Old 11-11-2015, 12:03 PM   #1107
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Now through the end of the year we're offering 5% off on the purchase of a Flash & Go/Innovate/NA tune + our Flex Fuel kit. This can also be combined with an EcuTek License and/or EcuTek Cable Kit. Use coupon code DT-COMBO-5 at checkout. Enjoy and happy holidays!
Sincerely,
Old 11-30-2015, 12:40 PM   #1108
DeliciousTuning
We have no added the ACE 4-2-1 Header option to our tuning page along with a few more options to choose from.
Stage 2 Reflash - Ace 4-2-1 Header
Cheers,
William Knose
Old 11-30-2015, 10:02 PM   #1109
aciddemon
Drives: 2013 FRS
Does this tune include the ACE front pipe as well or will another tune be released for that combination?
Thanks.
aciddemon is offline   Reply With Quote
Old 11-30-2015, 10:23 PM   #1110
DeliciousTuning
Thanks.
We are currently testing the front pipe (on our daily driver) on the current tune to see how it reacts to the tune. So far you can feel it adds a bit of mid range of the power band and a much quicker throttle response over the stock front pipe.
Cheers,
William Knose
Old 12-04-2015, 09:14 PM   #1111
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Hello William,
Thanks for all your work getting us to the current state of the art in tuning.
Trying to understand where things currently stand. The Link provided above to results on DT web page for stage two tune with ACE header said:
"The Stage 2 reflash using E85 for your Toyota FT86, Scion FRS or Subaru BRZ adds increased torque across the board and nearly eliminates the awful 4000 RPM dip felt by many and seen in many a dyno chart. In order to use the Stage 2 tune we highly recommend installing a full header back exhaust system in order to take full advantage of the improved performance. As far as which headers we suggest using either the ACE Muffler 4-2-1 Header for this package."
Q1: Either = Type A or B, or one of the three variants of each?
Q2: Using the OEM header back leaves how much on the performance table compared to "full header back system"? And details of FHBS tested i.e. Diameter, number of cats, etc. please to better evaluate cost per performance gained.
Thanks
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 12-05-2015, 01:29 AM   #1112
churchx
churchx's Avatar
Drives: 2014 GT86
Brzzee:
Q1 - A, if you don't mind spend extra and there still are some in stock, but B is cheaper and not much worse. > 350 < - most torque, a bit less hp, should be one to get. 150 - most hp at top, less torque (somewhat similar to other top ELs on market. Should be fine on track where one keeps near redline in powerband, not so fine for daily driving). 250 - somewhat middle torque/hp wise. 350 may have fitting/rubbing issues on automatic transmissions/RHD though. Check up Ace's related threads for nfo.
Q2 - actually Ace gets most gains from which you can get with full bolt ons while NA, and adding rest will be not too cost effective imho due diminishing returns when nearing +40whp .. imho you'll be fine with OEM catback too. Maybe just add aftermarket air filter. Also if considering other bolt on upgrades, remember that catless header increases loudness a lot, so choose quieter catbacks like eg. Q300 if you decide to change out stock.
Brzzee (12-12-2015)
Old 12-07-2015, 12:51 PM   #1113
DeliciousTuning
Originally Posted by churchx View Post
Brzzee:
You pretty much hit it right on the dot here. Our shop car has a Type A 350 installed along with the stock catback. We've finished dialing in our tune for this system, and it's available on our website here: http://www.delicioustuning.com/node/484
Recently, we've also added the Ace front pipe. We should be getting some additional fine tuning done around the front pipe soon. Our standard Stage 2 NA tune already worked pretty well with this setup; this Ace specific tune adds a bit more power, and offers considerable fueling and cam timing changes to suit its specific powerband. What this means for the end user is ultimately a smoother driving experience with a bit more power on tap than our typical map.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Brzzee (12-12-2015)
Old 12-07-2015, 01:28 PM   #1114
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
I can't seem to find 97 RON fuel rating in the website.
Can I go for 98 RON option or that would be dangers?
TkTk is offline   Reply With Quote
Old 12-07-2015, 05:53 PM   #1115
DeliciousTuning
You can always specify 97 RON in the comments section at checkout, and we can calibrate for that specific fuel. I believe we've tuned a couple folks in Qatar with the same 97 RON fuel.
Sincerely,
Old 12-07-2015, 11:07 PM   #1116
tt86
Drives: 2012 JDM Toyota 86
Originally Posted by sales@delicioustuning.com View Post
Once the car has a license, it is permanent. You do not need to buy another. All you would need to get a new tune on the vehicle is a cable kit and tune to flash.
Sincerely,
Zach
Ok so i want to get the cable kit. Where do i purchase? Your website? Will i be able to see what parameters and maps are currently set on the ecu as was tuned in Japan? I also want to install a header on the car, does this mean you guys can sell me a map and i can put it in myself? Do I even need to visit a dyno? If the car can indeed be tuned without a tuner physically present then this is very exciting news to me as access to a good tuner in extremely difficult here in the caribbean.
Sent from my SM-T700 using Tapatalk
tt86 is offline   Reply With Quote
Old 12-08-2015, 12:13 PM   #1117
DeliciousTuning
What you'd need is a cable kit, license, and tune. You can check those out on our website here: www.delicioustuning.com/Stage_2_PumpGas
You will be able to datalog certain parameters on the factory map with the cable kit, and more with our tune, but you will not be able to edit or view any of the maps themselves as they are locked. You can install our maps from the comfort of your garage, without ever needing to see a separate tuner or dyno!
Sincerely,
Old 01-05-2016, 12:01 PM   #1118
DeliciousTuning
Happy New Year!
We are working on some new developments this year and to give you an idea here are some pictures. Keep an eye out...
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
DriftEm (01-06-2016), MINOCIN (01-09-2016), Wayno (01-05-2016)
Old 05-02-2016, 03:50 PM   #1119
DeliciousTuning
Update: All tunes have recently been updated for improved throttle mapping and starting from a dead stop. Current versions are listed below:
Stage 1 NA: V6.00
Stage 2 NA: V6.50
Stage 2 Ace Specific: V6.50
Innovate/Sprintex Specific: V9.50
Edelbrock: V19.00
Flash & Go: V19.00
The latest Ace specific tune also gains over 10ft/lb of torque in the lower end as compared with the previous version (V6.46), and has a broader torque curve overall. These updates will be the same $65 as our previous releases. For more information, email me directly at sales@delicioustuning.com.com
To view each of these tunes on our website, check the individual links:
Stage 1 NA: http://www.delicioustuning.com/Stage_1_PumpGas
Stage 2 NA: http://www.delicioustuning.com/Stage_2_PumpGas
Stage 2 Ace Specific: http://www.delicioustuning.com/node/484
Innovate/Sprintex Stage 1: http://www.delicioustuning.com/Innovate/Stage1_Tuner
Innovate/Sprintex Stage 2: http://www.delicioustuning.com/Innovate/Stage2_Tuner
Edelbrock: http://www.delicioustuning.com/node/483
Flash & Go: http://www.delicioustuning.com/flash_and_go
Sincerely,
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
MaximeT (09-20-2016), Votlon (05-10-2016)
Old 09-20-2016, 03:45 PM   #1120
DHitHim
Drives: 2015 CWP Limited BRZ
Are the logs you request and we wemail back to you in excel sheet?
DHitHim is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
