Old 11-24-2015, 03:04 AM   #183
ravisraval
Drives: 2013 FRS
Originally Posted by ka-t_240 View Post
So then you feel the kit should clear the 17x9 +35 w/o spacers?
yup
ravisraval is offline
The Following User Says Thank You to ravisraval For This Useful Post:
MaximeT (11-24-2015)
Old 11-24-2015, 11:23 AM   #184
frslee
Just drive it
Drives: 13' FR-S
Originally Posted by MaximeT View Post
The kit looks really good.
I took that with my phone :
Let us know how that works out. I'm currently saving up for a kit soon.
frslee is offline
The Following User Says Thank You to frslee For This Useful Post:
Old 11-26-2015, 08:40 AM   #185
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
Rafi,
What is your thoughts on mixing the Sport Rears with the compition fronts? I see you have a holiday sale going on, that is a $100 of the purchase of a F/R sport kit. But, would prefer the 6 piston fronts.
I think that its a great combo. Based on our track testing and all the feedback we have received from the numerous customers we have who track their 86's, this car benefits tremendously from more rear bias.
Rafi
Rafi@RR-racing is offline
Old 11-26-2015, 11:10 AM   #186
ka-t_240
Rafi
Is it too much rear bias? I know you mentioned that the stage 2 rear for competition setup should have rear aero, what that right?
ka-t_240 is offline
Old 11-27-2015, 06:49 PM   #187
Rafi@RR-racing
Drives: Toyota GT86
We originally developed the Stage II rear caliper setup for cars with rear downforce. But since we have done that, we tested that setup without rear downforce and had no issues at all, definitely no rear lockup.
We have done a lot of road testing with the Sport Performance rear kit, and no rear lockup issues either. Balance is really good.
Neal from The Racer's Line tested our rear kit on a customer car, without rear downforce, in the rain at Leguna Seca -- so even in the rain, we did not get any reports of rear lockup or ABS activation on the rear brakes.
BTW, Phil from Element Tuning is not only running our Stage II rear calipers, but he is now also using Hawk DTC60 pads in the rear, and much lower friction pads in the front! So the bottom line is that the 86 really benefits from increased rear bias.
Rafi
The Following 2 Users Say Thank You to Rafi@RR-racing For This Useful Post:
MaximeT (11-28-2015), solidONE (11-29-2015)
Old 11-28-2015, 10:12 AM   #188
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
Next week we will have front rotors that match the Sport Performance kit rears. I will post pics of the new front rotor option that matches rears by next week.
Any progress on this? I think I'll be buying the stage I front kit if it will work with the dba rotors. I think I'll be able to make the money work out if I can use paypal "bill me later" feature. As long as the price doesn't change too significantly for the dba's.
ハチロク is offline
The Following User Says Thank You to ハチロク For This Useful Post:
djdnz (11-28-2015)
Old 11-28-2015, 10:37 AM   #189
ka-t_240
Rafi
Thanks! I know I feel the need for more rear bias, I have noticed abs activation on the front end of the car on the hard braking corners of our local track. Currently running dtc60s f and r on stock calipers.
ka-t_240 is offline
Old 11-28-2015, 05:25 PM   #190
Rafi@RR-racing
Drives: Toyota GT86
Almost man... sorry for the delay. We should get the DBA pattern front rotors this coming week, will post pics soon.
Nice thing is that you are in NJ, so you will receive the order really fast (we are near Philly).
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
ハチロク (11-28-2015)
Old 11-28-2015, 11:04 PM   #191
DarkSunrise
DarkSunrise's Avatar
That's a good question, generally the Stage II and IV will not fit stock rims because they use much wider calipers to accommodate thick pads.
So if you want maximum clearance, you need to go with Stage I or Stage III which use the more narrow caliper. Rear should fit no problem with stock wheels.
That said, for the front, even with the Stage I or Stage III, you will still need approx. 10mm spacer for stock wheels.
You can download the wheel fitment templates off of the description page of each brake kit on our site.
-Rafi
@Rafi@RR-racing
This is a picture of the stage 2 front template and Wedssport TC105N 17x8 +42 wheels. There is about 6 mm clearance towards the bottom. Assuming there is some thermal expansion at track temps, how much space would you recommend at a minimum? Thanks!
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
Old 12-07-2015, 03:17 AM   #192
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Are the STAGE I compatible with DBA T3 4000's for our cars??
http://www.rallysportdirect.com/shop...ont-rotor-pair
stevo_12v is offline
Old 12-07-2015, 07:31 AM   #193
ajc209
Drives: GT86 Cosworth
Yes, regarding BBK fitment for stock wheels, what you wrote is correct.
The Sport Performance Rear 4 piston BBK is a huge value proposition because what we achieved is more heat capacity AND a big shift in rear bias which benefits braking performance tremendously. The rear pad wear rate is much less than fronts, so the thickness of the pads is plenty sufficient. You will find that the rear pads will still outlast the thick pads we use on our front BBK's, so this is a non-issue.
Bias chart:
Hi,
Looking on your website you have two options for the piston diameter of the sport performance rear kits. Am I correct to assume the column on the right is with the larger piston offered with the sport performance rear kit?
ajc209 is offline
Old 12-07-2015, 04:23 PM   #194
Panman
Panman's Avatar
Drives: 86 GTS
It works with the DBA rotors, I'm running them
Panman is offline
Old 12-07-2015, 04:25 PM   #195
Panman
Panman's Avatar
Drives: 86 GTS
Stevo, That's what I'm running on my car with the Stage 1 Kit - Brisbane.
Panman is offline
The Following User Says Thank You to Panman For This Useful Post:
stevo_12v (12-08-2015)
Old 12-07-2015, 06:40 PM   #196
Rafi@RR-racing
Drives: Toyota GT86
Originally Posted by ajc209 View Post
Hi,
Sport Performance kit only has one piston option. We have 2 piston options with our 2 piece 13" rear Competition kits.
Rafi
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
