Old 11-15-2015, 02:12 PM   #1835
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by swarb View Post
Any ideas to combat inside rear wheel lift?
I am on feal coilovers 7k/7k, everything else pretty stock.
2.9 camber all around, I know that is too much in the rear.
0 toe front. tiny bit toe in rear.
Front bar? Increase shock stiffness front? and softer rear?
You need a front bar anyway. So I would start there.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
swarb (11-15-2015)
Old 11-15-2015, 02:35 PM   #1836
renfield90
The Stig's German cousin
As an alternative you could disconnect the rear sway bar, but you'll probably have a better car by upgrading the front.
The Following User Says Thank You to renfield90 For This Useful Post:
swarb (11-15-2015)
Old 11-15-2015, 05:56 PM   #1837
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Detaching the rear bar is pretty common for Miatas, might make sense for you swarb just as a test, you should be able to reattach in between runs if it's bad. How low are you? Maybe the rear bar is preloaded creating some weird forces, adjustable endlinks might be the solution?
ineedyourdiddly
swarb (11-15-2015)
Old 11-15-2015, 06:39 PM   #1838
swarb
I am lowered about 1.5-1.75 inches(I know too low, but I wanna look cool!).
The coilovers came with front end links about 2inches shorter. The rear ones are stock. They rear endlinks are pre-loaded a little too much sadly. How should I preload? 0 at static height? or slightly?
I guess I will try a front sway bar and some rear end links. Anyone know a factory endlink(wrx?) that is slightly shorter than stock?
Whiteline for sway bar or? I want an adjustable and probably just slightly bigger.
Old 11-15-2015, 06:57 PM   #1839
BlaineWasHere
Grip>Drift
Drives: FRS
I ran stock endlinks for a bit with the Strano bar but because I so low (2 inches) I had to get whiteline links for clearance.
But I'm lower than you and I don't lift any tires ever.
Old 11-15-2015, 07:37 PM   #1840
strat61caster
I always did mine with zero preload when sitting on a level surface, everything should come apart and go together with zero resistance.
Lots of variables at play here... Might also be driving style, still on the brakes to get weight up front whilst turning would make the car do this, but this isn't an FF or the stock suspension where you need to force the front to grip. Dialing back on the trail braking may settle the car better.
ineedyourdiddly
Old 11-16-2015, 08:58 AM   #1841
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Sorry to interrupt the technical discussion, but I just wanted to put in a plug for my Nameless header that is for sale in case someone is looking for some STX goodies for next season:
http://www.ft86club.com/forums/showthread.php?t=97529
jprice130 is offline   Reply With Quote
Old 11-18-2015, 02:45 PM   #1842
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I think I've become addicted to buying parts that I don't plan to install for several more months. Perhaps I should start one of those build thread things....
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-18-2015, 09:19 PM   #1843
cjd
cjd's Avatar
Drives: 2017 BRZ
I started last November... It's when good stuff shows up FS.
The Following User Says Thank You to cjd For This Useful Post:
Shark_Bait88 (11-18-2015)
Old 11-18-2015, 10:43 PM   #1844
48Spoons
Drives: Ultramarine FR-S
Bought most of my STX setup last black friday, hurt to wait till around spring to get everything installed.
48Spoons is offline   Reply With Quote
The Following User Says Thank You to 48Spoons For This Useful Post:
Old 11-18-2015, 11:45 PM   #1845
Shark_Bait88
Yeah, the only other thing I plan to get before spring will be camber plates for the new coilovers. I'll figure out the sway bar setup after I see how the car feels with the new suspension at my first event next year.
Old 11-19-2015, 01:25 PM   #1846
conedodging
conedodging's Avatar
Drives: '14 BRZ
Fun. Our PAX jumps up by .005 to .836 next season. Thanks everyone.
http://solotime.info/pax/rtp2016.html
conedodging is offline   Reply With Quote
The Following User Says Thank You to conedodging For This Useful Post:
justint5387 (11-19-2015)
Old 11-19-2015, 03:46 PM   #1847
RedBRZ80
Drives: 2013 Red BRZ
That's the "Marcus effect ". When STX raw times STR. You know pax will change.
But all street tire classes went up- the RE71 effect.
RedBRZ80 is offline   Reply With Quote
The Following 3 Users Say Thank You to RedBRZ80 For This Useful Post:
conedodging (11-19-2015), DocWalt (11-19-2015), strat61caster (11-19-2015)
Old 11-19-2015, 11:03 PM   #1848
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yea, pretty much everything is up.
STX has gone up the last 2 years too, can't say I was surprised by another increase. I blame the twins coming onto the scene
justinco is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
