Old 11-28-2015, 05:33 PM   #113
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by TxFrs10 View Post
No oil cooler on mine. The highest I have seen was 245°F oil temps when it was 85° outside following a faster car; measured via torque pro. Coolant bounces between 170° and 195°. 8K miles daily stage 2.3.
Do you plan on getting an oil cooler?
MS, CSCS, TSAC-F, CPT
Old 11-28-2015, 05:45 PM   #114
350matt
Drives: toyota mr2/ Toyota GT86
245 F isn't that hot = 118 deg C and bear in ind that the stock temp measurement point is on the gallery, so about 8-10 degrees hotter than it woudl be in the sump - which is the normal point of reference
as you typically want to maintain 100 deg C in the sump for best power
350matt is offline   Reply With Quote
Old 11-30-2015, 01:15 AM   #115
TxFrs10
TxFrs10's Avatar
Drives: 10 series fr-s
Not at this time. How much longer does it take to get up to temp in comparison with oil cooler?
TxFrs10 is offline   Reply With Quote
Old 12-02-2015, 01:20 PM   #116
ajc209
Drives: GT86 Cosworth
It lives:
[ame="https://www.youtube.com/watch?v=AtvxvQZEFxY"]Cosworth Stage 2 Supercharger Kit up and running on my GT86 - YouTube[/ame]
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
weederr33 (12-02-2015)
Old 12-02-2015, 06:40 PM   #117
Hamegreg
Hamegreg's Avatar
Drives: 2015 WRB BRZ Aozora Edition
That's good news ! Did you run into any issues with the install ?
Hamegreg is offline   Reply With Quote
Old 12-02-2015, 07:44 PM   #118
ajc209
It went really smoothly. No issue so far.
I did a good 6 consecutive 3rd gear pulls to check everything was running nicely but so I haven't stressed it properly yet.
I've got a track day booked in February, but until then I need to sort out the suspension, wheels and brakes!
I plan to do some proper track endurance logs to show how good the IATs are for this kit.
I'd also just like to add the cat back exhaust is a thing of beauty
Old 12-02-2015, 10:32 PM   #119
weederr33
weederr33's Avatar
I would love to know how the IATs are. I sometimes feel I may have over done it by getting an oil cooler haha.
Old 12-14-2015, 12:26 PM   #120
ocelot27
ocelot27's Avatar
Drives: 2023 BRZ Limited/Manual
Add me to the list - Stage 2.3 completed in August 2015 - BRZ... Delicious Tuning custom tunes for 93/94
-john
ocelot27 is offline   Reply With Quote
The Following User Says Thank You to ocelot27 For This Useful Post:
weederr33 (12-14-2015)
Old 12-14-2015, 02:43 PM   #121
weederr33
weederr33's Avatar
-john
I'd like to know how the Delicious Tuning works. Do you have the nameless headers and front/overpipe, or do you have a different set up? 2.3 I'd assume is headers and all. Welcome to the Cosworth crowd! Us lucky few
Old 12-14-2015, 06:37 PM   #122
weederr33
weederr33's Avatar
Ok... I've had the two codes P0171 and C1201 pop up for the second time within a 2 month period. I don't know what to make of the issue so I sent Cosworth an email. Hopefully they can help me figure this out.
Old 12-15-2015, 05:16 AM   #123
ajc209
P0171 is lean on bank 1. Check all in take pipes including the breathers. Make sure the manifold is torqued down properly - if one side is tight and the other looser it can cause an air leak.
Next thing is to check the exhaust manifold. I replaced the gaskets on my stock manifold because one cyclinder, I forget which one, was showing signs of exhaust gas creepage.
C1201 shows as an ABS related fault. Makes no sense to me that one, but hopefully Cosoworth might be able to help.
I'd speak directly with Matt Feasey rather than Cosworth USA.
weederr33 (12-15-2015)
Old 12-15-2015, 05:18 AM   #124
ajc209
It's a pain that its so infrequent, otherwise i'd try to reset the codes and make it happen while doing some logs....
Old 12-15-2015, 09:44 AM   #125
weederr33
weederr33's Avatar
I emailed Cosworth yesterday, and got a reply this morning. They want me to do a data log and then send it to them. Matt Feasey said he'd look it over and do a custom tune. He suspects it's the maf sensor, but I'm going to make sure everything is tight. The abs light is just a byproduct of the CEL.
Also, I've only been in contact with Cosworth in the UK, so I can't comment on Cosworth USA.
Old 12-15-2015, 01:00 PM   #126
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Gents
I've decided to take a presence on this forum to better assist with any issues so feel free to ask any questions - obviously I'l have to abide by forum rules but I'll help where I can
Matt@Cosworth is offline   Reply With Quote
The Following 5 Users Say Thank You to Matt@Cosworth For This Useful Post:
Adam (NoVA) (01-01-2016), ajc209 (12-15-2015), kch (12-16-2015), TxFrs10 (12-16-2015), weederr33 (12-15-2015)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
