Old 10-27-2015, 11:58 AM   #85
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by CxG View Post
MOREEEEEEE!
I want to put one of these in my 85 Celica now...
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
CxG (10-27-2015)
Old 10-28-2015, 02:16 AM   #86
CxG
Drives: Pearl White '13 ZN6
Well I may have to start buying parts soon...
It looks like he has it all down for sale with the exception of headers/turbo manifold and mounts.
This will be the swap to satisfy the hearts of purist wanting to retain a good weight distribution and good after market (albeit it imported) support can't wait!!
The way it should have been
http://www.86swap.com/collections/86swap-com
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
The Following User Says Thank You to CxG For This Useful Post:
Draco_PR23 (10-28-2015)
Old 10-28-2015, 02:17 AM   #87
CxG
Originally Posted by JazzleSAURUS View Post
I think it would of been cool to offer a 3S in the Toyota, and an FA in the Subaru so you could pick which was more relevant to the heritage, but I'm also an EJ fan....for some reason.
Bored out 2ZZ would have been more appropriate
Old 11-08-2015, 10:56 PM   #88
Toxicmilk45
Toxicmilk45's Avatar
Drives: White out FRS
Hey guys, I'm actually planning on starting a 3SGE swap on my FRS this month due to a blown FA20. Pretty disappointed in the boxer that came with this car, NA car and still under 30K miles.
As of right now, a 3SGE swap seems like the most cost efficient way to get my car running again instead of having to deal with another complicated and weak FA20.
I'm going to try my best to document my swap since I really don't know much about these engines and could use all the help I can get! I should be picking my car up from the dealership and starting the tear down this week.
Toxicmilk45 is offline   Reply With Quote
The Following 4 Users Say Thank You to Toxicmilk45 For This Useful Post:
cf6mech (11-09-2015), CxG (11-09-2015), Draco_PR23 (11-08-2015), KR-S (11-24-2015)
Old 11-09-2015, 04:41 PM   #89
CxG
Good luck to you, I plan on going with this swap as well when I have enough funds to do it properly. Don't care how long it takes.
Old 11-11-2015, 12:35 PM   #90
JDM Haze
JDM Haze's Avatar
Drives: Whiteout FRS
Check out 86swap.com, they have a bunch of stuff needed to get the swap in. At around 3k (without a stand alone ecu) you get mounts, driveshaft, and wiring harness (plug and play). Or at least ask them what you would need because they've done it and they know what they're doing with the swap.
And defiantly want to check it out once you're done.
JDM Haze is offline   Reply With Quote
The Following User Says Thank You to JDM Haze For This Useful Post:
hmong337 (11-11-2015)
Old 11-24-2015, 10:16 PM   #91
MrDinkleman
Drives: 2016 Oceanic, "base" model
Originally Posted by hmong337 View Post
This is how the frs should've came.
Yup. As I followed the development of the BRZ/FRS I was hoping that in the end the two models would be differentiated at least by their engines. Oh well, still like the car as it is...
MrDinkleman is offline   Reply With Quote
Old 11-24-2015, 11:03 PM   #92
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
So while we are on the subject of 3S engines, has anyone tried to swap a 3S-GTE in? How much different is that engine from the BEAMS 3S-GE?
Old 11-24-2015, 11:25 PM   #93
CxG
That I know of, no. Only one 3S swap that I'm aware of and it's that blue one that's for sale.
Difference in engines. Quite a few. First of the heads are different in design and technology. The beams has VVT-i while the turbo one doesn't (think valve angles were different as well). Pistons, connecting rods (forged in the turbo model), compression ratio, and if I'm not mistaken oil pumps and oil pans are all different as well.
As for using the existing beams swap kit to put in a 3S-GTE. It wouldn't work. The 3S-GTE has always been transverse mounted and because of the oil pan and pump if you don't let it sit with a lean (tilt) you'll kill the engine from oil starvation. Also the swap kit has custom headers you'll have to source elsewhere.
The Beams has a better head design, would have better around time driving, and wouldn't suffer from turbo lag because high compression. The 3S-GTE has more horsepower potential (when shooting for over 500), and is more common in the United States seeing as how it was actually sold in the market.
The Following 2 Users Say Thank You to CxG For This Useful Post:
Draco_PR23 (11-25-2015), KR-S (11-24-2015)
Old 12-25-2015, 08:28 PM   #94
midshipmiguel
Drives: 91 MR2 turbo 2013 brz supercharged
Well I've got a hole in my block. 2013 WRB BRZ with vortech supercharger 40k miles. I'm think of a 4th gen 3sgte what was needed for your beams swap
midshipmiguel is offline   Reply With Quote
Old 12-25-2015, 08:30 PM   #95
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
gen4 3sgte is a transverse engine so it will not fit. The BEAMS iteration of 3s is the best anyways.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
NyC Zn6 (12-28-2015)
Old 12-26-2015, 07:56 AM   #96
wparsons
wparsons's Avatar
No chance the swap will end up costing less than just putting in another stock engine. You'll get a good used engine for about (or less than) what mounts/wiring will cost for the swap.
flickr
Old 12-06-2016, 08:03 PM   #97
Toxicmilk45
I've been done with my 3SGE swap for a few months now and finally decided now to upload some photos for you guys.
These are photos from around March or April I believe before I had a new harness and Haltech standalone ecu. I was running stock harness and ecu at the time.
I am currently using this as my daily driver and I love it.
The Following 5 Users Say Thank You to Toxicmilk45 For This Useful Post:
CxG (01-14-2017), Draco_PR23 (12-06-2016), Sportsguy83 (01-10-2017), Teseo (12-06-2016), TofuJoe (03-23-2017)
Old 12-06-2016, 08:05 PM   #98
Toxicmilk45
Also check out my buddy Alan's video that he made of my car.
I'm sure some of you guys already know him, he makes amazing videos and is a FRS drift king lol.
[ame="https://www.youtube.com/watch?v=DupEdhpc5yw"]BEAMS Swapped FRS | Fixing my Cracked Bumper - YouTube[/ame]
CxG (01-14-2017), Draco_PR23 (12-06-2016), Jdogg88 (12-06-2016), slow86 (01-14-2017), Sportsguy83 (01-10-2017)
High beams DjDATZ Cosmetic Modification (Interior/Exterior/Lighting) 8 09-10-2014 07:49 PM
3000k HID low beams WolfsFang Cosmetic Modification (Interior/Exterior/Lighting) 26 08-21-2013 09:41 PM
24 Watt LED DRL/Hi beams! Ironsquid Cosmetic Modification (Interior/Exterior/Lighting) 23 05-20-2013 02:45 PM
High Beams DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 01-12-2013 10:44 PM
High beams?!?! gmanculb Cosmetic Modification (Interior/Exterior/Lighting) 12 10-02-2012 04:51 PM
