Old 11-10-2015, 01:42 PM   #309
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I think it could work either way. Backwards probably wouldn't mess with aero and add protection. Facing towards the front of the car would let more air hit the cooler and might add some additional air to the other heat exchangers, but it would still flow out how the normal incoming air would. I guess there could be an instance where you would get air hitting from coming in normally AND flowing upwards, and I'm not sure on how that would affect aero if it even would.
On the corvette this just replaced a somewhat shoddy air dam / hole with a scoop. I didn't have it personally, but my intake took air directly from that area and this was something I had considered.
Old 11-10-2015, 04:27 PM   #310
toast
Drives: 14 BSP Edelbrock BRZ
You could just make an aluminum scoop with the exit in the back, that might also increase the pressure differential and get you more flow through the oil cooler.
Edit: just noticed the post above mine, we're saying the same thing. I don't see how the corvette piece would have helped anything, you definitely don't want the scoop facing forward in this application.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
sato (11-10-2015), yberther (08-25-2016)
Old 11-10-2015, 04:51 PM   #311
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Nothing to do with aero, more so about getting air to flow through the heat exchanger in one direction. Heat exchangers are at the most efficient when it has laminar flow across it, efftively pulling the heat from the fins out and away.
Exactly! Either way, an interesting and imaginative mod. Too bad @Nitro22 isn't planning on making more of these for sale. Albeit a bit niche, I think there is a small market there.
Old 11-10-2015, 05:16 PM   #312
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Glad to see some fellow members going with the Edelbrock kit. Being CARB exempt, I will most likely go this route when my finances are straightened out come the new year.
So for the California owners, Do any of you live or drive near Santa Barbara / Goleta area? Would love to see this kit first hand. I venture down to L.A. every once in a blue moon as well.
GotBRZ1691 is offline   Reply With Quote
Old 11-10-2015, 06:11 PM   #313
Summerwolf
Panda Trueno
Summerwolf's Avatar
You would have to see the corvette's cooling system. Stock it has a duct there just not as enlarged that would feed the air intake.
I agree that if something like that were used to face it rearwards.
Old 11-10-2015, 08:08 PM   #314
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
What supporting mods were required to achieve this? Injectors or fuel pump?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-10-2015, 08:12 PM   #315
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
AVO makes a ducted oil cooler that mounts off to the side but has it's own air duct.
Lunatic is offline   Reply With Quote
Old 11-10-2015, 08:24 PM   #316
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
This car had an upgraded DW fuel pump and DW 700cc injectors.
Sincerely,
Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
CSG Mike (11-10-2015), whataboutbob (11-10-2015)
Old 11-10-2015, 08:29 PM   #317
JEDI
JEDI's Avatar
Drives: 2015 FR-S RS 1.0 #0993
Sincerely,
Zach
Awesome!
2015 Subaru WRX - SOLD!
2013 Scion FR-S - Traded In!
2015 Scion FR-S RS 1.0 - My DD , GF, and BFF!
JEDI is offline   Reply With Quote
Old 11-10-2015, 08:34 PM   #318
CSG Mike
CSG Mike's Avatar
Originally Posted by JEDI View Post
Awesome!
I think there's a kit calling your name...
Old 11-10-2015, 10:33 PM   #319
BigFatFlip
BigFatFlip's Avatar
I do like the ducted oil coolers but I think the AVO resides right where the pump is for the water to air intercooler.
Old 11-10-2015, 11:16 PM   #320
Lunatic
Lunatic's Avatar
Yes, didn't think of that.
Old 11-14-2015, 06:54 PM   #321
DeliciousTuning
Thought some of you might be interested in our latest development on the Edelbrock eForce supercharger. We have started some pulley test and tunes and so far the 3.00in (15 PSI) pulley works great on 91 octane. Though you will be at the limit on stock injectors. More to come...
Cheers,
William Knose
The Following 8 Users Say Thank You to DeliciousTuning For This Useful Post:
Alltezza (11-14-2015), BigFatFlip (11-14-2015), Calum (11-16-2015), clayrush (11-14-2015), EJ. (06-18-2016), NotSoJDM (11-14-2015), stoked_on_spool (11-16-2015), Summerwolf (11-16-2015)
Old 11-14-2015, 06:55 PM   #322
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Cheers,
William Knose
Oh yessss I'm already ready for this. Let me know when we can make it happen.
NotSoJDM is offline   Reply With Quote
The Following User Says Thank You to NotSoJDM For This Useful Post:
CSG Mike (11-15-2015)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
