Old 06-07-2012, 05:03 PM   #1
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Rattling in 2nd or 3rd at low rpms
Just like a new parent, I think I've been extra sensitive about every little noise my car makes. I've noticed that when ever I'm in 2nd or sometimes 3rd, at low rpms (around 2-2.5k) I hear and feel a little rattle in the transmission, like something is loose and shaking around in there. I would guess that the gear isn't quite engaged, since I notice the same noise in my old civic when I don't get 1st in all the way. As I get up around 3k rpm, the noise slowly disappears. I'll be calling the service dept. of my dealer later today, but if anybody has some input, it will be well appreciated!
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
Flako (09-03-2013), kgc (10-22-2012)
Old 06-07-2012, 05:11 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Next time it happens, place your fingers on the reverse lockout ring and see if it goes away. Rattles coming from that ring are common in 6mt Subarus at low revs.
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
BigFatFlip (06-07-2012), blu_ (06-07-2012), Roadliner (04-13-2014)
Old 06-07-2012, 05:48 PM   #3
MTeator
First 86
Mine does it too, sounds like an old truck.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-07-2012, 05:51 PM   #4
vividracing
vividracing's Avatar
How much load are you trying to put on the engine at those RPMs in those gears? Low speed, high load situations aren't good for any car.
vividracing is offline   Reply With Quote
The Following 2 Users Say Thank You to vividracing For This Useful Post:
Roadliner (04-13-2014), usptwins (01-09-2013)
Old 06-07-2012, 06:09 PM   #5
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Speaking of, I always catch myself 'playing' with that ring when my hand is on the shifter. Not trying to pull it up, but just fidgeting. I know I can't be the only one... right?
I'm used to reverse gear being to the right and down of 6th, so this is somewhat new to me, but I like the placement more. Makes it easier to switch between 1 and R. Also like how the gear indicator shows R with a nice bold border, stands out!
eriktherod is offline   Reply With Quote
Old 06-07-2012, 06:15 PM   #6
BigFatFlip
BigFatFlip's Avatar
Not very much. I usually notice it driving around during slow city driving, right after shifting up from 1st after starting from a stop, like at a light or something.
Old 06-07-2012, 06:24 PM   #7
vividracing
Hmm, sounds like you're driving her right then. Have you ever heard clutch chatter? Sounds like what you're experiencing. If it's not the ring like others mentioned, I bet it's clutch chatter. I don't remember if our car had it stock... We've got the Clutch Masters clutch and flywheel in there now.
The Following User Says Thank You to vividracing For This Useful Post:
Old 06-07-2012, 06:28 PM   #8
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Its most likely this. It can be very common and sounds exactly like the OP described.
blu_ is offline   Reply With Quote
Old 06-07-2012, 08:30 PM   #9
Zoomie
Drives: VW R32
Somewhere, on one of the sites I thought I read a service bulletin or something-of-the-sort that if customers complained of this to change to a different lubricant. I cannot for the life of me remember where I read this...
I think they also mentioned something about giving it to Zoomie so he could test thrash it for you also!
Zoomie is offline   Reply With Quote
Old 06-10-2012, 07:05 AM   #10
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
My car makes this noise under the correct circumstances. It's nothing that concerns me at this point. Sounds quite normal for the type of transmission.
The noise is from the transmission, not the reverse lock. It happens when traveling slowly at a load level that is almost lugging the engine.
I hope this noise doesn't become another BS warranty thing like what happened to the V160.... I'm sure that made Toyota upset.
Ishii
Ishii Motors is offline   Reply With Quote
The Following 3 Users Say Thank You to Ishii Motors For This Useful Post:
BigFatFlip (06-11-2012), Hawaiian (06-11-2012), meeks (07-24-2012)
Old 06-10-2012, 10:30 AM   #11
FakeWhiteMan
Back From The Dead
Drives: Hot Lava FR-S
Send a message via AIM to FakeWhiteMan
Nope, I'm always playing with mine.
FakeWhiteMan is offline   Reply With Quote
Old 06-10-2012, 07:00 PM   #12
DragonPunch86
Drives: 2013 Subaru BRZ
I have this experience when I'm going too slow at a gear in which the car seems less comfortable in. I never imagined it being any sort of mechanical issue but more of just learning the car's behavior.
DragonPunch86 is offline   Reply With Quote
Old 06-11-2012, 06:37 AM   #13
Staticfrost
Drives: Eight Six
Let us know what the service people tell you :S.
Staticfrost is offline   Reply With Quote
Old 06-11-2012, 11:41 AM   #14
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Ishii
This!
I get the same thing when I up shift too early in the city. I just figure it's the car telling me to rev it more next time.
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
zoth (06-23-2015)
RPMS!! Spencer Strayer Engine, Exhaust, Transmission 82 09-15-2011 10:51 AM
