Old 11-12-2015, 01:49 AM   #953
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
I don't think anyone here would endorse cruising at 7300rpm though.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 11-12-2015, 02:11 AM   #954
steve99
Drives: FT86
Originally Posted by justinco View Post
Sorry if I missed it somewhere...but, does OFT "smooth out" the rev-limiter by chance? For example, if I am in 2nd gear and hit the rev-limiter, will it "bounce" off the limiter by cutting fuel/spark (or whatever it does to cause the bouncing off the limiter)? Or, will it cruise along smoothly at the limiter with no bouncing?
Thanks!
It wont bounce its soft rev limiter, it uses ignition retard then fuel cut, it will just sit at the limiter
Old 11-12-2015, 02:23 AM   #955
riboyster
riboyster's Avatar
Hey Steve, could you take a look at todays charts when you get a chance? Updated the post with my dyno chart on it with the new links. Kinda scared. I don't think my car is detecting knock or lowering IAM.
Old 11-12-2015, 02:41 AM   #956
JB86'd
JB86'd's Avatar
Drives: JAWS
How many miles do you have on the latest tune? The car won't register FLKC or lower IAM for a while after flashing. Also, why are you scared? Your AFR looks pretty spot on and LTFT is in good ranges on that recent 2nd gear wot run.
JB86'd is offline   Reply With Quote
Old 11-12-2015, 02:50 AM   #957
riboyster
riboyster's Avatar
Plugged it in while driving yesterday at some point and got a CEL, had to clear. So I'm thinking it isn't yet listening for knocks. Scared because my torque curve is acting different than it did yesterday (specifically around 7k)
Yesterday = Blue
Today = Red.
I think I need to wait for it to pull some timing again before I can accurately log stuff.
Old 11-12-2015, 03:18 AM   #958
JB86'd
JB86'd's Avatar
Drives: JAWS
Yesterday = Blue
Today = Red.
Okay, don't plug in the tablet with the car on, or even key turned because it causes communication errors and CEL. You let it idle for a minute before touching throttle right? Drive for 60 miles to learn fuel trims then do another log.
Also, are you doing these logs in the same exact place at similar temperatures? I wouldn't read into a virtual dyno too much. The datalog is whats important.
Old 11-12-2015, 03:20 AM   #959
riboyster
riboyster's Avatar
Sounds good. I've already got my corrected timing .bin from yesterday's results ready. Just wanted more data before I commit to a flash
Old 11-12-2015, 03:43 AM   #960
Kodename47
Kodename47's Avatar
Drives: UK GT86
Unless you're using Virtual Dyno on the same road under similar conditions it is, essentially, useless. I note that one of your pulls is labelled as downhill so that immediately renders it unreliable (in VD at least).
@JB86'd what do you mean that FLKC isn't immediately active? AFAIK so long as you're in the FLKC region it should be active, FBKC should also be the same. As far as I know there is no learning or similar, although I could be wrong.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-12-2015, 04:29 AM   #961
riboyster
riboyster's Avatar
Same spot on the road, same conditions every time. Barely downhill, and I've adjusted the dyno to compensate.
Old 11-12-2015, 08:11 AM   #962
steve99
Drives: FT86
Yesterday = Blue
Today = Red.
new log look good no knock good ltft afr good.
maybe you had bit of bad fuel last time ?? but all ok now
Old 11-12-2015, 11:43 AM   #963
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yesterday = Blue
Today = Red.
If you do 10 pulls on that same road back to back (this is what I do using 3rd gear on the flattest road I can find) at least 8 or 7 out of the 10 should look almost exactly the same. For virtual dyno to have any use it has to be consistent, road has to be flat, the logs used cannot have any wheel slip. 4th gear pulls will be better than 3rd gear pulls. 2nd gear pulls happen too fast to be any good, IMO. If you're only doing one single pull and converting that each time, it will be extremely inconsistent and the data useless. Any log with inconsistencies, such as sudden rpm rise due to wheels slip, are throwaways and useless.
Good luck!
Intent > Content
Old 11-12-2015, 01:53 PM   #964
justinco
justinco's Avatar
Drives: 2022 GR86
Nor would I. Specific use case is for autocross, where sometimes I momentarily have to be on the rev-limiter where shifting doesn't make sense.
Thanks.
justinco is offline   Reply With Quote
Old 11-12-2015, 02:40 PM   #965
JB86'd
JB86'd's Avatar
Drives: JAWS
@Kodename47 That's my bad, I meant IAM will not drop immediately after, although FLKC may still be active and learning.
Old 11-13-2015, 02:46 AM   #966
riboyster
riboyster's Avatar
Not sure that it's learning or active. The only indication I have that it is active is that it's transmitting a single value for the duration. It won't move on my trouble areas yet, so there's definitely nothing to learn.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
