to get my car back from this shop.
When they were done, I got a whopping 280WHP on their Mustang Dyno. I was bummed to say the least.
All the while, Full Blown was there with the best customer service, got me a new rebuilt turbo after the shop incorrectly installed it originally, leaving it with no water flowing through it. They said it was installer error (usually not covered), but replaced it anyways because FB was such a good customer.
I sold the car to a guy in Indiana. He took up Phil at Element Tuning's offer to fly in and tune the car himself.
Without touching ANYTHING, Phil was able to get another extra 86 HP out of my car with just a proper tune.
If my car had been tuned originally correctly, I'd probably still own it, I'm glad the new owner now has the power that I built the car to make.
Both Full Blown, and Element Tuning's Hydra Standalone are great products. If I had to do it again, I'd probably still go with Full Blown for the turbo kit.
Since so many shops tune with Ecutek, and it now supports meth injection, I'd probably opt for that, unless I was going racing. Then Element's Hydra Standalone would probably be a better application.
I just wanted to put a shout out to Full Blown, and Element Tuning for the GREAT customer service, and also to warn people to get their car tuned by someone who knows our cars, and has tuned many of them.
My car was this shop's first 86, and it showed.
The Following User Says Thank You to mike the snake For This Useful Post:
Darryljr11 (11-14-2015)
Old 11-13-2015, 09:24 AM   #2484
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I just want to echo this statement. The FA20 is not your average run of the mill motor. It is a high compression direct injected motor. It is not a Honda B, K, F series motor. It is not an LS motor. It is not a 2JZ motor. It is definitely not an EJ25 motor. There are a few good reliable FA20 tuning shops out there. Spend the money and take your car there for a tune. Don't waste the money you invested in a turbo kit by running on a basemap or some crappy shops idea of a "custom" tune.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
alvinrenz (12-04-2015), blackfireball5 (11-13-2015)
Old 12-04-2015, 10:40 PM   #2485
alvinrenz
Drives: firestorm 2015
hello everyone, I have been reading this thread for a couple of days, Im at pg 30 already lol.
I am in the market of buying this kit. and aiming for the stage 1 base kit with gtx30.
budget is tight at the moment,saving up for more, can I skip the BOOST CONTROLLER and DM6 WIDEBAND and get it next time? should i get the ceramic coating?
I cant wait to be part of FBM user soon cheers!
alvinrenz is offline   Reply With Quote
Old 12-04-2015, 11:14 PM   #2486
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
What act clutch do you guys recommend? My stock clutch is slipping after a two days being boosted. Is the act hdss enough? It says 270tq, I'm assuming its better to have a strong clutch than pushing the clutch to the limit?
fbm stage 1 kit. gtx2867. 7-10 psi
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 12-05-2015, 09:36 PM   #2487
Frs300
Frs300's Avatar
Drives: Pile of junk
6 puck hd/xt...im using the hd with 420wtq
Frs300 is offline   Reply With Quote
Old 12-05-2015, 10:58 PM   #2488
FRS Johnny
FRS Johnny's Avatar
I won't even be close to 420 tq :o How is it tho? Do you drive it on the streets daily or is it just as a fun car on the weekends.
Old 12-07-2015, 03:22 PM   #2489
mashal
DADA
mashal's Avatar
Drives: 2013
Question for all those running the oil catch can, what was used as a plug for the bottom drain? I'm assuming the shop forgot to put it back in because now I am getting some oil on the firewall/battery area and its from the catch can drain
mashal is offline   Reply With Quote
Old 12-14-2015, 12:36 PM   #2490
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
took it to willow springs yesturday
thanks for the reliable turbo!
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 12-14-2015, 09:07 PM   #2491
FRS Johnny
FRS Johnny's Avatar
I would use a small filter just so nothing gets sucked in. I used a catch can that vents to atmosphere.
Old 12-15-2015, 12:27 AM   #2492
mashal
DADA
mashal's Avatar
Drives: 2013
The FBM design is vta too, but I thought the bottom end would be plugged
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
