Old 11-22-2015, 10:25 PM   #15
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
There is one other element to the equation to consider. I believe the damper in MY15 cars onwards were re-valved for better ride quality.
My MY15 BRZ rides quite nice provided I stay on top of my tire pressures and am still completely stock on the 17x7 wheels.
Things I'm considering for improving ride would be a lighter set of wheels, but going to 225 tyres with a softer compound / side walls. After seeing how that goes I'm might look to a set of coliovers however I'm not interested in a drop in ride height. If I can't avoid a small drop then no more than 1 or 2cm at the most or no dice.
The car came from the factory really low to start with and I have really enjoyed simply driving the car and not needing to take any more than rudimentary care with drive ways and speed humps.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 11-23-2015, 01:08 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Mr_Hann View Post
Their infinite adjustability
What is this infinite adjustability you speak of?
Old 11-23-2015, 06:02 PM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by discretion View Post
Sounds like exactly what I'm looking for. Do you actually think it would improve ride quality though? And about how much would that set up cost me?
RCE yellows have been reviewed a bunch of times on here, pretty well everyone I've read or talked to agrees that they ride better than stock. Not really "smoother" but less crashy, more composed. They only way I could reconcile it in my mind was to think that the stiffer springs and shorter bump stops were making the transition from the spring to the bump stop smoother. The end result gave me a lot more confidence in corners and made the ride more enjoyable than stock.
The HD dampers should ride even better while increasing grip. Really, you can't go wrong with that setup. Also, keep an eye out for black friday sales, especially for the dampers. furiouscustoms.com had an incredible deal on for them last year and their customer service is awesome. RCE (racecompengineering.com) also sells them for a great price, and their customer service is absolutely the best I've ever received.
Old 11-23-2015, 06:20 PM   #18
stevesnj
stevesnj's Avatar
TRD lowering springs, great handling for under $250.
My 2016 Build thread
Old 11-23-2015, 06:37 PM   #19
Mr_Hann
Mr_Hann's Avatar
Drives: 2015 Steel FR-S
The rebound dampening is adjustable from very soft to very stiff, but unlike other shock bodies it doesn't have any "clicks". So technically yes there is a range of adjustment (making it finite), but because you can turn the dial 1/4, 1/8, 1/64, etc. that was what I meant by "infinite adjustability".
Mr_Hann is offline   Reply With Quote
Old 11-23-2015, 07:13 PM   #20
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Would the Ohlins make a big difference in ride quality? My main concern is getting better ride, more supple, plus a slight boost in performance. Nothing extreme.
If you want to increase ride quality while maintaining your road-holding you will need to go high end on the dampers. I've had several aftermarket dampers through the years, but Ohlins are the only ones I've owned that seem to improve BOTH handling and ride comfort - and this is on a very low Miata.
-Justin
Justin.b is offline   Reply With Quote
Old 11-23-2015, 09:29 PM   #21
Racecomp Engineering
Calum's response sums it up nicely. With the Bilsteins yes for sure ride quality is great and without it's still good over most bumps.
We're deciding on some Black Friday sales but are still finalizing them. They'll go through the weekend at least.
- Andrew
Old 11-25-2015, 03:15 AM   #22
discretion
Drives: Scion FR-S in Whiteout
- Andrew
So I'll need RCE yellows and HD dampers?
discretion is offline   Reply With Quote
Old 11-25-2015, 11:26 AM   #23
That would be the way I would go.
- Andrew
Old 11-25-2015, 11:38 AM   #24
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
That's a really good combo. If you buy Bilsteins, look around for best prices. Last time I checked, a certain tire website had the lowest price on them.
smg1138 is offline   Reply With Quote
Old 11-25-2015, 06:51 PM   #25
discretion
Bilsteins in addition or on top of the RCE's and HD dampers?
Old 11-25-2015, 07:32 PM   #26
smg1138
smg1138's Avatar
Bilsteins are HD's. They make the Sport and HD versions. The Bilstein HD's are what you would want to match RCE Yellow springs.
Old 11-25-2015, 07:43 PM   #27
discretion
Ah, I see. Noob question haha
Old 11-25-2015, 07:46 PM   #28
discretion
- Andrew
How much would labor cost?
Concerns about the 1st round of mods RYU Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-31-2015 11:29 PM
My first round of upgrades MonkeyBoy Scion FR-S / Toyota 86 GT86 General Forum 16 01-14-2014 03:27 PM
New round of exhausts? mike_ekim1024 Engine, Exhaust, Transmission 0 01-01-2014 02:21 AM
Should I sit out this round and see what comes in 2014? oldpueblo BRZ First-Gen (2012+) — General Topics 56 10-10-2012 12:44 PM
Last round! Levi Scion FR-S / Toyota 86 GT86 General Forum 36 09-16-2011 05:08 PM
