Old 11-19-2015, 09:41 PM   #1
LaertesSon
LaertesSon's Avatar
Drives: Asphalt 2013 FR-S 6MT
Misfire after installing Crawford Billet Power Blocks (BPB)
So today I installed the Crawford Billet Power Blocks. I took the car for a drive after I installed them, and everything seemed normal until I revved it to about 4k under load, and it seemed to stutter and not want to go above that. I took it home and tightened up the intake tube and looked over everything and it all seemed fine, so I took it out again and under a bit more throttle revved it to 4k. Same issue, but this time I got a blinking CEL that went away after a few seconds. I checked the code with my OBD reader and it's a cylinder 2 misfire. Any idea of the quickest way to fix this or find the problem? My guess is the o-ring on that cylinder has come undone and is causing a vacuum leak. Thanks in advance
By the way - my only other mod on the engine is the Perrin CAI and inlet tube. No tune.
OFT Stage 2 tune, OFH, Works AB-M, Perrin 2.75" Intake/Silicone inlet
Kartboy Short Shifter, WC Lathewerks knob, MTEC springs
TSW Nurburgring, FIVE:AD aero kit, smoked Valenti
LaertesSon is offline   Reply With Quote
Old 11-19-2015, 11:30 PM   #2
I reckon the only way to check to see if the "O" ring slipped out of the groove during installation, is to take it off and check.
Now, wasn't THAT helpful .....
humfrz is online now   Reply With Quote
Old 11-20-2015, 12:13 PM   #3
LaertesSon
LaertesSon's Avatar
I just took them out and the misfires stopped. No blocks for me. Rallysportdirect won't even let me return them!
Old 11-20-2015, 12:34 PM   #4
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@LaertesSon did you determine whether the o-ring was out of place, etc.? Or did you just take them off, no more problem, so it's the parts fault?
Otherwise why would @Rallysportdirect even let you return an installed part that was not proven to be defective?
LOLS2K is offline   Reply With Quote
Old 11-20-2015, 12:36 PM   #5
LaertesSon
LaertesSon's Avatar
The o-rings were just fine. It's as simple as blocks in = misfires blocks out = runs fine. I looked and the blocks seem to have a bit of a defect, a really small dent:
I do not think I changed one thing other than the blocks, and my misfire was solved. I'm not sure if such a small dent could actually cause a vacuum problem, but it's the only solution I can come up with.
EDIT: I don't really expect RSD to let me return them. It's just a pain because from what I can tell, the blocks were causing the issue.
The Following User Says Thank You to LaertesSon For This Useful Post:
flippy (01-21-2016)
Old 11-20-2015, 12:42 PM   #6
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@LaertesSon interesting find. I too am curious to find out if that dent could be causing your issues. Hopefully RSD and/or Crawford can shed some light on this issue.
Old 11-20-2015, 01:31 PM   #7
LaertesSon
LaertesSon's Avatar
I am as well. I will update on what Crawford says. I think I'm out of luck with RSD. Everyone be careful with these blocks and ensure they aren't damaged before you install them.
LOLS2K (11-20-2015)
Old 11-20-2015, 02:02 PM   #8
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Crawford should replace it under warranty. if not, who'll buy it? sucks to happen this to OP. It's annoying to replace same part like 2-3 times
Old 11-20-2015, 02:04 PM   #9
LaertesSon
LaertesSon's Avatar
I'm wouldnt attempt to sell them because I spent quite a few hours getting them in and out and have nothing to show for it and I wouldnt wish that on anyone lol. Just awaiting Crawfords response now
Tcoat (11-20-2015)
Old 11-20-2015, 02:59 PM   #10
I wouldn't think that little nick would be an issue, because the O ring should seal around it.
Did you check the blocks to make sure they were "flat", like in ..... not warped .... ??
Old 11-20-2015, 03:22 PM   #11
LaertesSon
LaertesSon's Avatar
That's good thinking.
I just checked with a level and the level sits perfectly flat along both of the blocks. They look to be flat.
Old 11-20-2015, 03:52 PM   #12
hmmmm.........I hope this doesn't insult your mechanical abilities ....... but, are you sure you installed the power blocks ....... gasket side down ..... ??
Old 11-20-2015, 03:59 PM   #13
LaertesSon
LaertesSon's Avatar
Hah not at all. Fair question. I made sure to do that when I installed them. I triple checked that as I was installing.
Old 11-20-2015, 05:05 PM   #14
Well, I'm out of "ideas".......
Hopefully, Crawford has a solution.
What a bummer ...... all that work ......
Please let us know how it turns out.
LaertesSon (11-20-2015)
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
FS: Crawford Billet Power Blocks FRSH86 Engine, Exhaust, Bolt-Ons 17 09-21-2015 03:52 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
Brand new Crawford Billet Power Blocks serial gixxer Engine, Exhaust, Bolt-Ons 1 07-18-2014 11:33 PM
Brand New Crawford Billet Power Blocks wawro569 Engine, Exhaust, Bolt-Ons 18 07-11-2014 02:06 AM
