Old 11-18-2015, 02:24 PM   #1
xiayu0320
Drives: 2013 GBS BRZ
Got ECU fault code U0073. Need help!
I just went to a local inspection station yesterday. They told me I got a ECU fault code U0073 cause the computer can not connect to the car. I don't know the reason. After I restart my car I only got CEL on. Name:  ImageUploadedByTapatalk1447874567.437456.jpg
Before I went to the inspection station, I flash back to the original file to the car, I'm OFT user.
Electronical mod list:
Backup camera
Third break light (between two exhaust tips)
xiayu0320 is offline   Reply With Quote
Old 11-18-2015, 02:26 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Clear the code. Don't plug the OFT in while the car is running.
jawn is offline   Reply With Quote
Old 11-18-2015, 02:42 PM   #3
xiayu0320
I just clear the code and take off the OFT yesterday. But still can not connect to the inspection computer.
Old 11-18-2015, 06:50 PM   #4
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
A couple things:
1) Do you have an extension cable attached to your OBD2 port? Lots of people use them with OFT to help it reach a mounting point. Some of these cables can result in connectivity issues for various computers (missing pins, etc.), but not necessarily the OFT. If you have one, remove it and see it that fixes the problem.
2) Make sure you are connecting and disconnecting the OFT while the car is in the "off" state. Sometimes if you connect or disconnect OFT while the car is in either the electrical "on" state or the engine is running, it can cause connectivity issues. To be honest with you, I often disconnect OFT while the car engine is running and have never run into an issue (throwing a code or connection issue), but others have reported issues and it is worthwhile to follow OpenFlash's OFT connection instructions to the letter.
3) When you cleared the code, did the CEL light turn off? If the light is still illuminated, it could be a) the computer is taking its sweet time to recognize the code deletion - this will resolve with a few miles of driving, or b) something about your OFT-OBD2 connection is faulting even after you cleared the code, causing it to remain tripped. This could be due to an extension cable, as I mentioned above, or could indicate something more sinister (e.g. damaged pins in the OBD2 connector, remember, the twins' OBD2 connector is beyond flimsy).
theadmiral976 is offline   Reply With Quote
Old 11-18-2015, 11:41 PM   #5
xiayu0320
Originally Posted by theadmiral976 View Post
A couple things:
Thanks bro! I'll try to find some problems tomorrow.
CEL U0073 - Network Trashed675 Issues | Warranty | Recalls / TSB 17 07-31-2016 06:08 PM
BRZ Steering Right Tightening + VSC Fault?? BRZ2Bars Issues | Warranty | Recalls / TSB 4 05-07-2015 03:58 PM
Brake Switch Fault | TSB FIX Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-11-2014 10:11 PM
MOAR fault codesss! jonbonazza Engine, Exhaust, Transmission 2 09-20-2013 02:47 PM
Torque fault codes help derka-derka Issues | Warranty | Recalls / TSB 2 05-24-2013 09:07 AM
