Sam Strano
Old 11-18-2015, 10:40 PM   #3837
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by ryan t View Post
in my last 2 events ive had a rider with me and noticed my faster times were with the rider as opposed to just i. ive not yet corner balanced my car to see if the weight evens it out or what. any opinions from those that have run back to back with a rider.
Always slower with a passenger, especially in light weight, low power cars like these.
justinco is offline   Reply With Quote
Old 11-19-2015, 10:55 AM   #3838
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
A passenger costs me ~3 tenths on a 50 second course in my GTI which runs about the same sort of times as my local hotshoes in C Street, fairly consistently. I'm not a very consistent driver, but it's pretty clear that a passenger adds quite a bit of dead weight that might balance the car (I doubt it) but certainly hurts overall performance.
FWIW on a road course a passenger made a VERY noticeable difference in acceleration when I was following another 86. The other 86 would pull on me a little down low even with his stock header/tune while I have a JDL UEL/tuned.
Old 11-19-2015, 01:06 PM   #3839
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Passenger = 2-4 tenths depending on course and acceleration points. If your passenger is a good instructor they can save you some time, though, if they're calling out braking points, etc. (if that's what you need, at least). Every pound you bring into one of these cars in C-Street form is a killer.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 11-19-2015, 01:33 PM   #3840
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Passenger could also have a psychological effect. I know I picked up some time when my gf rode along because I focused on being smooth.
ineedyourdiddly
Old 11-19-2015, 02:27 PM   #3841
ryan t
Drives: frs
i know lighter is better, the only thing it might be was the cold. these last 2 were 30-40 degrees. the last being the coldest, and i noticed the majority of cars had a rider with them. i would say 1/4 were driver only. there was even a bmw with a 3rd sitting in middle of back seat. could the extra ballast help in the cold/slick?
ryan t is offline   Reply With Quote
Old 11-19-2015, 02:28 PM   #3842
ryan t
Drives: frs
if its not the cold than you may be the correct one. lol
The Following User Says Thank You to ryan t For This Useful Post:
strat61caster (11-19-2015)
Old 11-19-2015, 02:55 PM   #3843
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Psychological. The car without a passenger is going to be faster if driven consistently. I almost always drive my fastest runs with a passengers but that is because I am still super inconsistent and not using 100% of the performance the car has to offer. Hence why I don't have a National trophy yet.
DylanFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to DylanFRS For This Useful Post:
jbailey8748 (11-27-2015), strat61caster (11-19-2015)
Old 11-19-2015, 03:19 PM   #3844
DylanFRS
Lost in Kansas
DylanFRS's Avatar
So anyone see the 2016 PAX?
http://solotime.info/pax/rtp2016.html
Looks like CS took a pretty decent hit, even relative to everyone else>
I don't really understand since the top CS finisher at Nationals was 134th in the PAX standings.
Old 11-27-2015, 03:53 PM   #3845
Biggins
Drives: Yes
My theory is that too many of us did well locally and upset people who run in a PAX class?
I can't believe BS and GS stayed the same and FS didn't take as much of a hit... oh well.
Biggins is offline   Reply With Quote
Old 11-28-2015, 12:56 AM   #3846
renfield90
The Stig's German cousin
I discovered my front left left hub hasn't been securely mounted to the control arm for about a year. 2x top index like that. Don't tell Rick Ruth or he'll fix the index even more!
We were a little soft this year I thought. It's only a 3 tenths bump. Most street classes took a hit due to the Bridgestone/BFG effect.
What I'm unhappy with is SS unchanged, might as well call it Super Soft. There is a C7 Z06 locally that has been destroying us on anything but a tight twisty course. Sure, it's well driven, but it's also on the factory run flats.
Old 12-04-2015, 02:29 PM   #3847
simpleisbest
Senior Citizen
Drives: Scion FR-S
Well....here is the proof. The Koni full strut replacements appear to be illegal for Street Class.
The Koni strut's upper mounting holes are both symmetrical in size at roughly 16.3mm, OEM has 14mm on brake hose bracket side and 16.3mm on the other. This +2mm difference in diameter of the one hole gives the mounting bolt another millimeter or so of allowance, THUS the additional negative camber claimed by many on this forum.
If you examine the picture of the OEM 14mm crash bolt, you can easily imagine how the extra 2mm in diameter would help get more camber!
Luckily, with a simple machined spacer it should be easy to bring in these shocks back to legal compliance without much headache or costs.
Unfortunately, the measurements done by members in the past on this forum did not measure BOTH upper mounting holes. If they did, the difference would have been pretty obvious. I think as the Koni used the same size holes on both sides, it might have been mistakenly thought that OEM was similarly so.
simpleisbest is offline   Reply With Quote
The Following 5 Users Say Thank You to simpleisbest For This Useful Post:
Briankbot (12-04-2015), doggieboy09 (12-09-2015), Jawnathin (12-04-2015), Laloosh (12-09-2015), swarb (12-04-2015)
Old 12-04-2015, 04:35 PM   #3848
swarb
here is some more info on the koni http://www.apexjunky.com/2015/12/kon...9ZA0I.facebook
Old 12-04-2015, 07:47 PM   #3849
Jawnathin
Drives: Toyobaru FRZ
Thanks for sharing your findings Sean. As many predicted here, something was out of spec with the strut which gave the suspension some additional camber. Just didn't make sense that a car can get more negative camber with just a shock replacement if everything the same as OEM.
Just to be sure the bases are covered before we call them illegal, are there tolerances defined by OEMs that would allow a 14%~ increase in diameter while still considered to be within 'OEM spec'? 14% tolerance sounds REALLY high but just thought it was a question worth raising. I'm sure SCCA will also have an opinion on whether this variance is considered legal or not.
If determined to be illegal I wonder if Koni will have an updated model/model number or if they're going to provide a machined insert to make existing shocks legal.
Jawnathin is offline   Reply With Quote
The Following User Says Thank You to Jawnathin For This Useful Post:
simpleisbest (12-04-2015)
Old 12-04-2015, 07:48 PM   #3850
Locust
Custom User Title
Locust's Avatar
So the real question is for the people that already have these: Are you going to keep them this way and drive them like that next year?
That extra 1° of negative camber in the front makes a decent enough difference.
I'd really hate to see protests getting thrown around all season against people that continue to use the CS illegal version of the Koni's but I also understand how dumb it is to buy something and then have it be confirmed illegal later.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
