Old 10-28-2015, 11:54 AM   #3123
Given how hard it is to convince some people that an alignment will net them more performance than a set of $800 ebay coilovers, I think you're overestimating how many "idiots" would take advantage of adjustable alignment hardware.
Yeah, point taken. I keep forgetting those of us here are a niche group of a niche market.
Old 10-28-2015, 12:18 PM   #3124
DarkSunrise
DarkSunrise's Avatar
Yeah, point taken. I keep forgetting those of use here are a niche group of a niche market.
Or as I prefer to think of the subforum, group therapy for trackheads.
2022 BRZ Build
2013 FR-S Build
Old 11-13-2015, 09:20 AM   #3125
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Bump.
LOLS2K is offline   Reply With Quote
Old 11-13-2015, 12:51 PM   #3126
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I love reading this thread! Thanks in advance everyone.
Tire pressure advice needed. Streets of Willow - Clockwise
Vehicle details:
- Stock suspension with camber bolts (alignment shown below)
- P.Mu Club Racer pads
- RE71r 225/45/17 Square
This is my first time running these tires. On previous FWD car Federal 595rsr 215/40/17 Square. Streets of Willow - Clockwise 57º ambient
Cold Pressures:
Left Front - 27 psi
Right Front - 29 psi
Right Rear - 32 psi
Left Rear - 30 psi
Hot Pressures:
Left Front - 33 psi
Right Front - 33 psi
Right Rear - 34 psi
Left Rear - 34 psi
[MENTION=126922]@CSG Mike
Old 11-13-2015, 01:12 PM   #3127
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by LOLS2K View Post
Cold Pressures:
Left Front - 27 psi
Right Rear - 32 psi
Left Rear - 30 psi
Hot Pressures:
Left Front - 33 psi
Right Rear - 34 psi
Left Rear - 34 psi
Those look in the ballpark to me, 30-34 psi hot is what I've heard, maybe dropping 1-2 psi all around next time (TPMS light goes on around 26 psi) for a bit more grip. Camber will help you're probably still working the outside of the tires in the corners but that's a not insignificant upgrade. What's the car doing and what do you want it to do? You might be totally happy with that setup, in that case don't change it, maybe experiment with the knobs you feel comfortable turning to get some insight into how the car reacts.
ineedyourdiddly
Old 11-13-2015, 01:45 PM   #3128
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@strat61caster I have had good success with the pressures that I provided. I'll see what I can do to dial it in at the track. I still don't know how the car is going to react, but it looks like I have a decent starting point. Thanks!
Old 11-13-2015, 02:53 PM   #3129
DarkSunrise
GSpeed was on a similar setup to you (less camber, but wider tires) and found 34 psi hot worked well:
Originally Posted by GSpeed View Post
We ran 245/40/17 RE71Rs this past week for the first time. Car was stock other than camber bolts giving us -1.2° camber in the front. Picked up 4.8 seconds (1:32 to 1:27) with no other changes. Slight rubbing on 17x9+45.
After 20 minutes on track, front right tire was showing over 200F on outer shoulder and times dropped off by 1.5 to 2 seconds. Hot pressures were 34psi, which gave us a nice temperature gradient as measured by a probe in hot pits. Ambient temperature was 85F, track surface was 95F.
All in all, a very fast tire, but may drop off times under hard driving. Great tire for DD use and beginner DE users.
Just watch the outer shoulder tread wear. You may need to bump tire pressures if you're rolling onto the shoulder a lot.
2022 BRZ Build
2013 FR-S Build
Old 11-13-2015, 03:00 PM   #3130
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Cool thanks! I'll keep an eye on the pressures and report back on Monday. Unfortunately, I don't have a tire probe to offer temperatures. Oh wells.
Old 11-13-2015, 04:19 PM   #3131
DarkSunrise
Let us know how it goes and have fun!
2022 BRZ Build
2013 FR-S Build
Old 11-16-2015, 09:41 AM   #3132
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
The track day at Street of Willow (CW) turned out really good. The car was great, and did everything I could've wanted it to. I'm familiar with the track, however this was my first time with the FRS. I learned more and more from every lap, every session, and spin out. Started off at 1:32.0 and managed to get it down to a 1:30.6 on the last laps of my last session. Car is bone stock with 225/45/17 RE71r, P.Mu Club Racer pads, and SPC Camber bolts. Thanks for all the help and advice guys!
Here are some bad iPhone pics (3rd from the top):
Old 11-16-2015, 12:13 PM   #3133
CSG Mike
CSG Mike's Avatar
9 laps on 71Rs! Jeebus.
CSG Mike is online now   Reply With Quote
Old 11-16-2015, 12:20 PM   #3134
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I thought the same thing after seeing the results.
I've never been one to just throw money at the car to make it faster. I like the less is more mentality when tracking a car. So much so that I'm a bit reluctant to change the suspension (coilovers) because I don't want to ruin a good thing. However, I do want to go faster. I guess my question would be:
Which would benefit me more, coilovers (budget $1,500 and down) or components such as lower control arms and top mounts for more camber?
Old 11-16-2015, 12:21 PM   #3135
CSG Mike
CSG Mike's Avatar
What if you could do both? The problem is you will outgrow a lower end suspension at some point. I don't normally recommend them, but a closeout set of Tein Street Flex is an awesome deal, and includes camber plates. Add some SPL rear LCA (which you will not outgrow), and you'll be set for quite a while.
Remember, the 71R is stickier than slicks from just a few generations ago; you've already bought your lap time, to a degree, by using those tires.
Old 11-16-2015, 12:25 PM   #3136
Pat
Pat's Avatar
Drives: 2023 BRZ
I feel like I'm missing something. What's the big deal about driving nine laps on 71Rs?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
