Old 11-24-2015, 10:43 AM   #323
Dr Speed
Drives: Red
Time for some Loooooooong Division!!!! #math
Dr Speed is offline   Reply With Quote
Old 11-24-2015, 06:48 PM   #324
celek
Resident Gear Head
celek's Avatar
Did some cleaning and some test fitting.
celek is offline   Reply With Quote
Old 11-29-2015, 08:38 PM   #325
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Keep up the good work Chris. Really excited to see this build coming along.
xkalelx is offline   Reply With Quote
Old 12-02-2015, 02:37 PM   #326
celek
Resident Gear Head
celek's Avatar
Big news.
At SEMA I met some new friends that had some scrap parts laying around. This is inbound, ETA next week.
Base for the Individual throttle bodies.
Old 12-02-2015, 07:52 PM   #327
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
wuuuuuuuuut more info on itbs pleez
cyde01 is offline   Reply With Quote
Old 12-03-2015, 04:10 AM   #328
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
So all this talk of different engines and % changes in hp and crank vs. whp is just cr#p...
And totally missing the point of this build.
I think I've said before that I really admire the work and dedication in this one, and definitely keen to see what the final results will be... so please dudes (in the nicest possible manner) can we cut the rubbish and stop the
for the build - I'm super keen on seeing the final built motor - and just how much the torque curve will be improved (of course the tune will make a big diff once all the physical parts are done too).
Can't remember if you said already... you going to use e85 too?
And thanks for sharing
I like driving!
86 South Africa is offline   Reply With Quote
Old 12-03-2015, 04:57 AM   #329
Snake
Drives: ADM Toyota 86 GT
And even if you don't meet your hp goals, please let us know the outcome. Seems there have been a few NA builds on this platform but no one publishes anything, which is sad!
Snake is offline   Reply With Quote
Old 12-03-2015, 06:07 AM   #330
churchx
churchx's Avatar
Drives: 2014 GT86
86 South Africa: how differs %of whp you complain about vs torque improvement you are asking about?
Or you wrote rather about shape of torque curve, preferably without infamous torque dip? That can be fixed in stock engine too with different aftermarket exhaust headers without any engine itself rebuild, so i hardly see it being among most important objectives of this engine build endeavour.
Old 12-03-2015, 07:20 AM   #331
celek
Resident Gear Head
celek's Avatar
Yes on E85
Old 12-04-2015, 05:12 AM   #332
86 South Africa
I don't know what the "importance" of it is. Depends how you drive I guess.
The torque is one of the negative aspects of the stock engine... so what I am keen on seeing is how much torque the NA build will produce + how the torque curve looks in the end - in other words, instead of bolting on some FI that solves the problem it will be interesting to see how this built motor will deliver it's power.
No measure is perfect, but a % increase is much more comparable because it negates much of the actual hp numbers people quote. 10% is 10% whereas 10hp is ? If you had 500hp to begin with then 10hp isn't much - but if you only had 20, then 10 is great.
Also different dyno's read differently + each car will have slight differences (even on the same dyno)... so therefore the obsession with hp numbers is silly. So what motor can/can't make "200hp" for e.g. is a silly comparison. That's all.
I like driving!
Old 12-05-2015, 06:07 AM   #333
Traktor
Drives: Subaru BRZ Limited
I'm not sure the torque curve is the point of this build? The intent is to rev to 9000rpm and the only way to make NA power up there will be more lift via cams. The motor doesn't have variable lift unlike a VTEC so you'd expect the bottom end of the curve to suffer as a result.
I am very interested to see what happens with that inlet setup. Keep the posts coming celek!
Traktor is offline   Reply With Quote
Old 12-07-2015, 04:26 PM   #334
celek
Resident Gear Head
celek's Avatar
Another part arrives
Old 12-08-2015, 11:45 AM   #335
sato
sato's Avatar
Drives: Dodge Patitas
Supercharger manifold?
Sent using tapatalk
sato is offline   Reply With Quote
Old 12-08-2015, 11:54 AM   #336
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
What are you planning to do with that? I sense a lot of melting aluminum in your near future.
Intent > Content
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
