Old 11-16-2015, 07:01 PM   #1
ChrisP
Ryan Tuerck shift knob
Does anyone have the mishimoto limited edition Ryan Tuerck shift knob installed and do you like it? If so please post pics.
ChrisP is offline   Reply With Quote
Old 11-16-2015, 08:57 PM   #2
stevemp5
Drives: scion fr-s
I bought it and immediately regretted ... just dont fit with the reverse lock-out. I do not understand why ft86speedfactory sells it on their site when it does not even fit.. yeah Ryan tuerk have it on his car but he run supra engine with tranny.
stevemp5 is offline   Reply With Quote
Old 11-16-2015, 09:11 PM   #3
stevemp5
Drives: scion fr-s
You need something like this
The Following User Says Thank You to stevemp5 For This Useful Post:
ChrisP (11-17-2015)
Old 11-16-2015, 10:20 PM   #4
ChrisP
Did it leave the little white part exposed or does it actually block the reverse lock out from working?
Old 11-16-2015, 11:01 PM   #5
stevemp5
Drives: scion fr-s
Block reverse lockout
ChrisP (11-17-2015)
Old 11-16-2015, 11:10 PM   #6
ChrisP
But the blox adapter fixed the problem?
Old 11-17-2015, 07:21 AM   #7
stevemp5
Drives: scion fr-s
I'm not sure of it, i have not tried
ChrisP (11-17-2015)
Old 11-19-2015, 05:02 PM   #8
ChrisP
I just recieved my Ryan Tuerck shift knob today. I have the blox adapter coming in order to clean up the look a little bit, but I found that if you put some paper towels in the knob before screwing it on you can get it to sit at the right hight to clear the reverse lockout.
Old 01-22-2016, 12:32 PM   #9
Kame
Drives: 2016 Scion FRS
I must admit having been a bit let down by the fact it isn't plug and play compatible with the reverse-lock mechanism.
I ended up picking up a few brass washers and stacked em up and taped em together. Then I put 2 rubber washers that were the same size as the brass ones, one at each end of the makeshift spacer.
The aim is that the rubber helps me screw on the shifter to where it is tight and facing in the right direction, without having to screw so hard that I might damage threads.
Kame is offline   Reply With Quote
Old 01-22-2016, 01:45 PM   #10
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I impulse bought one. You have to unscrew it if you want to reverse. You would think a Toyota-themed part would fit on a Toyota, right?
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 01-22-2016, 01:49 PM   #11
Higher Being
Drives: 2014 Asphalt Grey FRS
Thats a bit ridiculous though dont you think?
Higher Being is offline   Reply With Quote
Old 01-22-2016, 06:45 PM   #12
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
I have it and I used loctite to secure the inner thread and the knob itself. I like it, of course you can screw it down enough to leave spave for the lock out...it isn't a big deal to me though.
thatfilipinoguy is offline   Reply With Quote
Old 01-22-2016, 08:38 PM   #13
Kame
Having a loose shift knob is an issue.
Having to unscrew also is an issue.
Hell paper towel ? I wouldn't have thought of that lol.!
Apart from puting a spacer at the bottom, you could probably also use a nut and screw it on before the shoftknob, but I couldn't find one in the 12 x 1.5 thread at the local hardware/auto stores.
You could also enlarge the bore of the, say, first 3/4 in in the inner thread of the knob. It'l sit lower in the end but the reverse-lock could sit inside it and the white plastic bit wouldn't show, which it does with my spacer setup. As they should've made the thing.
Honestly, if they were to make a classic Toyota motorsport colorway on it AND show an install tuto using an frs, they sould've checked to see if it fits with a the stock one.
I wouldn't recommend anyone here to go and buy one.
Ryan Tuerck’s Street FRS Sideways&Smiling Scion FR-S / Toyota 86 GT86 General Forum 1 10-01-2014 11:07 AM
Enjuku Racing - Ryan Tuerck Gets Top 8 & You get 8% OFF Enjuku Racing Announcements, Contests, Giveaways 0 05-31-2013 02:24 PM
Take a hot lap with Ryan Tuerck in the Retaks Scoin FR-S @ FD Long Beach TAP Auto Parts FR-S / BRZ vs.... 3 05-08-2013 06:29 PM
The curse strikes Ryan Tuerck Asphalt~86 Scion FR-S / Toyota 86 GT86 General Forum 10 04-26-2013 10:10 AM
Ryan Tuerck 2j/FRS - back in Portland jason@psi Northwest 8 04-22-2013 11:39 PM
