| Software Tuning Discuss all software tuning topics. |
Drives: 2014 BRZ sterling silver
ACE header and OFT
With in the next year I plan on getting an ACE type 1 or 2. I have a OFT and was wondering how well the stage2 EL 91 or 93 tune does with it?
#2 |
Not a troll
It will probably do OK. If you're spending the money on what is most likely the "holy grail" of headers for the twins, it's worth it to either get a custom e-tune done by Shiv, or ante up and get ECUTek and a dyno tune. Really depends on how much you want to spend on top of the header.
#3 |
Yeah I wouldn't get the ace if your going to use an ots tune
| The Following User Says Thank You to raven1231 For This Useful Post: | kch (11-18-2015) |
#4 |
I wouldn't recommend an Ace if you're going to use a OTS tune. Likewise, if you get the Ace, I wouldn't recommend using an OTS tune.
I've seen some OTS tune disagree with the Ace header so much that a chasm of 109wtq was recorded on the dyno. The Ace header's flow is so different from the other headers on the market that a tune is mandatory to really take advantage of the header. CSG is in the process of creating "off the shelf" tunes for the Ace header, for common configurations. - Stock drivetrain w/ Ace header (any catback) (gasoline and Flex Fuel) - Stock drivetrain w/ Ace header + Ace FP (any catback) (gasoline and Flex Fuel) - JRSC w/ Ace header + Ace FP (gasoline) - JRSC w/ Ace header + Ace FP + Injectors (gasoline + flex fuel) - Edelbrock w/ Ace header + Ace FP + Injectors (gasoline + Flex Fuel) There is no ETA on these tunes; they are ready when they are ready. Each tune is being extensively tested in a variety of conditions to get the best possible long term reliability. |
| The Following 11 Users Say Thank You to CSG Mike For This Useful Post: |
#5 | |
/scion
Drives: '13 86 M/T
#6 |
Drives: '13 BRZ | '04 E55
| The Following 3 Users Say Thank You to NotSoJDM For This Useful Post: |
#7 | |
When I first got my ACE header, I loaded up the Stage 2 EL tune. It's already been said, but this does not take advantage of the full potential of the header. If you are looking to just flash a map and be done, then using an OFT map is not for you. I would recommend going ECUtek and getting a flash from someone who has developed one for the ACE. IF you are comfortable with making adjustments in your tune, then an OFT OTS map is a good starting point. There are VVT tables posted on this forum for use with the ACE, and can be tweaked even further. You can also play with some base timing in the stage 2 map and get a few extra horsepower. The simple answer is, if you want to tune yourself, give the OFT a try. If that's not something that interests you, you are better suited with ECUtek. |
| The Following User Says Thank You to NotSoJDM For This Useful Post: | AceHeader-MT (11-26-2015) |
#8 |
hummmm well I guess the best thing for me to do is have SHIV make me a custom tune. Thanks for the reply's
| The Following User Says Thank You to oldgunfan For This Useful Post: | raven1231 (11-19-2015) |
#9 |
You can use any tune, you just need to find a tuner willing to figure out VVT tables for the header if you want optimal flow. This may be tricky with OFT because many tuners refuse to work with unlocked tunes.
#10 |
There's other people that sell unlocked tunes as well, on EcuTek.
#11 | |
I'm not saying there isnt, but I can count the number of Ecutek tuners offering unlocked roms on one finger (to my knowledge). If you know anyone other than jamesm (who doesn't etune anymore) please feel free to share them. Sent from my iPhone using Tapatalk
#12 |
PhoneFlash by EcuTeK
We are actually custom specific tunes for the ACE Header for the past few months for daily driving and track. We should be releasing these in the very near future.
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | AceHeader-MT (11-26-2015), Stumpygt86 (12-04-2015) |
#13 |
Drives: 2013 FR-S Argento
#14 |
Drives: '13 FR-S WHITEOUT
Should be ecutek
Sent from my SM-G900V using Tapatalk
\\ 3" Perrin RCBE [] Radium MCB [] SuperTek Intake Tube [] AFE DIF [] Kartboy Crank Pulley [] BRZ Swift Springs [] OFT //
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
