Old 09-29-2015, 01:30 PM   #281
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Originally Posted by sickmint79 View Post
how long does it take you to trash a coilpack in the past? seems to take me over 10 track days (intermediate)
In the past it was usually after 1-2 weekends the code would pop back up.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 10-22-2015, 11:24 AM   #282
smbstyle
smbstyle's Avatar
So after ~4 days on track with the replaced spark plug in Cyl #2.... I get P0353, for Cyl #3! Argh. Going to replace the coil pack and plug at the same time while I'm there...
2013 SWP BRZ
Old 11-18-2015, 10:26 AM   #283
smbstyle
smbstyle's Avatar
So Cyl #2 now has a new plug and coil pack, and twice this past weekend @ TWS I got a P0300 & P0302 (random misfire and misfire cyl #2....) I'm not sure what else I can do at this point other than look at the injector seals.
2013 SWP BRZ
Old 11-18-2015, 11:00 AM   #284
smbstyle
smbstyle's Avatar
Pretty much how I feel every time I get the P035x code....
2013 SWP BRZ
The Following 7 Users Say Thank You to smbstyle For This Useful Post:
86kahl (12-15-2015), ATL BRZ (11-19-2015), Bonburner (12-24-2015), RavioliG (12-11-2015), skye67 (03-26-2017), xkalelx (11-09-2016), ZionsWrath (04-24-2016)
Old 11-18-2015, 04:24 PM   #285
wparsons
wparsons's Avatar
Originally Posted by Pabloc View Post
Since the problem seems to be heat related, what if the coil packs could be mounted remotely, away from the exhaust heat?
Feasible?
Not feasible, they're coil on plug coils.
flickr
Old 11-19-2015, 03:44 AM   #286
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
http://www.ft86club.com/forums/showthread.php?t=81613
try this?
The Following User Says Thank You to Bonburner For This Useful Post:
smbstyle (11-19-2015)
Old 11-19-2015, 08:42 AM   #287
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
After about 2 dozen track days in this car, I have only had the issue once which was cylinder 1 directly over the unwrapped HKS header and it was close to 100 degrees ambiant. Am I just lucky or could the big vent in my Seibon hood have something to do with it?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-20-2015, 03:55 AM   #288
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I've always wondered about those vented hoods .. what happens when it rains?
can you not drive the car?
Old 11-20-2015, 06:00 AM   #289
churchx
churchx's Avatar
Drives: 2014 GT86
Highly doubt it. Lot more water can be splashed up from below of car when driving through water puddles or through front radgrill, then what may rain in through hood ventholes. Most important things should be watertight enough for that to not be an issue.
Old 12-12-2015, 11:00 AM   #290
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
So sick of this. Replaced #1 twice now and #2 once.
There has been one trackday since then. Now I'm reading p0351 every time I'm at redline, and the car feels seriously underpowered.
Just ordered 2 new coil packs and a full set of spark plugs...
RavioliG is offline   Reply With Quote
Old 12-12-2015, 11:23 AM   #291
churchx
churchx's Avatar
Drives: 2014 GT86
I'd search for cause for plugs to get fouled that frequent. Maybe something gone wrong with tune or intake or oil subsystem? (wild guesses, as what else can impact fouling?)
Old 12-15-2015, 07:59 AM   #292
smbstyle
smbstyle's Avatar
Took the car to @ and we wrapped the header, added a ground and went to 1 step colder plugs last Friday.
Then, at Sebring, we did some testing. Session 1 in the AM, ran for 15 minutes, no CEL. Session 3, mid-day around 1 PM, in the heat of the day, CEL came on towards the end of the session (~20 min in) for P0300 and P0302.
Then, we had the unique opportunity to test at NIGHT at Sebring, significantly cooler and making more power (shift points were noticeably sooner) and the CEL would "blink" on the long, high gear straights at high RPM, but no code would be thrown. We ran the car for about 1 hr 30 min with a 5 min break in the middle, with no code, so it does appear to be a heat issue, but need to find a better cooling solution.
Next step, maybe a CF vented hood?
2013 SWP BRZ
The Following User Says Thank You to smbstyle For This Useful Post:
Old 02-11-2016, 08:07 PM   #293
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
So I've been driving like a grandma to prevent the CEL at higher RPMs .. for whatever reason I had a bad feeling about the stock battery
So I swapped out the (it actually went bad) stock battery and grabbed a deka intimidator grp 35 battery
I have yet to get the CEL at red line ... of course I don't know if this was what went wrong
I'll update if I get a CEL .. but for now nothing
Prior to the battery I was getting the CEL I'd say 85% of the time 6/7k RPMs
Old 02-13-2016, 06:52 PM   #294
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Test: 450 miles of downshifting into 3 4 5 at 4-7.4k rpms
Results: not 1 CEL
Theory: after ignition coils get worn in and used a small amount of resistance builds up and our Stock batteries goes down the gutter too .. I don't think the coils went bad but just don't get enough juice at higher rpms.
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
mx5 2nr (04-23-2016), Teseo (02-13-2016)
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
