#1695 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | CxG (03-07-2017) |
#1696 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
#1697 |
Drives: Limited BRZ
I really have no idea, but if that happened so many months ago and nothing has happened, I think you're clear.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Astroboy (11-13-2015) |
#1698 |
Drives: 2013 Raven fr-s
Hey everyone, I have been doing a ton of reading of and on since this thread started. Now that we are at near 80 pages there is no way i can rea it all.
I think the AVO kit is the best option for me as I love the sound of the UEL header, not need to remove the oil pan, OEM style oil pump option, etc. My question is, how are the header/manifold holding up over time? I know i remember reading about leaking manifolds, warped flanges, etc. has that pretty much been taken care of now? I DD my car and DO NOT have time to have the car down constantly fixing minor issues, and thats why I have waited for 3 years to do any kind of power upgrades. |
| The Following User Says Thank You to Basket Case For This Useful Post: | Astroboy (11-18-2015) |
#1699 |
I've never had any issues with mine. I used the grimmspeed gaskets and the header flange was machined though. I bought my AVO kit from a member after he ran it for a bit.
It was exactly what the car needed. |
#1700 |
Drives: .
Little exhaust clip from our recently Turbo'd GT86:
[ame="https://www.youtube.com/watch?v=tRVUOiurxP4"]https://www.youtube.com/watch?v=tRVUOiurxP4[/ame]
"Some will follow your footsteps, easier than they will your advice."
#1701 |
Drives: GT86
Hi everybody!
![]() I have a question about Ecutek´s boost settings via map switching. Do I need to add something to my setup like "separate boost controller and valve" to get it done? If so can you guys give me advice "best valve" Im complete newbie about this thing. ![]() My kit has 8 actuator and 3" AVO catted full exhaust. |
#1702 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
For ecu controlled boost you'll need a boost control solenoid that plugs into an existing harness (replaces the evap). You'll need to talk to your tuner about getting it enabled You could also run a standalone boost controller, either manual or electronic. The problem with this route as a newbie is that the potential to blow something up is quite high In my opinion, you should go with the ecu controlled boost setup because it will be easier to use and setup. Talk to your tuner, they probably have a solenoid for sale
Top Tier Imports - Check out my build journal HERE
| The Following 2 Users Say Thank You to protpibe For This Useful Post: | Draco_PR23 (11-29-2015), Jonde875 (11-29-2015) |
#1703 | |
Drives: GT86
#1704 |
Drives: None
How's the winter treating you guys with the avo kit. Anybody still running oil coolers in the winter
#1706 |
Drives: None
#1707 |
Drives: GT86
#1708 |
Drives: None
What clutch Are you guys running with this kit? I think I might have smoked my stock clutch
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
