Drives: 2019 BMW ///M4
Diode Dynamic Fog Light Caught Fire - Caution
For those of you running the Diode Dynamic Fog Light, please check your fog lights....
I've had my Diode Dynamics fog light for about one year and this is the long term result of owning them: Back in October of 2014 the negative terminal melted... See thread: http://www.ft86club.com/forums/showthread.php?p=2003881 Pictures are broken but here they are again... ![]() ![]() They replaced the harness and now about one year later this is the result.... On November 10th my fog light on driver side stopped working, I bought a new bulb and replaced it. I also noticed condensation in my housings. Upon further inspection I found the DRIVER side melting... ![]() I contacted Diode Dynamics.... ![]() This is there response... ![]() Again I press on...and some more back and forth happens. I bring up the harness again... ![]() My concern is a possible electrical fire...This is their last message to me since I did not reply back. It was going around in circle with the condensation. Dated November 13th ![]() Again they avoid my harness question and concern... Exactly four days later...tonight...my harness caught fire and melted on the passenger side. ![]() ![]() ![]() ![]() I did perform my due diligence and contact the vendor to seek support. I have sent you another e-mail Justin @Diode Dynamics. I will be awaiting your response.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
| The Following User Says Thank You to N1rve For This Useful Post: | tato.valverde (11-18-2015) |
#2 |
Not a troll
Holy. I would not be happy about that. However, if I noticed it was melting, I would have stopped using it immediately.
#3 |
Are you using the proper size electrical fuse ..... ??
humfrz |
#4 |
This came as a kit so I'm not sure. I didn't build the kit nor engineer it. I am merely the end user.
N1rve
| The Following User Says Thank You to N1rve For This Useful Post: | humfrz (11-18-2015) |
#5 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
In for response. That does not at all look good.
#6 |
It looks like it's possible that there was a bad crimp in the terminals. I'm really not sure why this would have happened twice on your vehicle, but that does not matter. Please contact our customer service team and we will send you a heavier-gauge harness at no cost.
For anyone currently using the fog light kit with halogen bulbs, we will exchange your relay harness for a heavier gauge at no cost. (314) 205-3033 or email us: contact@diodedynamics.com I apologize for the inconvenience, but rest assured we will take care of this issue for you Thanks, Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | 86kahl (11-21-2015) |
#7 | |
Drives: 15 BRZ LTD, 05 FXT
Thanks!
#8 | |
Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | JazzleSAURUS (11-19-2015) |
#9 |
Drives: Scion FRS/Whiteout/OEM spoiler
I had nearly identical damage in that exact cable that connects to the fog lights. I called DD and they sent me a replacement bulb and wiring with no hassle.
In my case it may have been water intrusion but nearly identical damage.
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
#10 |
Drives: SWP BRZ
yeah i woudnt use it either. glad vendor taking responsibility and replacing it. but why now? couldnt DD replace when op had concern at first time? i understand op why he had to post here.
I remember asking DD about foglights for people who has premium (only BRZ limited comes with fog light), they dont bother reply back to me even asked for 2 times. |
#11 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
shouldn't the fuse prevent this?
#12 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Not necessarily. The fuse only protects against over current situations where the current that is being drawn by the device and associated wiring/connectors exceeds the designed failure rating of the fuse, in both amps (or milliamps) and time. If the load (in this case a bulb) or the wiring or connections are not designed properly or malfunctioning (i.e. loose connectors, wire gauge too small, too much load for extended periods of time) but still within the rating of the fuse, the fuse will hold but you get an increase in heat. If the circuit isn’t designed to dissipate or otherwise handle that heat, you get melting or potentially fire. This is the reason why you should NEVER replace a fuse with one of higher rating (unless you hold an Electrical Engineering degree, but sometimes they’re even worse!) The entire circuit is designed for safe operation, including the choice of fuse to protect it, so changing any component in that circuit can have a potentially negative impact. |
#13 |
A Demon
Drives: Raven GT86
This is what happens with cheap wiring harnesses. Have you upgraded to a different fog light kit? I see you're in la if you haven't and want to if be happy to lend a hand installing it.
#14 |
What other harnesses out there? LOL Other than OEM...
N1rve
| Review: Diode Dynamic FRS Always-On Module | N1rve | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 03-14-2016 02:35 PM |
| Help!! Diode Dynamic drls are melting?? | Vincenttam | Cosmetic Modification (Interior/Exterior/Lighting) | 51 | 07-10-2015 10:49 AM |
| I got some diode dynamic lighting for my car!! | Vincenttam | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 03-27-2015 01:58 PM |
| Passenger seat caught on fire | PLZdontscream | Issues | Warranty | Recalls / TSB | 46 | 06-11-2014 12:57 PM |
| Anyone use diode dynamic fog lights with HiD? | KamakazeProject | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 01-24-2014 03:41 AM |
