Old 11-17-2015, 11:41 AM   #337
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by sato View Post
Definitely has to be a typo... 15psi on 91 in our 12.5:1 CR FA20 😱
Sent using Tapatalk
Definitely not a typo. Normally we would never run this much boost on a supercharger kit on 91 octane, but it plays along very nicely on this setup. I was as surprised as you are.
Sincerely,
Zach
Old 11-17-2015, 11:57 AM   #338
SPCorBUST
SPCorBUST's Avatar
Originally Posted by sales@delicioustuning.com View Post
2.625" Should be about 20psi.
Sincerely,
Zach
Well that's quite a jump... Are there plans to test that on the same motor?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 11-17-2015, 03:36 PM   #339
DeliciousTuning
That's entirely up to the end customer, but we do recommend a built motor for anyone thinking about the 20psi pulley!
Sincerely,
Zach
Old 11-17-2015, 07:14 PM   #340
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by NotSoJDM View Post
Just to document it in the event someone else has the issue....
My belt jumped 2 ribs today after a hard launch. I loosened the belt, checked all the pulleys and nothing seemed amiss. Realigned, and have yet to drive it anymore to see if it happens again.
On a side note, KUDOS to Edelbrock for making this kit easy to work on. Any sort of belt work on the KW is hell compared to this one. I really appreciate the use of an OEM tensioner setup.
I might have missed it in this long thread but who installed your kit, @NotSoJDM?
Old 11-17-2015, 07:25 PM   #341
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I did the installation. Heres a link to the install thread:
http://www.ft86club.com/forums/showthread.php?t=96022
NotSoJDM is offline   Reply With Quote
Old 11-18-2015, 09:24 AM   #342
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
This is my car and Dsport magazined did the install. I just found an E85 station not too far from me so I will be picking up a flex fuel kit, larger injectors, fuel pump and header. Also on those runs we removed my crank pulley, mid pipe and over pipe. So next time it gets tuned it should be on E85 with the full exhaust. May also be picking up a clutch. Also as far as the wheel/tires are concerned they a only 0.30lbs heavier in total. I'm just looking up options
20valvewynn83 is offline   Reply With Quote
Old 11-18-2015, 09:28 AM   #343
NotSoJDM
NotSoJDM's Avatar
I'm assuming you're referring to the Delicious tuned car with the 3" pulley swap as being yours?
Old 11-18-2015, 02:37 PM   #344
Wraithrider
Wraithrider's Avatar
Drives: 2015 Subaru BRZ Pearl White
A question for NotSoJDM
How is your oil cooler install working ? I'm getting ready to install the E Force supercharger kit on my wife's 13BRZ we have a cooler kit to install also and was going to mount it horizontal.
Wraithrider is offline   Reply With Quote
Old 11-18-2015, 02:40 PM   #345
NotSoJDM
NotSoJDM's Avatar
That was @Nitro22 that was doing the horizontal cooler install.
I am working on my own DIY cooler setup, but will be mounting it behind the passenger foglight area.
Old 11-18-2015, 02:52 PM   #346
Wraithrider
Do you think there will be enough room along with the LTR water pump ? We were looking at that area it will cause us to make some new lines possibly some kind of ducting. Thanks for the tip about the upper radiator mounts as we have a larger radiator also
Old 11-18-2015, 03:04 PM   #347
NotSoJDM
NotSoJDM's Avatar
I am a little concerned about squeezing it in there with the pump, but based on Nitro's feedback I definitely wanted something that would be out of the way of the front of the LTR. I am pretty confident I am going to have to build some ducting to it, as it will probably require a mounting solution that will either be angled or somehow out of the direct flow path from the fog light hole.
Old 11-18-2015, 03:08 PM   #348
NotSoJDM
NotSoJDM's Avatar
On a separate note:
The 3" Edelbrock pulley is a stifling $31 upgrade =]
http://www.summitracing.com/parts/edl-15822
Same goes for the 2.75":
http://www.summitracing.com/parts/edl-15823
There is also no mention of needing a new belt with the pulley swap. Someone correct me if I'm wrong on that one though.
Old 11-18-2015, 03:10 PM   #349
Wraithrider
We are using the kits from Mishimoto , when we get into that part of the install I'll try and post some pics as to what we tried. I want to keep it as sleeper as possible as the suburban PD around her seem to pick on the cars with viable changes. Only exterior on her car now is some stripes and some 18" wheels
Old 11-18-2015, 03:15 PM   #350
Wraithrider
visual (Dam auto text )
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
