Old 11-25-2015, 11:46 AM   #6707
iLLDYNASTi
iLLDYNASTi's Avatar
Drives: 2013 DGM BRZ
So I was told by Zach at Delicious Tuning that the vacuum actuator orientation could effect the AFR on the car. Any one know how it's supposed to be oriented?
Sent from my SM-G900V using Tapatalk
"Don't ask me...I just work here"
iLLDYNASTi is offline   Reply With Quote
Old 11-25-2015, 09:52 PM   #6708
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
delete
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following 2 Users Say Thank You to Rifle For This Useful Post:
CK_Bladesmith (11-25-2015), sato (11-26-2015)
Old 11-26-2015, 10:50 AM   #6709
xjohnx
Grip>Slip
xjohnx's Avatar
Did you get this sorted out or do you need me to go take a picture of mine?
Old 11-26-2015, 10:53 AM   #6710
iLLDYNASTi
iLLDYNASTi's Avatar
A picture would be great. I'm also now waiting on a new intake pipe and trying to get a stock air box again. Greg from Sprintex said that the custom piping I did to use my grimmspeed box is likely what's fucking everything up.
Old 11-26-2015, 02:44 PM   #6711
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Don't modify your plastic intake pipe to relocate the MAF element in there. This is like changing to a different MAF, but with worse results. This messes with the MAF signal quite a bit.
SprintexUSA is offline   Reply With Quote
Old 12-02-2015, 07:47 AM   #6712
Harro
Drives: 2014 Toyota 86
Howdy all, I've been trawling this thread for some ideas, although it is difficult sorting out the good from the bad.
I'm running an intercooled 210 - serial number S5-210-010313-0001. The number worries me a bit - I only had the blower installed about 9 months ago and I have a feeling I've been duped with an old stock model....any way I'm facing some issues that I am trying to reduce.
One is power - I'm only sitting at about 135 rwkw on 98 RON fuel - I would expect this kit to make around 150 rwkw at least.
The other one is heat - on a recent sprint session here in Queensland where the ambient air temp was 34 degrees C (94 F), track temp would've been at least 45 C (113 F) I would imagine.
I have two after market IAT's - One in the airbox for intake temps, one post screw/intercooler, the airbox temp was sitting pretty around 45 degrees C, after 4 laps, post screw temp hit a whopping 69 degrees C - 156 F.
I'm running an oil cooler, so oil was a happy 90 C (194 F), coolant never saw over 90 C - everything else was apples.
Headers have been ceramic coated, bonnet is a siebon CF Vented, both engine and intercooler coolant have been boosted with Motul Mo Cool and flow into the engine bay is good, I've ensured there is no high pressure behind the radiator.
There are a couple of idea's I've had - insulate the coolant line into the Laminova plate...avoid any of the heat from the oil cooler lines affecting the coolant, insulate the plastic intake tube into the blower to stop heat soak, remove the skid plate from the bottom of the engine bay to increase air flow past the headers to remove some of the heat travelling upwards. Larger water pump in the intercooler circuit to increase the flow....
I'm open to other suggestions, so fire away!
Harro is offline   Reply With Quote
Old 12-02-2015, 02:48 PM   #6713
stockysnail
Just the tip
stockysnail's Avatar
This is where people tell you to run e85. I'd like answers to your question as well. I have a feeling that it will come down to the efficiency and capacity of the intercooler smashed between the blower and the manifold. I'm guessing if they went with a manifold like the Cosworth with dual intercoolers that the temperature would be less, but that's just speculation, but also a reason I've been throwing around the idea of swapping kits.
Old 12-02-2015, 02:55 PM   #6714
Harro
Yeah the move to E85 has been very tempting - I just don't know if I drive the car often enough to avoid the fuel 'going off' between drives - in 2 years I've done about 14,000km and most of that to, from and at the track.
Could invest in a flex fuel option - but that's not going to help intake temps. I think you're spot on right - the fact the laminova plate is sandwiched between two heat sources doesn't help matters. As a daily though this kit is awesome - I rarely see 10 degress post screw above ambient and it gives the car a great kick....if only it could handle the track better!
Old 12-02-2015, 04:02 PM   #6715
jwvand02
Drives: 2013 SWP BRZ Limited
You could get a tune that utilizes map switching, make gas your primary map and switch it over to E85 for the track.
jwvand02 is offline   Reply With Quote
Old 12-02-2015, 05:20 PM   #6716
Harro
While E85 would undoubtedly run cooler, would it make that much of a difference to the intake temps?
Old 12-02-2015, 06:28 PM   #6717
jwvand02
Probably not, it makes a big difference in power though. Have you looked at others' logs to see if their IATs are similar?
Old 12-02-2015, 07:44 PM   #6718
azynneo
quick question, is there supposed to be a washer or an O-ring where the dipstick is
azynneo is offline   Reply With Quote
Old 12-02-2015, 07:46 PM   #6719
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Not that I'm aware of.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 12-02-2015, 08:52 PM   #6720
stockysnail
Just the tip
Do you know where I could source a post blower air temperature plate, and temp sensor, or are you the guy I already asked a while ago? or if you don't use the MAP plate to monitor temps, where are you doing it?
For your temperature question I would ask Mike at Moto-East. He's very familiar with the kit and the 335 kit as well. He's pretty busy however so don't expect instant turnaround with a response.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
