Old 11-13-2015, 02:34 PM   #1
Basket Case
Drives: 2013 Raven fr-s
On lowering springs for and stock shocks, time for new shocks...
So I have been on Hotchkis lowering springs and my OEM shocks. They are starting to wear, which is expected. My car has 64,xxx miles on it now, and probably the last 25,000 with the lowering springs.
This is where my dilemma comes from. Should i go for new kong or bilstein shocks, or just get coilers? At this point, it looks like i can get a set of tein or other coilers for damn near the same price as just the new shocks.
I plan on tracking the car at some point, but I DD the car, so i don't plan on slamming it with coils.
opinions?
Basket Case is offline   Reply With Quote
Old 11-13-2015, 02:42 PM   #2
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I'm wondering the same thing a set of Konis or B8s are around ~900. You can get flex Zs for around that price.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-13-2015, 02:43 PM   #3
Basket Case
That is exactly what i was thinking...The pricing just seems to make it a better option, but i could be wrong?
Old 11-13-2015, 03:20 PM   #4
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
The valving on low-end coilovers is generally not great. A set of Koni adjustables or B8s, especially if you get custom valving done on either, will likely be a much better suspension setup than most cheap coilovers.
Depending on what your budget would be you can get into some okay options, like RCE Tarmac0s, around the $1,500 mark. But if you're spending less than that I'd just go for a good set of shocks, preferably custom valved for your spring rates.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Tcoat (11-13-2015)
Old 11-13-2015, 03:32 PM   #5
bfrank1972
Drives: 2013 FR-S Argento
I would normally agree with this - but supposedly the TEIN Flex Z's are getting pretty good reviews. I don't have them but I have the older Street Flex, I think the dampers are pretty much the same except the Flex Z's aren't rebuildable. I like them a lot - don't think you can lump these in with the 'low end' coilover group (albeit they're certainly not premium dampers). Plus you get front camber plates! And you get height adjustability.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Tcoat (11-13-2015)
Old 11-13-2015, 04:03 PM   #6
Shark_Bait88
Ahh. After reading CSG's review of the Flex Zs it doesn't seem like all that bad of an option actually.
Old 11-13-2015, 04:26 PM   #7
Nickosport
Drives: 2015 WRB BRZ Premium
I've been thinking about this myself. I have lowering spring on and will need to do something about the dampers in the next year. I'm leaning to the Flex Zs because they are getting such good reviews. Id like to have camber plates; ride height is not such a big issue for me since I DD the car and don't want to go super low anyway.
In reference to the street flex/rebuilding issue - You cant rebuild the Flex Zs, but the replacement damper cartridges are relatively inexpensive. So, even if the 1st set wears out, the fix will be easy with replacement cartridges.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 11-13-2015, 04:51 PM   #8
Phantobe
Phantobe's Avatar
Well since I just bought lowering springs, I'll most likely just go with some shocks with adjustable damping and springs. Custom valving is a +++, so you can better match the shock to the spring rate.
I don't care too much about height adjustability I'm gonna be lowered about 1.2" to 1.4" on the springs, so theres no point for me to go with coilovers as I'm not gonna go any lower than that.
The Following User Says Thank You to Phantobe For This Useful Post:
Shark_Bait88 (11-13-2015)
Old 11-15-2015, 02:46 AM   #9
Coastermikey
Drives: BRZ DGM
opinions?
I'm a little over 60k miles, swapped my worn struts and lowering springs with flex z's. No complaints here. I DD as well.
Coastermikey is offline   Reply With Quote
The Following User Says Thank You to Coastermikey For This Useful Post:
Basket Case (11-15-2015)
Old 11-15-2015, 07:04 PM   #10
Basket Case
Does it feel better then before?
Old 11-15-2015, 07:35 PM   #11
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Flex Z's are a great option... just impossible to find. Not likely to be back in stock until january it seems. CSG bought out the next production run that is due in december. So you'll have to go there for any shot at grabbing a set.
ajcarson11 is offline   Reply With Quote
Old 11-16-2015, 09:31 AM   #12
Coastermikey
Drives: BRZ DGM
The ride is not as harsh but feels just as responsive as when the OEM struts were brand new with the lowering springs.
FS: Stock Shocks w/ Tein S-Tech Lowering Springs $100 DomoSpeed Southern California 0 12-03-2014 03:15 AM
NEW EIBACH LOWERING SPORTLINE SPRINGS & OEM SHOCKS - SAVE TIME & MONEY - $450 SHIPPED STS-V Brakes, Suspension, Chassis 5 08-31-2014 10:59 AM
What shocks recommended for Tein S-Tech -1.2/-1.02 Lowering springs? STS-V Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-26-2014 04:21 PM
lowering springs and aftermarket strut shocks charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-22-2013 12:35 PM
Which lowering springs compatible with OEM shocks? hmong337 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 08-26-2013 11:37 AM
